Marc Jones (marc.jones@se-eng.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/7269
commit 8756bb76d6429349bd2bac114975872d25d14bfd Author: Vadim Bendebury vbendeb@chromium.org Date: Wed Apr 9 19:23:04 2014 -0700
ipq8064: Make timer code compile
Commment out nonessential timer services and modify the source code to cleanly build in coeboot environment. Do not remove dead code just yet, these functions might be necessary later.
Need to rename the soc timer.h to prevent collisions with timer.h in the top level include directory.
Currently build timer code for ramstage only.
BUG=chrome-os-partner:27784 TEST='emerge-storm coreboot' still succeeds
Original-Change-Id: Ib10133ccb42697840708845a8ea6d75ceeaeb3d5 Original-Signed-off-by: Vadim Bendebury vbendeb@chromium.org Original-Reviewed-on: https://chromium-review.googlesource.com/194067 Original-Reviewed-by: David Hendricks dhendrix@chromium.org (cherry picked from commit 987ce95220953c16216d1e1d70d5a941d05fc9bc) Signed-off-by: Marc Jones marc.jones@se-eng.com
Change-Id: Ia9cf175da11c70709354def5e51bf79df4fda2fe --- src/soc/qualcomm/ipq806x/Makefile.inc | 1 + src/soc/qualcomm/ipq806x/cbfs.c | 9 ------ src/soc/qualcomm/ipq806x/include/cdp.h | 40 +++++++++++++++++------- src/soc/qualcomm/ipq806x/include/iomap.h | 4 ++- src/soc/qualcomm/ipq806x/include/ipq_timer.h | 40 ++++++++++++++++++++++++ src/soc/qualcomm/ipq806x/include/timer.h | 40 ------------------------ src/soc/qualcomm/ipq806x/timer.c | 46 ++++++++++++---------------- 7 files changed, 93 insertions(+), 87 deletions(-)
diff --git a/src/soc/qualcomm/ipq806x/Makefile.inc b/src/soc/qualcomm/ipq806x/Makefile.inc index 002e59c..41cde31 100644 --- a/src/soc/qualcomm/ipq806x/Makefile.inc +++ b/src/soc/qualcomm/ipq806x/Makefile.inc @@ -6,6 +6,7 @@ romstage-y += gpio.c
ramstage-y += cbfs.c ramstage-y += gpio.c +ramstage-y += timer.c
ifeq ($(CONFIG_USE_BLOBS),y)
diff --git a/src/soc/qualcomm/ipq806x/cbfs.c b/src/soc/qualcomm/ipq806x/cbfs.c index eec9b73..97ae548 100644 --- a/src/soc/qualcomm/ipq806x/cbfs.c +++ b/src/soc/qualcomm/ipq806x/cbfs.c @@ -24,12 +24,3 @@ int init_default_cbfs_media(struct cbfs_media *media) { return 0; } - -/* - * Temporary change to make sure storm code still builds. Will be dropped - * shortly. - */ -#include <delay.h> /* This driver serves as a CBFS media source. */ -void init_timer(void) -{ -} diff --git a/src/soc/qualcomm/ipq806x/include/cdp.h b/src/soc/qualcomm/ipq806x/include/cdp.h index 4ae476a..22ba192 100644 --- a/src/soc/qualcomm/ipq806x/include/cdp.h +++ b/src/soc/qualcomm/ipq806x/include/cdp.h @@ -4,9 +4,23 @@ #ifndef _IPQ806X_CDP_H_ #define _IPQ806X_CDP_H_
-#include <phy.h> +unsigned smem_get_board_machtype(void);
-unsigned int smