Piotr Król (piotr.krol@3mdeb.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/14138
commit 65bf04e7774d04912e56ded6f9dad060b3d95caf Author: Piotr Król piotr.krol@3mdeb.com Date: Fri May 27 12:04:13 2016 +0200
pcengines/apu2: add board support
Initial work based on db-ft3b-ls and code released by Eltan. Board not booting yet.
Known issues:
* serial input in SeaBIOS doesn't work, so there is no way to choose boot device ie. USB * timeouts on XHCI * AmdInitLate fails * device 18 PCI error * 'mainboard_picr_data' or 'mainboard_intr_data' tables are NULL
Change-Id: Id23e448e27f4bba47b7e9e7fa7679e2690c6e4bc Signed-off-by: Piotr Król piotr.krol@3mdeb.com --- src/mainboard/pcengines/apu2/BiosCallOuts.c | 159 +++++++++++++ src/mainboard/pcengines/apu2/HYNIX-2G-1333.spd.hex | 264 +++++++++++++++++++++ .../pcengines/apu2/HYNIX-4G-1333-ECC.spd.hex | 261 ++++++++++++++++++++ src/mainboard/pcengines/apu2/Kconfig | 56 +++++ src/mainboard/pcengines/apu2/Kconfig.name | 2 + src/mainboard/pcengines/apu2/Makefile.inc | 40 ++++ src/mainboard/pcengines/apu2/OemCustomize.c | 121 ++++++++++ src/mainboard/pcengines/apu2/acpi/AmdImc.asl | 109 +++++++++ src/mainboard/pcengines/apu2/acpi/gpe.asl | 67 ++++++ src/mainboard/pcengines/apu2/acpi/ide.asl | 2 + src/mainboard/pcengines/apu2/acpi/mainboard.asl | 37 +++ src/mainboard/pcengines/apu2/acpi/routing.asl | 193 +++++++++++++++ src/mainboard/pcengines/apu2/acpi/si.asl | 23 ++ src/mainboard/pcengines/apu2/acpi/sleep.asl | 95 ++++++++ src/mainboard/pcengines/apu2/acpi/thermal.asl | 2 + src/mainboard/pcengines/apu2/acpi/usb_oc.asl | 36 +++ src/mainboard/pcengines/apu2/acpi_tables.c | 56 +++++ src/mainboard/pcengines/apu2/apu2.h | 58 +++++ src/mainboard/pcengines/apu2/board_info.txt | 6 + src/mainboard/pcengines/apu2/cmos.layout | 74 ++++++ src/mainboard/pcengines/apu2/devicetree.cb | 91 +++++++ src/mainboard/pcengines/apu2/dsdt.asl | 87 +++++++ src/mainboard/pcengines/apu2/irq_tables.c | 103 ++++++++ src/mainboard/pcengines/apu2/mainboard.c | 99 ++++++++ src/mainboard/pcengines/apu2/mptable.c | 129 ++++++++++ src/mainboard/pcengines/apu2/romstage.c | 110 +++++++++ 26 files changed, 2280 insertions(+)
diff --git a/src/mainboard/pcengines/apu2/BiosCallOuts.c b/src/mainboard/pcengines/apu2/BiosCallOuts.c new file mode 100644 index 0000000..a6c7373 --- /dev/null +++ b/src/mainboard/pcengines/apu2/BiosCallOuts.c @@ -0,0 +1,159 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2012 Advanced Micro Devices, Inc. + * Copyright (C) 2016 3mdeb + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include "AGESA.h" +#include "amdlib.h" +#include <spd_cache.h> +#include <northbridge/amd/pi/BiosCallOuts.h> +#include "Ids.h" +#include "OptionsIds.h" +#include "heapManager.h" +#include "FchPlatform.h" +#include "cbfs.h" +#if IS_ENABLED(CONFIG_HUDSON_IMC_FWM) +#include "imc.h" +#endif +#include "hudson.h" +#include <stdlib.h> +#include "apu2.h" + +static AGESA_STATUS Fch_Oem_config(UINT32 Func, UINT32 FchData, VOID *ConfigPtr); +static AGESA_STATUS board_ReadSpd_from_cbfs(UINT32 Func, UINTN Data, VOID *ConfigPtr); + +const BIOS_CALLOUT_STRUCT BiosCallouts[] = +{ + {AGESA_ALLOCATE_BUFFER, agesa_AllocateBuffer }, + {AGESA_DEALLOCATE_BUFFER, agesa_DeallocateBuffer }, + {AGESA_LOCATE_BUFFER, agesa_LocateBuffer }, + {AGESA_READ_SPD, board_ReadSpd_from_cbfs }, + {AGESA_DO_RESET, agesa_Reset }, + {AGESA_READ_SPD_RECOVERY, agesa_NoopUnsupported }, + {AGESA_RUNFUNC_ONAP, agesa_RunFuncOnAp }, + {AGESA_GET_IDS_INIT_DATA, agesa_EmptyIdsInitData }, + {AGESA_HOOKBEFORE_DQS_TRAINING, agesa_NoopSuccess }, + {AGESA_HOOKBEFORE_EXIT_SELF_REF, agesa_NoopSuccess }, + {AGESA_FCH_OEM_CALLOUT, Fch_Oem_config } +}; +const int BiosCalloutsLen = ARRAY_SIZE(BiosCallouts); + +//{AGESA_GNB_GFX_GET_VBIOS_IMAGE, agesa_NoopUnsupported } + + +/* + * Hardware Monitor Fan Control + * Hardware limitation: + * HWM will fail to read the input temperature via I2C if other + * software switches the I2C address. AMD recommends using IMC + * to control fans, instead of HWM. + */ +static void oem_fan_control(FCH_DATA_BLOCK *FchParams) +{ + FchParams->Imc.ImcEnable = FALSE; + FchParams->Hwm.HwMonitorEnable = FALSE; + FchParams->Hwm.HwmFchtsiAutoPoll = FALSE; /* 1 enable, 0 disable TSI Auto Polling */ +} + +/** + * Fch Oem setting callback + * + * Configure platform specific Hudson device, + * such Azalia, SATA, IMC etc. + */ +static AGESA_STATUS Fch_Oem_config(UINT32 Func, UINT32 FchData, VOID *ConfigPtr) +{ + AMD_CONFIG_PARAMS *StdHeader = (AMD_CONFIG_PARAMS *)ConfigPtr; + if (StdHeader->Func == AMD_INIT_RESET) { + FCH_RESET_DATA_BLOCK *FchParams = (FCH_RESET_DATA_BLOCK *) FchData; + printk(BIOS_DEBUG, "Fch OEM config in INIT RESET "); + //FchParams_reset->EcChannel0 = TRUE; /* logical devicd 3 */ + FchParams->LegacyFree = CONFIG_HUDSON_LEGACY_FREE; + FchParams->FchReset.SataEnable = hudson_sata_enable(); + FchParams->FchReset.IdeEnable = hudson_ide_enable(); + FchParams->FchReset.Xhci0Enable = IS_ENABLED(CONFIG_HUDSON_XHCI_ENABLE); + FchParams->FchReset.Xhci1Enable = FALSE; + } else if (StdHeader->Func == AMD_INIT_ENV) { + FCH_DATA_BLOCK *FchParams = (FCH_DATA_BLOCK *)FchData; + printk(BIOS_DEBUG, "Fch OEM config in INIT ENV "); + + + FchParams->Azalia.AzaliaEnable = AzDisable; + + /* Fan Control */ + oem_fan_control(FchParams); + + /* XHCI configuration */ + FchParams->Usb.Xhci0Enable = IS_ENABLED(CONFIG_HUDSON_XHCI_ENABLE); + FchParams->Usb.Xhci1Enable = FALSE; + + /* EHCI configuration */ + FchParams->Usb.Ehci3Enable = !IS_ENABLED(CONFIG_HUDSON_XHCI_ENABLE); + FchParams->Usb.Ehci1Enable = FALSE; // Disable EHCI 0 (port 0 to 3) + FchParams->Usb.Ehci2Enable = TRUE; // Enable EHCI 1 ( port 4 to 7) port 4 and 5 to EHCI header port 6 and 7 to PCIe slot. + + /* sata configuration */ + FchParams->Sata.SataDevSlpPort0 = 0; // Disable DEVSLP0 and 1 to make sure GPIO55 and 59 are not used by DEVSLP + FchParams->Sata.SataDevSlpPort1 = 0; + + FchParams->Sata.SataClass = CONFIG_HUDSON_SATA_MODE; + switch ((SATA_CLASS)CONFIG_HUDSON_SATA_MODE) { + case SataRaid: + case SataAhci: + case SataAhci7804: + case SataLegacyIde: + FchParams->Sata.SataIdeMode = FALSE; + break; + case SataIde2Ahci: + case SataIde2Ahci7804: + default: /* SataNativeIde */ + FchParams->Sata.SataIdeMode = TRUE; + break; + } + } + printk(BIOS_DEBUG, "Done\n"); + + return AGESA_SUCCESS; +} + + +static AGESA_STATUS board_ReadSpd_from_cbfs(UINT32 Func, UINT32 Data, VOID *ConfigPtr) +{ + AGESA_STATUS Status = AGESA_UNSUPPORTED; +#ifdef __PRE_RAM__ + AGESA_READ_SPD_PARAMS *info = ConfigPtr; + int index = 0; + + if (info->MemChannelId > 0) + return AGESA_UNSUPPORTED; + if (info->SocketId != 0) + return AGESA_UNSUPPORTED; + if (info->DimmId != 0) + return AGESA_UNSUPPORTED; + + /* One SPD file contains all 4 options, determine which index to read here, then call into the standard routines*/ + + u8 *gpio_bank0_ptr = (u8 *)(ACPI_MMIO_BASE + GPIO_BANK0_BASE); + if (*(gpio_bank0_ptr + (0x40 << 2) + 2) & BIT0) index |= BIT0; + if (*(gpio_bank0_ptr + (0x41 << 2) + 2) & BIT0) index |= BIT1; + + printk(BIOS_INFO, "Reading SPD index %d\n", index); + + if (read_spd_from_cbfs((u8*)info->Buffer, index) < 0) + die("No SPD data\n"); + + Status = AGESA_SUCCESS; +#endif + return Status; +} diff --git a/src/mainboard/pcengines/apu2/HYNIX-2G-1333.spd.hex b/src/mainboard/pcengines/apu2/HYNIX-2G-1333.spd.hex new file mode 100644 index 0000000..a70db53 --- /dev/null +++ b/src/mainboard/pcengines/apu2/HYNIX-2G-1333.spd.hex @@ -0,0 +1,264 @@ +# PCEngines 2Gb 1333 + +# SPD contents for APU 2GB DDR3 NO ECC (1333MHz PC1333) soldered down +# 0 Number of SPD Bytes used / Total SPD Size / CRC Coverage +# bits[3:0]: 1 = 128 SPD Bytes Used +# bits[6:4]: 1 = 256 SPD Bytes Total +# bit7 : 0 = CRC covers bytes 0 ~ 128 +01 + +# 1 SPD Revision +# 0x13 = Revision 1.3 +13 + +# 2 Key Byte / DRAM Device Type +# bits[7:0]: 0x0b = DDR3 SDRAM +0B + +# 3 Key Byte / Module Type +# bits[3:0]: 3 = SO-DIMM +# bits[3:0]: 8 = 72b-SO-DIMM +# bits[7:4]: reserved +03 + +# 4 SDRAM CHIP Density and Banks +# bits[3:0]: 3 = 2 Gigabits Total SDRAM capacity per chip +# bits[3:0]: 4 = 4 Gigabits Total SDRAM capacity per chip +# bits[6:4]: 0 = 3 (8 banks) +# bit7 : reserved +03 + +# 5 SDRAM Addressing +# bits[2:0]: 1 = 10 Column Address Bits +# bits[5:3]: 4 = 16 Row Address Bits +# bits[5:3]: 3 = 15 Row Address Bits +# bits[5:3]: 2 = 14 Row Address Bits +# bits[7:6]: reserved +19 + +# 6 Module Nominal Voltage, VDD +# bit0 : 0 = 1.5 V operable +# bit1 : 0 = NOT 1.35 V operable +# bit2 : 0 = NOT 1.25 V operable +# bits[7:3]: reserved +00 + +# 7 Module Organization +# bits[2:0]: 1 = 8 bits +# bits[2:0]: 2 = 16 bits +# bits[5:3]: 0 = 1 Rank +# bits[7:6]: reserved +01 + +# 8 Module Memory Bus Width +# bits[2:0]: 3 = Primary bus width is 64 bits +# bits[4:3]: 0 = 0 bits (no bus width extension) +# bits[4:3]: 1 = 8 bits (for ECC) +# bits[7:5]: reserved +03 + +# 9 Fine Timebase (FTB) Dividend / Divisor +# bits[3:0]: 0x02 divisor +# bits[7:4]: 0x05 dividend +# 5 / 2 = 2.5ps +52 + +# 10 Medium Timebase (MTB) Dividend +# 11 Medium Timebase (MTB) Divisor +# 1 / 8 = .125 ns +01 08 + +# 12 SDRAM Minimum Cycle Time (tCKmin) +# 0x0a = tCKmin of 1.25 ns = DDR3-1600 (800 MHz clock) +# 0x0c = tCKmin of 1.5 ns = DDR3-1333 (667 MHz clock) +# 0x0c = tCKmin of 1.5 ns = in multiples of MTB +0C + +# 13 Reserved +00 + +# 14 CAS Latencies Supported, Least Significant Byte +# 15 CAS Latencies Supported, Most Significant Byte +# Cas Latencies of 11 - 5 are supported +7E 00 + +# 16 Minimum CAS Latency Time (tAAmin) +# 0x6C = 13.5ns - DDR3-1333 +# 0x69 = 13.125 ns - DDR3-1333 +69 + +# 17 Minimum Write Recovery Time (tWRmin) +# 0x78 = tWR of 15ns - All DDR3 speed grades +78 + +# 18 Minimum RAS# to CAS# Delay Time (tRCDmin) +# 0x6E = 13.5ns - DDR3-1333 +# 0x69 = 13.125 ns - DDR3-1333 +69 + +# 19 Minimum Row Active to Row Active Delay Time (tRRDmin) +# 0x30 = 6.0ns +# 0x38 = 7.0ns +# 0x3C = 7.5ns +30 + +# 20 Minimum Row Precharge Delay Time (tRPmin) +# 0x6C = 13.5ns - +# 0x69 = 13.125 ns - DDR3-1333 +69 + +# 21 Upper Nibbles for tRAS and tRC +# bits[3:0]: tRAS most significant nibble = 1 (see byte 22) +# bits[7:4]: tRC most significant nibble = 1 (see byte 23) +11 + +# 22 Minimum Active to Precharge Delay Time (tRASmin), LSB +# 0x120 = 36ns - DDR3-1333 (see byte 21) +# 0x120 = 36ns - DDR3 +20 + +# 23 Minimum Active to Active/Refresh Delay Time (tRCmin), LSB +# 0x289 = 49.125ns - DDR3-1333 +89 + +# 24 Minimum Refresh Recovery Delay Time (tRFCmin), LSB +# 25 Minimum Refresh Recovery Delay Time (tRFCmin), MSB +# 0x500 = 160ns - for 2 Gigabit chips +# 0x820 = 260ns - for 4 Gigabit chips +00 05 + +# 26 Minimum Internal Write to Read Command Delay Time (tWTRmin) +# 0x3c = 7.5 ns - All DDR3 SDRAM speed bins +3C + +# 27 Minimum Internal Read to Precharge Command Delay Time (tRTPmin) +# 0x3c = 7.5ns - All DDR3 SDRAM speed bins +3C + +# 28 Upper Nibble for tFAWmin +# 29 Minimum Four Activate Window Delay Time (tFAWmin) +# 0x00F0 = 30ns - DDR3-1333, 1 KB page size +00 F0 + +# 30 SDRAM Optional Feature +# bit0 : 1= RZQ/6 supported +# bit1 : 1 = RZQ/7 supported +# bits[6:2]: reserved +# bit7 : 1 = DLL Off mode supported +83 + +# 31 SDRAM Thermal and Refresh Options +# bit0 : 1 = Temp up to 95c supported +# bit1 : 0 = 85-95c uses 2x refresh rate +# bit2 : 1 = Auto Self Refresh supported +# bit3 : 0 = no on die thermal sensor +# bits[6:4]: reserved +# bit7 : 0 = partial self refresh supported +01 + +# 32 Module Thermal Sensor +# 0 = Thermal sensor not incorporated onto this assembly +00 + +# 33 SDRAM Device Type +# bits[1:0]: 0 = Signal Loading not specified +# bits[3:2]: reserved +# bits[6:4]: 0 = Die count not specified +# bit7 : 0 = Standard Monolithic DRAM Device +00 + +# 34 Fine Offset for SDRAM Minimum Cycle Time (tCKmin) +00 + +# 35 Fine Offset for Minimum CAS Latency Time (tAAmin) +00 + +# 36 Fine Offset for Minimum RAS# to CAS# Delay Time (tRCDmin) +00 + +# 37 Fine Offset for Minimum Row Precharge Delay Time (tRPmin) +00 + +# 38 Fine Offset for Minimum Active to Active/Refresh Delay (tRCmin) +00 + +# 39 40 (reserved) +00 00 + +# 41 tMAW, MAC +# 8K*tREFI / 200k +86 + +# 42 - 47 (reserved) +00 00 00 00 00 00 + +# 48 - 55 (reserved) +00 00 00 00 00 00 00 00 + +# 56 - 59 (reserved) +00 00 00 00 + +# 60 Raw Card Extension, Module Nominal Height +# bits[4:0]: 0 = <= 15mm tall +# bits[7:5]: 0 = raw card revision 0-3 +00 + +# 61 Module Maximum Thickness +# bits[3:0]: 0 = thickness front <= 1mm +# bits[7:4]: 0 = thinkness back <= 1mm +00 + +# 62 Reference Raw Card Used +# bits[4:0]: 0 = Reference Raw card A used +# bits[6:5]: 0 = revision 0 +# bit7 : 0 = Reference raw cards A through AL +# revision B4 +61 + +# 63 Address Mapping from Edge Connector to DRAM +# bit0 : 0 = standard mapping (not mirrored) +# bits[7:1]: reserved +00 + +# 64 - 71 (reserved) +00 00 00 00 00 00 00 00 + +# 72 - 79 (reserved) +00 00 00 00 00 00 00 00 + +# 80 - 87 (reserved) +00 00 00 00 00 00 00 00 + +# 88 - 95 (reserved) +00 00 00 00 00 00 00 00 + +# 96 - 103 (reserved) +00 00 00 00 00 00 00 00 + +# 104 - 111 (reserved) +00 00 00 00 00 00 00 00 + +# 112 - 116 (reserved) +00 00 00 00 00 + +# 117 - 118 Module ID: Module Manufacturers JEDEC ID Code +# 0x0001 = AMD +00 01 + +# 119 Module ID: Module Manufacturing Location - OEM specified +00 + +# 120 Module ID: Module Manufacture Year in BCD +# 0x15 = 2015 +15 + +# 121 Module ID: Module Manufacture week +# 0x44 = 44th week +44 + +# 122 - 125: Module Serial Number +00 00 00 00 + +# 126 - 127: Cyclical Redundancy Code +b6 73 + diff --git a/src/mainboard/pcengines/apu2/HYNIX-4G-1333-ECC.spd.hex b/src/mainboard/pcengines/apu2/HYNIX-4G-1333-ECC.spd.hex new file mode 100644 index 0000000..ac6b4c6 --- /dev/null +++ b/src/mainboard/pcengines/apu2/HYNIX-4G-1333-ECC.spd.hex @@ -0,0 +1,261 @@ +# HYNIX-4GBYTE-1333 The H9 N0 SPD delivered by Hynix + +# SPD contents for APU 4GB DDR3 ECC (1333MHz PC1333) soldered down +# 0 Number of SPD Bytes used / Total SPD Size / CRC Coverage +# bits[3:0]: 1 = 128 SPD Bytes Used +# bits[6:4]: 1 = 256 SPD Bytes Total +# bit7 : 0 = CRC covers bytes 0 ~ 128 +01 + +# 1 SPD Revision - +# 0x13 = Revision 1.3 +13 +# 2 Key Byte / DRAM Device Type +# bits[7:0]: 0x0b = DDR3 SDRAM +0B + +# 3 Key Byte / Module Type +# bits[3:0]: 3 = SO-DIMM +# bits[3:0]: 8 = 72b-SO-DIMM +# bits[7:4]: reserved +08 + +# 4 SDRAM CHIP Density and Banks +# bits[3:0]: 3 = 2 Gigabits Total SDRAM capacity per chip +# bits[3:0]: 4 = 4 Gigabits Total SDRAM capacity per chip +# bits[6:4]: 0 = 3 (8 banks) +# bit7 : reserved +04 + +# 5 SDRAM Addressing +# bits[2:0]: 1 = 10 Column Address Bits +# bits[5:3]: 4 = 16 Row Address Bits +# bits[5:3]: 3 = 15 Row Address Bits +# bits[5:3]: 2 = 14 Row Address Bits +# bits[7:6]: reserved +21 + +# 6 Module Nominal Voltage, VDD +# bit0 : 0 = 1.5 V operable +# bit1 : 0 = NOT 1.35 V operable +# bit2 : 0 = NOT 1.25 V operable +# bits[7:3]: reserved +00 + +# 7 Module Organization +# bits[2:0]: 1 = 8 bits +# bits[2:0]: 2 = 16 bits +# bits[5:3]: 0 = 1 Rank +# bits[7:6]: reserved +01 + +# 8 Module Memory Bus Width +# bits[2:0]: 3 = Primary bus width is 64 bits +# bits[4:3]: 0 = 0 bits (no bus width extension) +# bits[4:3]: 1 = 8 bits (for ECC) +# bits[7:5]: reserved +0B + +# 9 Fine Timebase (FTB) Dividend / Divisor +# bits[3:0]: 0x02 divisor +# bits[7:4]: 0x05 dividend +# 5 / 2 = 2.5 ps +52 + +# 10 Medium Timebase (MTB) Dividend +# 11 Medium Timebase (MTB) Divisor +# 1 / 8 = .125 ns +01 08 + +# 12 SDRAM Minimum Cycle Time (tCKmin) +# 0x0a = tCKmin of 1.25 ns = DDR3-1600 (800 MHz clock) +# 0x0c = tCKmin of 1.5 ns = DDR3-1333 (667 MHz clock) +# 0x0c = tCKmin of 1.5 ns = in multiples of MTB +0C + +# 13 Reserved +00 + +# 14 CAS Latencies Supported, Least Significant Byte +# 15 CAS Latencies Supported, Most Significant Byte +# Cas Latencies of 11 - 5 are supported +7E 00 + +# 16 Minimum CAS Latency Time (tAAmin) +# 0x6C = 13.5ns - DDR3-1333 +# 0x69 = 13.125 ns - DDR3-1333 +69 + +# 17 Minimum Write Recovery Time (tWRmin) +# 0x78 = tWR of 15ns - All DDR3 speed grades +78 + +# 18 Minimum RAS# to CAS# Delay Time (tRCDmin) +# 0x6E = 13.5ns - DDR3-1333 +# 0x69 = 13.125 ns - DDR3-1333 +69 + +# 19 Minimum Row Active to Row Active Delay Time (tRRDmin) +# 0x30 = 6ns +# 0x38 = 7.0ns +# 0x3C = 7.5ns +30 + +# 20 Minimum Row Precharge Delay Time (tRPmin) +# 0x6C = 13.5ns - +# 0x69 = 13.125 ns - DDR3-1333 +69 + +# 21 Upper Nibbles for tRAS and tRC +# bits[3:0]: tRAS most significant nibble = 1 (see byte 22) +# bits[7:4]: tRC most significant nibble = 1 (see byte 23) +11 + +# 22 Minimum Active to Precharge Delay Time (tRASmin), LSB +# 0x120 = 36ns - DDR3-1333 (see byte 21) +# 0x120 = 36ns - DDR3 +20 + +# 23 Minimum Active to Active/Refresh Delay Time (tRCmin), LSB +# 0x28C = 49.5ns - DDR3-1333 +# 0x289 = 49.125ns - DDR3-1333 +89 + +# 24 Minimum Refresh Recovery Delay Time (tRFCmin), LSB +# 25 Minimum Refresh Recovery Delay Time (tRFCmin), MSB +# 0x500 = 160ns - for 2 Gigabit chips +# 0x820 = 260ns - for 4 Gigabit chips +20 08 + +# 26 Minimum Internal Write to Read Command Delay Time (tWTRmin) +# 0x3c = 7.5 ns - All DDR3 SDRAM speed bins +3C + +# 27 Minimum Internal Read to Precharge Command Delay Time (tRTPmin) +# 0x3c = 7.5ns - All DDR3 SDRAM speed bins +3C + +# 28 Upper Nibble for tFAWmin +# 29 Minimum Four Activate Window Delay Time (tFAWmin) +# 0x00F0 = 30ns - DDR3-1333, 1 KB page size +00 F0 + +# 30 SDRAM Optional Feature +# bit0 : 1= RZQ/6 supported +# bit1 : 1 = RZQ/7 supported +# bits[6:2]: reserved +# bit7 : 1 = DLL Off mode supported +83 + +# 31 SDRAM Thermal and Refresh Options +# bit0 : 1 = Temp up to 95c supported +# bit1 : 0 = 85-95c uses 2x refresh rate +# bit2 : 1 = Auto Self Refresh supported +# bit3 : 0 = no on die thermal sensor +# bits[6:4]: reserved +# bit7 : 0 = partial self refresh supported +01 + +# 32 Module Thermal Sensor +# 0 = Thermal sensor not incorporated onto this assembly +00 + +# 33 SDRAM Device Type +# bits[1:0]: 0 = Signal Loading not specified +# bits[3:2]: reserved +# bits[6:4]: 0 = Die count not specified +# bit7 : 0 = Standard Monolithic DRAM Device +00 + +# 34 Fine Offset for SDRAM Minimum Cycle Time (tCKmin) +00 +# 35 Fine Offset for Minimum CAS Latency Time (tAAmin) +00 +# 36 Fine Offset for Minimum RAS# to CAS# Delay Time (tRCDmin) +00 +# 37 Fine Offset for Minimum Row Precharge Delay Time (tRPmin) +00 +# 38 Fine Offset for Minimum Active to Active/Refresh Delay (tRCmin) +00 + +# 39 40 (reserved) +00 00 + +# 41 tMAW, MAC +# 8K*tREFI / 200k +86 + +# 42 - 47 (reserved) +00 00 00 00 00 00 + +# 48 - 55 (reserved) +00 00 00 00 00 00 00 00 + +# 56 - 59 (reserved) +00 00 00 00 + +# 60 Raw Card Extension, Module Nominal Height +# bits[4:0]: 0 = <= 15mm tall +# bits[7:5]: 0 = raw card revision 0-3 +00 + +# 61 Module Maximum Thickness +# bits[3:0]: 0 = thickness front <= 1mm +# bits[7:4]: 0 = thinkness back <= 1mm +00 + +# 62 Reference Raw Card Used +# bits[4:0]: 0 = Reference Raw card A used +# bits[6:5]: 0 = revision 0 +# bit7 : 0 = Reference raw cards A through AL +# revision B4 +61 + +# 63 Address Mapping from Edge Connector to DRAM +# bit0 : 0 = standard mapping (not mirrored) +# bits[7:1]: reserved +00 + +# 64 - 71 (reserved) +00 00 00 00 00 00 00 00 + +# 72 - 79 (reserved) +00 00 00 00 00 00 00 00 + +# 80 - 87 (reserved) +00 00 00 00 00 00 00 00 + +# 88 - 95 (reserved) +00 00 00 00 00 00 00 00 + +# 96 - 103 (reserved) +00 00 00 00 00 00 00 00 + +# 104 - 111 (reserved) +00 00 00 00 00 00 00 00 + +# 112 - 116 (reserved) +00 00 00 00 00 + +# 117 - 118 Module ID: Module Manufacturers JEDEC ID Code +# 0x0001 = AMD +00 01 + +# 119 Module ID: Module Manufacturing Location - oem specified +00 + +# 120 Module ID: Module Manufacture Year in BCD +# 0x15 = 2015 +# 121 Module ID: Module Manufacture week +# 0x44 = 44th week +15 44 + +# 122 - 125: Module Serial Number +00 00 00 00 + +# 126 - 127: Cyclical Redundancy Code +67 94 + + + + diff --git a/src/mainboard/pcengines/apu2/Kconfig b/src/mainboard/pcengines/apu2/Kconfig new file mode 100644 index 0000000..5faffad --- /dev/null +++ b/src/mainboard/pcengines/apu2/Kconfig @@ -0,0 +1,56 @@ +# +# This file is part of the coreboot project. +# +# Copyright (C) 2012 Advanced Micro Devices, Inc. +# Copyright (C) 2015 Kyösti Mälkki kyosti.malkki@gmail.com +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; version 2 of the License. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# + +if BOARD_PCENGINES_APU2 + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select CPU_AMD_PI_00730F01 + select NORTHBRIDGE_AMD_PI_00730F01 + select SOUTHBRIDGE_AMD_PI_AVALON + select SUPERIO_NUVOTON_NCT5104D + select HAVE_PIRQ_TABLE + select HAVE_MP_TABLE + select HAVE_ACPI_TABLES + select BOARD_ROMSIZE_KB_8192 + select SPD_CACHE + select HUDSON_DISABLE_IMC + +config MAINBOARD_DIR + string + default pcengines/apu2 + +config MAINBOARD_PART_NUMBER + string + default "PCEngines apu2" + +config MAX_CPUS + int + default 4 + +config IRQ_SLOT_COUNT + int + default 11 + +config ONBOARD_VGA_IS_PRIMARY + bool + default y + +config HUDSON_LEGACY_FREE + bool + default y + +endif # BOARD_PCENGINES_APU2 diff --git a/src/mainboard/pcengines/apu2/Kconfig.name b/src/mainboard/pcengines/apu2/Kconfig.name new file mode 100644 index 0000000..ab19ee4 --- /dev/null +++ b/src/mainboard/pcengines/apu2/Kconfig.name @@ -0,0 +1,2 @@ +config BOARD_PCENGINES_APU2 + bool "APU2" diff --git a/src/mainboard/pcengines/apu2/Makefile.inc b/src/mainboard/pcengines/apu2/Makefile.inc new file mode 100644 index 0000000..5fae195 --- /dev/null +++ b/src/mainboard/pcengines/apu2/Makefile.inc @@ -0,0 +1,40 @@ +# +# This file is part of the coreboot project. +# +# Copyright (C) 2012 Advanced Micro Devices, Inc. +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; version 2 of the License. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# + +romstage-y += BiosCallOuts.c +romstage-y += OemCustomize.c + +ramstage-y += BiosCallOuts.c +ramstage-y += OemCustomize.c + +## DIMM SPD for on-board memory +SPD_BIN = $(obj)/spd.bin + +# Order of names in SPD_SOURCES is important! +SPD_SOURCES = HYNIX-2G-1333 HYNIX-4G-1333-ECC + +SPD_DEPS := $(foreach f, $(SPD_SOURCES), src/mainboard/$(MAINBOARDDIR)/$(f).spd.hex) + +# Include spd rom data +$(SPD_BIN): $(SPD_DEPS) + for f in $+; \ + do for c in $$(cat $$f | grep -v ^#); \ + do printf $$(printf '%o' 0x$$c); \ + done; \ + done > $@ + +cbfs-files-y += spd.bin +spd.bin-file := $(SPD_BIN) +spd.bin-type := spd diff --git a/src/mainboard/pcengines/apu2/OemCustomize.c b/src/mainboard/pcengines/apu2/OemCustomize.c new file mode 100644 index 0000000..06a8f3d --- /dev/null +++ b/src/mainboard/pcengines/apu2/OemCustomize.c @@ -0,0 +1,121 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2012 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <northbridge/amd/pi/agesawrapper.h> + +#define FILECODE PROC_GNB_PCIE_FAMILY_0X15_F15PCIECOMPLEXCONFIG_FILECODE + +static const PCIe_PORT_DESCRIPTOR PortList [] = { + { + 0, + PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 3, 3), + PCIE_PORT_DATA_INITIALIZER_V2 (PortEnabled, ChannelTypeExt6db, 2, 5, + HotplugDisabled, + PcieGenMaxSupported, + PcieGenMaxSupported, + AspmDisabled, 0x01, 0) + }, + /* Initialize Port descriptor (PCIe port, Lanes 1, PCI Device Number 2, ...) */ + { + 0, + PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 2, 2), + PCIE_PORT_DATA_INITIALIZER_V2 (PortEnabled, ChannelTypeExt6db, 2, 4, + HotplugDisabled, + PcieGenMaxSupported, + PcieGenMaxSupported, + AspmDisabled, 0x02, 0) + }, + /* Initialize Port descriptor (PCIe port, Lanes 2, PCI Device Number 2, ...) */ + { + 0, + PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 1, 1), + PCIE_PORT_DATA_INITIALIZER_V2 (PortEnabled, ChannelTypeExt6db, 2, 3, + HotplugDisabled, + PcieGenMaxSupported, + PcieGenMaxSupported, + AspmDisabled, 0x03, 0) + }, + /* Initialize Port descriptor (PCIe port, Lanes 3, PCI Device Number 2, ...) */ + { + 0, + PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 0, 0), + PCIE_PORT_DATA_INITIALIZER_V2 (PortEnabled, ChannelTypeExt6db, 2, 2, + HotplugDisabled, + PcieGenMaxSupported, + PcieGenMaxSupported, + AspmDisabled, 0x04, 0) + }, + /* Initialize Port descriptor (PCIe port, Lanes 4-7, PCI Device Number 4, ...) */ + { + DESCRIPTOR_TERMINATE_LIST, + PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 4, 7), + PCIE_PORT_DATA_INITIALIZER_V2 (PortEnabled, ChannelTypeExt6db, 2, 1, + HotplugDisabled, + PcieGenMaxSupported, + PcieGenMaxSupported, + AspmDisabled, 0x05, 0) + } +}; + +static const PCIe_DDI_DESCRIPTOR DdiList [] = { + /* DP0 to HDMI0/DP */ + { + 0, + PCIE_ENGINE_DATA_INITIALIZER (PcieDdiEngine, 8, 11), + PCIE_DDI_DATA_INITIALIZER (ConnectorTypeDP, Aux1, Hdp1) + }, + /* DP1 to FCH */ + { + 0, + PCIE_ENGINE_DATA_INITIALIZER (PcieDdiEngine, 12, 15), + PCIE_DDI_DATA_INITIALIZER (ConnectorTypeDP, Aux2, Hdp2) + }, + /* DP2 to HDMI1/DP */ + { + DESCRIPTOR_TERMINATE_LIST, + PCIE_ENGINE_DATA_INITIALIZER (PcieDdiEngine, 16, 19), + PCIE_DDI_DATA_INITIALIZER (ConnectorTypeCrt, Aux3, Hdp3) + }, +}; + +static const PCIe_COMPLEX_DESCRIPTOR PcieComplex = { + .Flags = DESCRIPTOR_TERMINATE_LIST, + .SocketId = 0, + .PciePortList = PortList, + .DdiLinkList = DdiList +}; + +/*---------------------------------------------------------------------------------------*/ +/** + * OemCustomizeInitEarly + * + * Description: + * This stub function will call the host environment through the binary block + * interface (call-out port) to provide a user hook opportunity + * + * Parameters: + * @param[in] *InitEarly + * + * @retval VOID + * + **/ +/*---------------------------------------------------------------------------------------*/ +VOID +OemCustomizeInitEarly ( + IN OUT AMD_EARLY_PARAMS *InitEarly + ) +{ + InitEarly->GnbConfig.PcieComplexList = &PcieComplex; +} diff --git a/src/mainboard/pcengines/apu2/acpi/AmdImc.asl b/src/mainboard/pcengines/apu2/acpi/AmdImc.asl new file mode 100644 index 0000000..d3bb74e --- /dev/null +++ b/src/mainboard/pcengines/apu2/acpi/AmdImc.asl @@ -0,0 +1,109 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2012 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +OperationRegion(IMIO, SystemIO, 0x3E, 0x02) +Field(IMIO , ByteAcc, NoLock, Preserve) { + IMCX,8, + IMCA,8 +} + +IndexField(IMCX, IMCA, ByteAcc, NoLock, Preserve) { + Offset(0x80), + MSTI, 8, + MITS, 8, + MRG0, 8, + MRG1, 8, + MRG2, 8, + MRG3, 8, +} + +Method(WACK, 0) +{ + Store(0, Local0) + While (LNotEqual(Local0, 0xFA)) { + Store(MRG0, Local0) + Sleep(10) + } +} + +//Init +Method (ITZE, 0) +{ + Store(0, MRG0) + Store(0xB5, MRG1) + Store(0, MRG2) + Store(0x96, MSTI) + WACK() + + Store(0, MRG0) + Store(0, MRG1) + Store(0, MRG2) + Store(0x80, MSTI) + WACK() + + Or(MRG2, 0x01, Local0) + + Store(0, MRG0) + Store(0, MRG1) + Store(Local0, MRG2) + Store(0x81, MSTI) + WACK() +} + +//Sleep +Method (IMSP, 0) +{ + Store(0, MRG0) + Store(0xB5, MRG1) + Store(0, MRG2) + Store(0x96, MSTI) + WACK() + + Store(0, MRG0) + Store(1, MRG1) + Store(0, MRG2) + Store(0x98, MSTI) + WACK() + + Store(0, MRG0) + Store(0xB4, MRG1) + Store(0, MRG2) + Store(0x96, MSTI) + WACK() +} + +//Wake +Method (IMWK, 0) +{ + Store(0, MRG0) + Store(0xB5, MRG1) + Store(0, MRG2) + Store(0x96, MSTI) + WACK() + + Store(0, MRG0) + Store(0, MRG1) + Store(0, MRG2) + Store(0x80, MSTI) + WACK() + + Or(MRG2, 0x01, Local0) + + Store(0, MRG0) + Store(0, MRG1) + Store(Local0, MRG2) + Store(0x81, MSTI) + WACK() +} diff --git a/src/mainboard/pcengines/apu2/acpi/gpe.asl b/src/mainboard/pcengines/apu2/acpi/gpe.asl new file mode 100644 index 0000000..cd366dc --- /dev/null +++ b/src/mainboard/pcengines/apu2/acpi/gpe.asl @@ -0,0 +1,67 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2013 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +Scope(_GPE) { /* Start Scope GPE */ + + /* General event 3 */ + Method(_L03) { + /* DBGO("\_GPE\_L00\n") */ + Notify(_SB.PWRB, 0x02) /* NOTIFY_DEVICE_WAKE */ + } + + /* Legacy PM event */ + Method(_L08) { + /* DBGO("\_GPE\_L08\n") */ + } + + /* Temp warning (TWarn) event */ + Method(_L09) { + /* DBGO("\_GPE\_L09\n") */ + /* Notify (_TZ.TZ00, 0x80) */ + } + + /* USB controller PME# */ + Method(_L0B) { + /* DBGO("\_GPE\_L0B\n") */ + Notify(_SB.PCI0.UOH1, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify(_SB.PCI0.UOH2, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify(_SB.PCI0.UOH3, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify(_SB.PCI0.UOH4, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify(_SB.PCI0.UOH5, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify(_SB.PCI0.UOH6, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify(_SB.PCI0.XHC0, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify(_SB.PWRB, 0x02) /* NOTIFY_DEVICE_WAKE */ + } + + /* ExtEvent0 SCI event */ + Method(_L10) { + /* DBGO("\_GPE\_L10\n") */ + } + + /* ExtEvent1 SCI event */ + Method(_L11) { + /* DBGO("\_GPE\_L11\n") */ + } + + /* GPIO0 or GEvent8 event */ + Method(_L18) { + /* DBGO("\_GPE\_L18\n") */ + Notify(_SB.PCI0.PBR4, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify(_SB.PCI0.PBR5, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify(_SB.PCI0.PBR6, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify(_SB.PCI0.PBR7, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify(_SB.PWRB, 0x02) /* NOTIFY_DEVICE_WAKE */ + } +} /* End Scope GPE */ diff --git a/src/mainboard/pcengines/apu2/acpi/ide.asl b/src/mainboard/pcengines/apu2/acpi/ide.asl new file mode 100644 index 0000000..4a3eac8 --- /dev/null +++ b/src/mainboard/pcengines/apu2/acpi/ide.asl @@ -0,0 +1,2 @@ +/* No license required */ +/* No IDE functionality */ diff --git a/src/mainboard/pcengines/apu2/acpi/mainboard.asl b/src/mainboard/pcengines/apu2/acpi/mainboard.asl new file mode 100644 index 0000000..0141481 --- /dev/null +++ b/src/mainboard/pcengines/apu2/acpi/mainboard.asl @@ -0,0 +1,37 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2013 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +/* Memory related values */ +Name(LOMH, 0x0) /* Start of unused memory in C0000-E0000 range */ +Name(PBAD, 0x0) /* Address of BIOS area (If TOM2 != 0, Addr >> 16) */ +Name(PBLN, 0x0) /* Length of BIOS area */ + +Name(PCBA, CONFIG_MMCONF_BASE_ADDRESS) /* Base address of PCIe config space */ +Name(PCLN, Multiply(0x100000, CONFIG_MMCONF_BUS_NUMBER)) /* Length of PCIe config space, 1MB each bus */ +Name(HPBA, 0xFED00000) /* Base address of HPET table */ + +Name(SSFG, 0x0D) /* S1 support: bit 0, S2 Support: bit 1, etc. S0 & S5 assumed */ + +/* Some global data */ +Name(OSVR, 3) /* Assume nothing. WinXp = 1, Vista = 2, Linux = 3, WinCE = 4 */ +Name(OSV, Ones) /* Assume nothing */ +Name(PMOD, One) /* Assume APIC */ + +/* AcpiGpe0Blk */ +OperationRegion(GP0B, SystemMemory, 0xfed80814, 0x04) + Field(GP0B, ByteAcc, NoLock, Preserve) { + , 11, + USBS, 1, +} diff --git a/src/mainboard/pcengines/apu2/acpi/routing.asl b/src/mainboard/pcengines/apu2/acpi/routing.asl new file mode 100644 index 0000000..7cb7a2f --- /dev/null +++ b/src/mainboard/pcengines/apu2/acpi/routing.asl @@ -0,0 +1,193 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2013 Advanced Micro Devices, Inc. + * Copyright (C) 2013 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +/* +DefinitionBlock ("DSDT.AML","DSDT",0x01,"XXXXXX","XXXXXXXX",0x00010001 + ) + { + #include "routing.asl" + } +*/ + +/* Routing is in System Bus scope */ +Name(PR0, Package(){ + /* NB devices */ + /* Bus 0, Dev 0 - F16 Host Controller */ + + /* Bus 0, Dev 1 - PCI Bridge for Internal Graphics(IGP) */ + /* Bus 0, Dev 1, Func 1 - HDMI Audio Controller */ + Package(){0x0001FFFF, 0, INTB, 0 }, + Package(){0x0001FFFF, 1, INTC, 0 }, + + + /* Bus 0, Dev 2 Func 0,1,2,3,4,5 - PCIe Bridges */ + Package(){0x0002FFFF, 0, INTC, 0 }, + Package(){0x0002FFFF, 1, INTD, 0 }, + Package(){0x0002FFFF, 2, INTA, 0 }, + Package(){0x0002FFFF, 3, INTB, 0 }, + + /* FCH devices */ + /* Bus 0, Dev 20 - F0:SMBus/ACPI,F2:HDAudio;F3:LPC;F7:SD */ + Package(){0x0014FFFF, 0, INTA, 0 }, + Package(){0x0014FFFF, 1, INTB, 0 }, + Package(){0x0014FFFF, 2, INTC, 0 }, + Package(){0x0014FFFF, 3, INTD, 0 }, + + /* Bus 0, Dev 18, 19, 22 Func 0 - USB: OHCI */ + /* Bus 0, Dev 18, 19, 22 Func 1 - USB: EHCI */ + Package(){0x0012FFFF, 0, INTC, 0 }, + Package(){0x0012FFFF, 1, INTB, 0 }, + + Package(){0x0013FFFF, 0, INTC, 0 }, + Package(){0x0013FFFF, 1, INTB, 0 }, + + Package(){0x0016FFFF, 0, INTC, 0 }, + Package(){0x0016FFFF, 1, INTB, 0 }, + + /* Bus 0, Dev 10 - USB: XHCI func 0, 1 */ + Package(){0x0010FFFF, 0, INTC, 0 }, + Package(){0x0010FFFF, 1, INTB, 0 }, + + /* Bus 0, Dev 17 - SATA controller */ + Package(){0x0011FFFF, 0, INTD, 0 }, + +}) + +Name(APR0, Package(){ + /* NB devices in APIC mode */ + /* Bus 0, Dev 0 - F15 Host Controller */ + + /* Bus 0, Dev 1 - PCI Bridge for Internal Graphics(IGP) */ + Package(){0x0001FFFF, 0, 0, 44 }, + Package(){0x0001FFFF, 1, 0, 45 }, + + /* Bus 0, Dev 2 - PCIe Bridges */ + Package(){0x0002FFFF, 0, 0, 24 }, + Package(){0x0002FFFF, 1, 0, 25 }, + Package(){0x0002FFFF, 2, 0, 26 }, + Package(){0x0002FFFF, 3, 0, 27 }, + + + /* SB devices in APIC mode */ + /* Bus 0, Dev 20 - F0:SMBus/ACPI,F2:HDAudio;F3:LPC;F7:SD */ + Package(){0x0014FFFF, 0, 0, 16 }, + Package(){0x0014FFFF, 1, 0, 17 }, + Package(){0x0014FFFF, 2, 0, 18 }, + Package(){0x0014FFFF, 3, 0, 19 }, + + /* Bus 0, Dev 18, 19, 22 Func 0 - USB: OHCI */ + /* Bus 0, Dev 18, 19, 22 Func 1 - USB: EHCI */ + Package(){0x0012FFFF, 0, 0, 18 }, + Package(){0x0012FFFF, 1, 0, 17 }, + + Package(){0x0013FFFF, 0, 0, 18 }, + Package(){0x0013FFFF, 1, 0, 17 }, + + Package(){0x0016FFFF, 0, 0, 18 }, + Package(){0x0016FFFF, 1, 0, 17 }, + + /* Bus 0, Dev 10 - USB: XHCI func 0, 1 */ + Package(){0x0010FFFF, 0, 0, 0x12}, + Package(){0x0010FFFF, 1, 0, 0x11}, + + /* Bus 0, Dev 17 - SATA controller */ + Package(){0x0011FFFF, 0, 0, 19 }, + +}) + +Name(PS2, Package(){ + Package(){0x0000FFFF, 0, INTC, 0 }, + Package(){0x0000FFFF, 1, INTD, 0 }, + Package(){0x0000FFFF, 2, INTA, 0 }, + Package(){0x0000FFFF, 3, INTB, 0 }, +}) +Name(APS2, Package(){ + Package(){0x0000FFFF, 0, 0, 18 }, + Package(){0x0000FFFF, 1, 0, 19 }, + Package(){0x0000FFFF, 2, 0, 16 }, + Package(){0x0000FFFF, 3, 0, 17 }, +}) + +/* GFX */ +Name(PS4, Package(){ + Package(){0x0000FFFF, 0, INTA, 0 }, + Package(){0x0000FFFF, 1, INTB, 0 }, + Package(){0x0000FFFF, 2, INTC, 0 }, + Package(){0x0000FFFF, 3, INTD, 0 }, +}) +Name(APS4, Package(){ + /* PCIe slot - Hooked to PCIe slot 4 */ + Package(){0x0000FFFF, 0, 0, 24 }, + Package(){0x0000FFFF, 1, 0, 25 }, + Package(){0x0000FFFF, 2, 0, 26 }, + Package(){0x0000FFFF, 3, 0, 27 }, +}) + +/* GPP 0 */ +Name(PS5, Package(){ + Package(){0x0000FFFF, 0, INTB, 0 }, + Package(){0x0000FFFF, 1, INTC, 0 }, + Package(){0x0000FFFF, 2, INTD, 0 }, + Package(){0x0000FFFF, 3, INTA, 0 }, +}) +Name(APS5, Package(){ + Package(){0x0000FFFF, 0, 0, 28 }, + Package(){0x0000FFFF, 1, 0, 29 }, + Package(){0x0000FFFF, 2, 0, 30 }, + Package(){0x0000FFFF, 3, 0, 31 }, +}) + +/* GPP 1 */ +Name(PS6, Package(){ + Package(){0x0000FFFF, 0, INTC, 0 }, + Package(){0x0000FFFF, 1, INTD, 0 }, + Package(){0x0000FFFF, 2, INTA, 0 }, + Package(){0x0000FFFF, 3, INTB, 0 }, +}) +Name(APS6, Package(){ + Package(){0x0000FFFF, 0, 0, 32 }, + Package(){0x0000FFFF, 1, 0, 33 }, + Package(){0x0000FFFF, 2, 0, 34 }, + Package(){0x0000FFFF, 3, 0, 35 }, +}) + +/* GPP 2 */ +Name(PS7, Package(){ + Package(){0x0000FFFF, 0, INTD, 0 }, + Package(){0x0000FFFF, 1, INTA, 0 }, + Package(){0x0000FFFF, 2, INTB, 0 }, + Package(){0x0000FFFF, 3, INTC, 0 }, +}) +Name(APS7, Package(){ + Package(){0x0000FFFF, 0, 0, 36 }, + Package(){0x0000FFFF, 1, 0, 37 }, + Package(){0x0000FFFF, 2, 0, 38 }, + Package(){0x0000FFFF, 3, 0, 39 }, +}) + +/* GPP 3 */ +Name(PS8, Package(){ + Package(){0x0000FFFF, 0, INTA, 0 }, + Package(){0x0000FFFF, 1, INTB, 0 }, + Package(){0x0000FFFF, 2, INTC, 0 }, + Package(){0x0000FFFF, 3, INTD, 0 }, +}) +Name(APS8, Package(){ + Package(){0x0000FFFF, 0, 0, 40 }, + Package(){0x0000FFFF, 1, 0, 41 }, + Package(){0x0000FFFF, 2, 0, 42 }, + Package(){0x0000FFFF, 3, 0, 43 }, +}) diff --git a/src/mainboard/pcengines/apu2/acpi/si.asl b/src/mainboard/pcengines/apu2/acpi/si.asl new file mode 100644 index 0000000..2923471 --- /dev/null +++ b/src/mainboard/pcengines/apu2/acpi/si.asl @@ -0,0 +1,23 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2013 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +Scope(_SI) { + Method(_SST, 1) { + /* DBGO("\_SI\_SST\n") */ + /* DBGO(" New Indicator state: ") */ + /* DBGO(Arg0) */ + /* DBGO("\n") */ + } +} /* End Scope SI */ diff --git a/src/mainboard/pcengines/apu2/acpi/sleep.asl b/src/mainboard/pcengines/apu2/acpi/sleep.asl new file mode 100644 index 0000000..0734c8e --- /dev/null +++ b/src/mainboard/pcengines/apu2/acpi/sleep.asl @@ -0,0 +1,95 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2013 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +/* Wake status package */ +Name(WKST,Package(){Zero, Zero}) + +/* +* _PTS - Prepare to Sleep method +* +* Entry: +* Arg0=The value of the sleeping state S1=1, S2=2, etc +* +* Exit: +* -none- +* +* The _PTS control method is executed at the beginning of the sleep process +* for S1-S5. The sleeping value is passed to the _PTS control method. This +* control method may be executed a relatively long time before entering the +* sleep state and the OS may abort the operation without notification to +* the ACPI driver. This method cannot modify the configuration or power +* state of any device in the system. +*/ + +External(_SB.APTS, MethodObj) +External(_SB.AWAK, MethodObj) + +Method(_PTS, 1) { + /* DBGO("\_PTS\n") */ + /* DBGO("From S0 to S") */ + /* DBGO(Arg0) */ + /* DBGO("\n") */ + + /* Clear wake status structure. */ + Store(0, Index(WKST,0)) + Store(0, Index(WKST,1)) + Store(7, UPWS) + _SB.APTS(Arg0) +} /* End Method(_PTS) */ + +/* +* _BFS OEM Back From Sleep method +* +* Entry: +* Arg0=The value of the sleeping state S1=1, S2=2 +* +* Exit: +* -none- +*/ +Method(_BFS, 1) { + /* DBGO("\_BFS\n") */ + /* DBGO("From S") */ + /* DBGO(Arg0) */ + /* DBGO(" to S0\n") */ +} + +/* +* _WAK System Wake method +* +* Entry: +* Arg0=The value of the sleeping state S1=1, S2=2 +* +* Exit: +* Return package of 2 DWords +* Dword 1 - Status +* 0x00000000 wake succeeded +* 0x00000001 Wake was signaled but failed due to lack of power +* 0x00000002 Wake was signaled but failed due to thermal condition +* Dword 2 - Power Supply state +* if non-zero the effective S-state the power supply entered +*/ +Method(_WAK, 1) { + /* DBGO("\_WAK\n") */ + /* DBGO("From S") */ + /* DBGO(Arg0) */ + /* DBGO(" to S0\n") */ + + /* clear USB wake up signal */ + Store(1, USBS) + + _SB.AWAK(Arg0) + + Return(WKST) +} /* End Method(_WAK) */ diff --git a/src/mainboard/pcengines/apu2/acpi/thermal.asl b/src/mainboard/pcengines/apu2/acpi/thermal.asl new file mode 100644 index 0000000..73077ac --- /dev/null +++ b/src/mainboard/pcengines/apu2/acpi/thermal.asl @@ -0,0 +1,2 @@ +/* No license required */ +/* No thermal zone functionality */ diff --git a/src/mainboard/pcengines/apu2/acpi/usb_oc.asl b/src/mainboard/pcengines/apu2/acpi/usb_oc.asl new file mode 100644 index 0000000..1643fe7 --- /dev/null +++ b/src/mainboard/pcengines/apu2/acpi/usb_oc.asl @@ -0,0 +1,36 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2012 Advanced Micro Devices, Inc. + * Copyright (C) 2013 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +/* simple name description */ +/* +DefinitionBlock ("DSDT.AML","DSDT",0x01,"XXXXXX","XXXXXXXX",0x00010001 + ) + { + #include "usb.asl" + } +*/ + +/* USB overcurrent mapping pins. */ +Name(UOM0, 0) +Name(UOM1, 2) +Name(UOM2, 0) +Name(UOM3, 7) +Name(UOM4, 2) +Name(UOM5, 2) +Name(UOM6, 6) +Name(UOM7, 2) +Name(UOM8, 6) +Name(UOM9, 6) diff --git a/src/mainboard/pcengines/apu2/acpi_tables.c b/src/mainboard/pcengines/apu2/acpi_tables.c new file mode 100644 index 0000000..d5ebad4 --- /dev/null +++ b/src/mainboard/pcengines/apu2/acpi_tables.c @@ -0,0 +1,56 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2012 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <northbridge/amd/pi/agesawrapper.h> + +#include <console/console.h> +#include <string.h> +#include <arch/acpi.h> +#include <arch/acpigen.h> +#include <arch/ioapic.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include <cpu/x86/msr.h> +#include <cpu/amd/mtrr.h> +#include <cpu/amd/amdfam16.h> + +unsigned long acpi_fill_madt(unsigned long current) +{ + /* create all subtables for processors */ + current = acpi_create_madt_lapics(current); + + /* Write SB800 IOAPIC, only one */ + current += acpi_create_madt_ioapic((acpi_madt_ioapic_t *) current, CONFIG_MAX_CPUS, + IO_APIC_ADDR, 0); + + /* TODO: Remove the hardcode */ + current += acpi_create_madt_ioapic((acpi_madt_ioapic_t *) current, CONFIG_MAX_CPUS+1, + 0xFEC20000, 24); + + current += acpi_create_madt_irqoverride((acpi_madt_irqoverride_t *) + current, 0, 0, 2, 0); + current += acpi_create_madt_irqoverride((acpi_madt_irqoverride_t *) + current, 0, 9, 9, 0xF); + /* 0: mean bus 0--->ISA */ + /* 0: PIC 0 */ + /* 2: APIC 2 */ + /* 5 mean: 0101 --> Edge-triggered, Active high */ + + /* create all subtables for processors */ + current += acpi_create_madt_lapic_nmi((acpi_madt_lapic_nmi_t *)current, 0xff, 5, 1); + /* 1: LINT1 connect to NMI */ + + return current; +} diff --git a/src/mainboard/pcengines/apu2/apu2.h b/src/mainboard/pcengines/apu2/apu2.h new file mode 100644 index 0000000..e94a7ac --- /dev/null +++ b/src/mainboard/pcengines/apu2/apu2.h @@ -0,0 +1,58 @@ +/* + * This file is part of the coreboot project. + + * + * Copyright (C) 2015 Eltan B.V. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <agesawrapper.h> + +#define APU2_SPD_STRAP0_GPIO 0x40 // GPIO49 +#define APU2_SPD_STRAP0_FUNC Function2 +#define APU2_SPD_STRAP1_GPIO 0x41 // GPIO50 +#define APU2_SPD_STRAP1_FUNC Function2 +#define APU2_PE3_RST_L_GPIO 0x42 // GPIO51 +#define APU2_PE3_RST_L_FUNC Function2 +#define APU2_PE4_RST_L_GPIO 0x43 // DEVSLP[0]/GPIO59 +#define APU2_PE4_RST_L_FUNC Function3 +#define APU2_LED1_L_GPIO 0x44 // GPIO57 +#define APU2_LED1_L_FUNC Function1 +#define APU2_LED2_L_GPIO 0x45 // GPIO58 +#define APU2_LED2_L_FUNC Function1 +#define APU2_LED3_L_GPIO 0x46 // DEVSLP[1]/GPIO59 +#define APU2_LED3_L_FUNC Function3 +#define APU2_PE3_WDIS_L_GPIO 0x47 // GPIO64 +#define APU2_PE3_WDIS_L_FUNC Function2 +#define APU2_PE4_WDIS_L_GPIO 0x48 // GPIO68 +#define APU2_PE4_WDIS_L_FUNC Function0 +#define APU2_SKR_GPIO 0x5B // SPKR/GPIO66 +#define APU2_SKR_FUNC Function0 +#define APU2_PROCHOT_GPIO 0x4D // GPIO71 +#define APU2_PROCHOT_FUNC Function0 +#define APU2_BIOS_CONSOLE_GPIO 0x59 // GENINT1_L/GPIO32 +#define APU2_BIOS_CONSOLE_FUNC Function0 + + + + + + + + + + + + diff --git a/src/mainboard/pcengines/apu2/board_info.txt b/src/mainboard/pcengines/apu2/board_info.txt new file mode 100644 index 0000000..a69e616 --- /dev/null +++ b/src/mainboard/pcengines/apu2/board_info.txt @@ -0,0 +1,6 @@ +Board name: PC Engines APU2 +Board URL: http://www.pcengines.ch/apu2c2.htm +Category: half +ROM protocol: SPI +ROM socketed: n +Flashrom support: y diff --git a/src/mainboard/pcengines/apu2/cmos.layout b/src/mainboard/pcengines/apu2/cmos.layout new file mode 100644 index 0000000..d83bb14 --- /dev/null +++ b/src/mainboard/pcengines/apu2/cmos.layout @@ -0,0 +1,74 @@ +#***************************************************************************** +# +# This file is part of the coreboot project. +# +# Copyright (C) 2012 Advanced Micro Devices, Inc. +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; version 2 of the License. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +#***************************************************************************** + +entries + +0 384 r 0 reserved_memory +384 1 e 4 boot_option +388 4 r 0 reboot_bits +392 3 e 5 baud_rate +395 1 e 1 hw_scrubber +396 1 e 1 interleave_chip_selects +397 2 e 8 max_mem_clock +399 1 e 2 multi_core +400 1 e 1 power_on_after_fail +412 4 e 6 debug_level +440 4 e 9 slow_cpu +444 1 e 1 nmi +445 1 e 1 iommu +456 1 e 1 ECC_memory +728 256 h 0 user_data +984 16 h 0 check_sum +# Reserve the extended AMD configuration registers +1000 24 r 0 amd_reserved + +enumerations + +#ID value text +1 0 Disable +1 1 Enable +2 0 Enable +2 1 Disable +4 0 Fallback +4 1 Normal +5 0 115200 +5 1 57600 +5 2 38400 +5 3 19200 +5 4 9600 +5 5 4800 +5 6 2400 +5 7 1200 +6 6 Notice +6 7 Info +6 8 Debug +6 9 Spew +8 0 400Mhz +8 1 333Mhz +8 2 266Mhz +8 3 200Mhz +9 0 off +9 1 87.5% +9 2 75.0% +9 3 62.5% +9 4 50.0% +9 5 37.5% +9 6 25.0% +9 7 12.5% + +checksums + +checksum 392 983 984 diff --git a/src/mainboard/pcengines/apu2/devicetree.cb b/src/mainboard/pcengines/apu2/devicetree.cb new file mode 100644 index 0000000..e815a6c --- /dev/null +++ b/src/mainboard/pcengines/apu2/devicetree.cb @@ -0,0 +1,91 @@ +# +# This file is part of the coreboot project. +# +# Copyright (C) 2013 Advanced Micro Devices, Inc. +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; version 2 of the License. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +chip northbridge/amd/pi/00730F01/root_complex + device cpu_cluster 0 on + chip cpu/amd/pi/00730F01 + device lapic 0 on end + end + end + + device domain 0 on + subsystemid 0x1022 0x1410 inherit + chip northbridge/amd/pi/00730F01 # CPU side of HT root complex + + chip northbridge/amd/pi/00730F01 # PCI side of HT root complex + device pci 0.0 on end # Root Complex + device pci 0.2 off end # IOMMU + device pci 1.0 off end # Internal Graphics P2P bridge 0x9804 + device pci 1.1 off end # Internal Multimedia + device pci 2.0 on end # PCIe Host Bridge + device pci 2.1 on end # mPCIe slot 2 (on GFX lane) + device pci 2.2 on end # LAN3 + device pci 2.3 on end # LAN2 + device pci 2.4 on end # LAN1 + device pci 2.5 on end # mPCIe slot 1 + device pci 8.0 on end # Platform Security Processor + end #chip northbridge/amd/pi/00730F01 + + chip southbridge/amd/pi/hudson # it is under NB/SB Link, but on the same pci bus + device pci 10.0 on end # XHCI HC0 muxed with EHCI 2 + device pci 11.0 on end # SATA + device pci 12.0 off end # USB EHCI0 usb[0:3] not connected + device pci 13.0 on end # USB EHCI1 usb[4:7] + device pci 14.0 on end # SM + device pci 14.3 on # LPC 0x439d + chip superio/nuvoton/nct5104d # SIO NCT5104D + register "irq_trigger_type" = "0" + device pnp 2e.0 off end + device pnp 2e.2 on + io 0x60 = 0x3f8 + irq 0x70 = 4 + end + device pnp 2e.3 on + io 0x60 = 0x2f8 + irq 0x70 = 3 + end + device pnp 2e.10 on + # UART C is conditionally turned on + io 0x60 = 0x3e8 + irq 0x70 = 4 + end + device pnp 2e.11 on + # UART D is conditionally turned on + io 0x60 = 0x2e8 + irq 0x70 = 3 + end + device pnp 2e.8 off end + device pnp 2e.f off end + # GPIO0 and GPIO1 are conditionally turned on + device pnp 2e.007 on end + device pnp 2e.107 on end + device pnp 2e.607 off end + device pnp 2e.e off end + end # SIO NCT5104D + end # LPC 0x439d + + device pci 14.7 on end # SD + device pci 16.0 on end # USB EHCI2 usb[8:7] - muxed with XHCI + end #chip southbridge/amd/pi/hudson + + device pci 18.0 on end + device pci 18.1 on end + device pci 18.2 on end + device pci 18.3 on end + device pci 18.4 on end + device pci 18.5 on end + + end #chip northbridge/amd/pi/00730F01 # CPU side of HT root complex + end #domain +end #northbridge/amd/pi/00730F01/root_complex diff --git a/src/mainboard/pcengines/apu2/dsdt.asl b/src/mainboard/pcengines/apu2/dsdt.asl new file mode 100644 index 0000000..45ae428 --- /dev/null +++ b/src/mainboard/pcengines/apu2/dsdt.asl @@ -0,0 +1,87 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2013 Advanced Micro Devices, Inc. + * Copyright (C) 2013 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +/* DefinitionBlock Statement */ +DefinitionBlock ( + "DSDT.AML", /* Output filename */ + "DSDT", /* Signature */ + 0x02, /* DSDT Revision, needs to be 2 for 64bit */ + "AMD ", /* OEMID */ + "COREBOOT", /* TABLE ID */ + 0x00010001 /* OEM Revision */ + ) +{ /* Start of ASL file */ + /* #include <arch/x86/acpi/debug.asl> */ /* Include global debug methods if needed */ + + /* Globals for the platform */ + #include "acpi/mainboard.asl" + + /* Describe the USB Overcurrent pins */ + #include "acpi/usb_oc.asl" + + /* PCI IRQ mapping for the Southbridge */ + #include <southbridge/amd/pi/hudson/acpi/pcie.asl> + + /* Describe the processor tree (_PR) */ + #include <cpu/amd/pi/00730F01/acpi/cpu.asl> + + /* Contains the supported sleep states for this chipset */ + #include <southbridge/amd/pi/hudson/acpi/sleepstates.asl> + + /* Contains the Sleep methods (WAK, PTS, GTS, etc.) */ + #include "acpi/sleep.asl" + + /* System Bus */ + Scope(_SB) { /* Start _SB scope */ + /* global utility methods expected within the _SB scope */ + #include <arch/x86/acpi/globutil.asl> + + /* Describe IRQ Routing mapping for this platform (within the _SB scope) */ + #include "acpi/routing.asl" + + Device(PWRB) { + Name(_HID, EISAID("PNP0C0C")) + Name(_UID, 0xAA) + Name(_PRW, Package () {3, 0x04}) + Name(_STA, 0x0B) + } + + Device(PCI0) { + /* Describe the AMD Northbridge */ + #include <northbridge/amd/pi/00730F01/acpi/northbridge.asl> + + /* Describe the AMD Fusion Controller Hub Southbridge */ + #include <southbridge/amd/pi/hudson/acpi/fch.asl> + } + + /* Describe PCI INT[A-H] for the Southbridge */ + #include <southbridge/amd/pi/hudson/acpi/pci_int.asl> + + } /* End _SB scope */ + + /* Describe SMBUS for the Southbridge */ + #include <southbridge/amd/pi/hudson/acpi/smbus.asl> + + /* Define the General Purpose Events for the platform */ + #include "acpi/gpe.asl" + + /* Define the Thermal zones and methods for the platform */ + #include "acpi/thermal.asl" + + /* Define the System Indicators for the platform */ + #include "acpi/si.asl" +} +/* End of ASL file */ diff --git a/src/mainboard/pcengines/apu2/irq_tables.c b/src/mainboard/pcengines/apu2/irq_tables.c new file mode 100644 index 0000000..eaeed3f --- /dev/null +++ b/src/mainboard/pcengines/apu2/irq_tables.c @@ -0,0 +1,103 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2012 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <console/console.h> +#include <device/pci.h> +#include <string.h> +#include <stdint.h> +#include <arch/pirq_routing.h> +#include <cpu/amd/amdfam16.h> + +static void write_pirq_info(struct irq_info *pirq_info, u8 bus, u8 devfn, + u8 link0, u16 bitmap0, u8 link1, u16 bitmap1, + u8 link2, u16 bitmap2, u8 link3, u16 bitmap3, + u8 slot, u8 rfu) +{ + pirq_info->bus = bus; + pirq_info->devfn = devfn; + pirq_info->irq[0].link = link0; + pirq_info->irq[0].bitmap = bitmap0; + pirq_info->irq[1].link = link1; + pirq_info->irq[1].bitmap = bitmap1; + pirq_info->irq[2].link = link2; + pirq_info->irq[2].bitmap = bitmap2; + pirq_info->irq[3].link = link3; + pirq_info->irq[3].bitmap = bitmap3; + pirq_info->slot = slot; + pirq_info->rfu = rfu; +} + + +unsigned long write_pirq_routing_table(unsigned long addr) +{ + struct irq_routing_table *pirq; + struct irq_info *pirq_info; + u32 slot_num; + u8 *v; + + u8 sum = 0; + int i; + + /* Align the table to be 16 byte aligned. */ + addr += 15; + addr &= ~15; + + /* This table must be between 0xf0000 & 0x100000 */ + printk(BIOS_INFO, "Writing IRQ routing tables to 0x%lx...", addr); + + pirq = (void *)(addr); + v = (u8 *) (addr); + + pirq->signature = PIRQ_SIGNATURE; + pirq->version = PIRQ_VERSION; + + pirq->rtr_bus = 0; + pirq->rtr_devfn = PCI_DEVFN(0x14, 4); + + pirq->exclusive_irqs = 0; + + pirq->rtr_vendor = 0x1002; + pirq->rtr_device = 0x4384; + + pirq->miniport_data = 0; + + memset(pirq->rfu, 0, sizeof(pirq->rfu)); + + pirq_info = (void *)(&pirq->checksum + 1); + slot_num = 0; + + /* pci bridge */ + write_pirq_info(pirq_info, 0, PCI_DEVFN(0x14, 4), + 0x1, 0xdee8, 0x2, 0xdee8, 0x3, 0xdee8, 0x4, 0xdee8, 0, + 0); + pirq_info++; + + slot_num++; + + pirq->size = 32 + 16 * slot_num; + + for (i = 0; i < pirq->size; i++) + sum += v[i]; + + sum = pirq->checksum - sum; + + if (sum != pirq->checksum) { + pirq->checksum = sum; + } + + printk(BIOS_INFO, "write_pirq_routing_table done.\n"); + + return (unsigned long)pirq_info; +} diff --git a/src/mainboard/pcengines/apu2/mainboard.c b/src/mainboard/pcengines/apu2/mainboard.c new file mode 100644 index 0000000..1f25df2 --- /dev/null +++ b/src/mainboard/pcengines/apu2/mainboard.c @@ -0,0 +1,99 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2012 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <console/console.h> +#include <device/device.h> +#include <device/pci.h> +#include <arch/io.h> +#include <device/pci_def.h> +#include <arch/acpi.h> +#include <northbridge/amd/pi/BiosCallOuts.h> +#include <cpu/amd/pi/s3_resume.h> +#include <northbridge/amd/pi/agesawrapper.h> +#include <cpu/x86/msr.h> +#include <cpu/amd/mtrr.h> +#if CONFIG_USE_OPTION_TABLE +#include <pc80/mc146818rtc.h> +#endif //CONFIG_USE_OPTION_TABLE +#if CONFIG_HAVE_OPTION_TABLE +#include "option_table.h" +#endif //CONFIG_HAVE_OPTION_TABLE +#include <hudson.h> +#include <timestamp.h> +#include "apu2.h" +#include <superio/nuvoton/nct5104d/nct5104d.h> +#include <spd_cache.h> + +#define SPD_SIZE 128 +#define PM_RTC_CONTROL 0x56 +#define PM_S_STATE_CONTROL 0xBA + +/* Wrapper to enable GPIO/UART devices under menuconfig. Revisit + * once configuration file format for SPI flash storage is complete. + */ +#define SIO_PORT 0x2e + +static void config_gpio_mux(void) +{ + struct device *uart, *gpio; + + uart = dev_find_slot_pnp(SIO_PORT, NCT5104D_SP3); + gpio = dev_find_slot_pnp(SIO_PORT, NCT5104D_GPIO0); + if (uart) + uart->enabled = CONFIG_PINMUX_UART_C; + if (gpio) + gpio->enabled = CONFIG_PINMUX_GPIO0; + + uart = dev_find_slot_pnp(SIO_PORT, NCT5104D_SP4); + gpio = dev_find_slot_pnp(SIO_PORT, NCT5104D_GPIO1); + if (uart) + uart->enabled = CONFIG_PINMUX_UART_D; + if (gpio) + gpio->enabled = CONFIG_PINMUX_GPIO1; +} + +/********************************************** + * enable the dedicated function in mainboard. + **********************************************/ + +static void mainboard_enable(device_t dev) +{ + printk(BIOS_INFO, "Mainboard " CONFIG_MAINBOARD_PART_NUMBER " Enable.\n"); + + config_gpio_mux(); + + // + // Enable the RTC output + // + pm_write16 ( PM_RTC_CONTROL, pm_read16( PM_RTC_CONTROL ) | (1 << 11)); + + // + // Enable power on from WAKE# + // + pm_write16 ( PM_S_STATE_CONTROL, pm_read16( PM_S_STATE_CONTROL ) | (1 << 14)); + + if (acpi_is_wakeup_s3()) + agesawrapper_fchs3earlyrestore(); +} + +struct chip_operations mainboard_ops = { + .enable_dev = mainboard_enable, +}; + + diff --git a/src/mainboard/pcengines/apu2/mptable.c b/src/mainboard/pcengines/apu2/mptable.c new file mode 100644 index 0000000..fd8ef46 --- /dev/null +++ b/src/mainboard/pcengines/apu2/mptable.c @@ -0,0 +1,129 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2012 Advanced Micro Devices, Inc. + * Copyright (C) 2014 Sage Electronic Engineering, LLC. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <console/console.h> +#include <arch/smp/mpspec.h> +#include <device/pci.h> +#include <arch/io.h> +#include <arch/ioapic.h> +#include <string.h> +#include <stdint.h> +#include <cpu/amd/amdfam15.h> +#include <arch/cpu.h> +#include <cpu/x86/lapic.h> +#include <southbridge/amd/common/amd_pci_util.h> + +static void *smp_write_config_table(void *v) +{ + struct mp_config_table *mc; + int bus_isa; + + /* Intialize the MP_Table */ + mc = (void *)(((char *)v) + SMP_FLOATING_TABLE_LEN); + + mptable_init(mc, LOCAL_APIC_ADDR); + + /* + * Type 0: Processor Entries: + * LAPIC ID, LAPIC Version, CPU Flags:EN/BP, + * CPU Signature (Stepping, Model, Family), + * Feature Flags + */ + smp_write_processors(mc); + + /* + * Type 1: Bus Entries: + * Bus ID, Bus Type + */ + mptable_write_buses(mc, NULL, &bus_isa); + + /* + * Type 2: I/O APICs: + * APIC ID, Version, APIC Flags:EN, Address + */ + u8 ioapic_id = (io_apic_read(VIO_APIC_VADDR, 0x00) >> 24); + u8 ioapic_ver = (io_apic_read(VIO_APIC_VADDR, 0x01) & 0xFF); + + smp_write_ioapic(mc, ioapic_id, ioapic_ver, VIO_APIC_VADDR); + + /* I/O Ints: Type Polarity Trigger Bus ID IRQ APIC ID PIN# */ +#define IO_LOCAL_INT(type, intr, apicid, pin) \ + smp_write_lintsrc(mc, (type), MP_IRQ_TRIGGER_EDGE | MP_IRQ_POLARITY_HIGH, bus_isa, (intr), (apicid), (pin)); + + /* + * Type 3: I/O Interrupt Table Entries: + * Int Type, Int Polarity, Int Level, Source Bus ID, + * Source Bus IRQ, Dest APIC ID, Dest PIN# + */ + + mptable_add_isa_interrupts(mc, bus_isa, ioapic_id, 0); + + /* PCI interrupts are level triggered, and are + * associated with a specific bus/device/function tuple. + */ +#define PCI_INT(bus, dev, int_sign, pin) \ + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, (bus), (((dev)<<2)|(int_sign)), ioapic_id, (pin)) + + + /* SMBUS / ACPI */ + PCI_INT(0x0, 0x14, 0x0, intr_data_ptr[PIRQ_SMBUS]); + + /* SD card */ + PCI_INT(0x0, 0x14, 0x1, intr_data_ptr[PIRQ_SD]); + + /* USB */ + PCI_INT(0x0, 0x12, 0x0, intr_data_ptr[PIRQ_OHCI1]); + PCI_INT(0x0, 0x12, 0x1, intr_data_ptr[PIRQ_EHCI1]); + PCI_INT(0x0, 0x13, 0x0, intr_data_ptr[PIRQ_OHCI2]); + PCI_INT(0x0, 0x13, 0x1, intr_data_ptr[PIRQ_EHCI2]); + PCI_INT(0x0, 0x16, 0x0, intr_data_ptr[PIRQ_OHCI3]); + PCI_INT(0x0, 0x16, 0x1, intr_data_ptr[PIRQ_EHCI3]); + PCI_INT(0x0, 0x14, 0x2, intr_data_ptr[PIRQ_OHCI4]); + + /* SATA */ + PCI_INT(0x0, 0x11, 0x0, intr_data_ptr[PIRQ_SATA]); + + /* on board NIC & Slot PCIE */ + PCI_INT(0x1, 0x0, 0x0, intr_data_ptr[PIRQ_E]); + PCI_INT(0x2, 0x0, 0x0, intr_data_ptr[PIRQ_F]); + + + /* GPP0 */ + PCI_INT(0x0, 0x2, 0x0, 0x10); // Network 3 + /* GPP1 */ + PCI_INT(0x0, 0x2, 0x1, 0x11); // Network 2 + /* GPP2 */ + PCI_INT(0x0, 0x2, 0x2, 0x12); // Network 1 + /* GPP3 */ + PCI_INT(0x0, 0x2, 0x3, 0x13); // mPCI + /* GPP4 */ + PCI_INT(0x0, 0x2, 0x4, 0x14); // mPCI + + IO_LOCAL_INT(mp_ExtINT, 0x0, MP_APIC_ALL, 0x0); + IO_LOCAL_INT(mp_NMI, 0x0, MP_APIC_ALL, 0x1); + + /* There is no extension information... */ + + /* Compute the checksums */ + return mptable_finalize(mc); +} + +unsigned long write_smp_table(unsigned long addr) +{ + void *v; + v = smp_write_floating_table(addr, 0); /* ADDR, Enable Virtual Wire */ + return (unsigned long)smp_write_config_table(v); +} diff --git a/src/mainboard/pcengines/apu2/romstage.c b/src/mainboard/pcengines/apu2/romstage.c new file mode 100644 index 0000000..c64fe4e --- /dev/null +++ b/src/mainboard/pcengines/apu2/romstage.c @@ -0,0 +1,110 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2012 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <stdint.h> +#include <string.h> +#include <device/pci_def.h> +#include <device/pci_ids.h> +#include <arch/acpi.h> +#include <arch/io.h> +#include <arch/stages.h> +#include <device/pnp_def.h> +#include <arch/cpu.h> +#include <cpu/x86/lapic.h> +#include <console/console.h> +#include <commonlib/loglevel.h> +#include <cpu/amd/car.h> +#include <northbridge/amd/pi/agesawrapper.h> +#include <northbridge/amd/pi/agesawrapper_call.h> +#include <cpu/x86/bist.h> +#include <cpu/x86/lapic.h> +#include <southbridge/amd/pi/hudson/hudson.h> +#include <cpu/amd/pi/s3_resume.h> + +void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) +{ + u32 val; + + /* + * In Hudson RRG, PMIOxD2[5:4] is "Drive strength control for + * LpcClk[1:0]". This following register setting has been + * replicated in every reference design since Parmer, so it is + * believed to be required even though it is not documented in + * the SoC BKDGs. Without this setting, there is no serial + * output. + */ + outb(0xD2, 0xcd6); + outb(0x00, 0xcd7); + + amd_initmmio(); + + hudson_lpc_port80(); + + if (!cpu_init_detectedx && boot_cpu()) { + post_code(0x30); + + post_code(0x31); + console_init(); + } + + /* Halt if there was a built in self test failure */ + post_code(0x34); + report_bist_failure(bist); + + /* Load MPB */ + val = cpuid_eax(1); + printk(BIOS_DEBUG, "BSP Family_Model: %08x \n", val); + printk(BIOS_DEBUG, "cpu_init_detectedx = %08lx \n", cpu_init_detectedx); + + post_code(0x37); + AGESAWRAPPER(amdinitreset); + + post_code(0x38); + printk(BIOS_DEBUG, "Got past avalon_early_setup\n"); + + post_code(0x39); + AGESAWRAPPER(amdinitearly); + int s3resume = acpi_is_wakeup_s3(); + if (!s3resume) { + post_code(0x40); + AGESAWRAPPER(amdinitpost); + + //PspMboxBiosCmdDramInfo(); + post_code(0x41); + AGESAWRAPPER(amdinitenv); + /* + If code hangs here, please check cahaltasm.S + */ + disable_cache_as_ram(); + } else { /* S3 detect */ + printk(BIOS_INFO, "S3 detected\n"); + + post_code(0x60); + AGESAWRAPPER(amdinitresume); + + AGESAWRAPPER(amds3laterestore); + + post_code(0x61); + prepare_for_resume(); + } + + outb(0xEA, 0xCD6); + outb(0x1, 0xcd7); + + post_code(0x50); + copy_and_run(); + + post_code(0x54); /* Should never see this post code. */ +}
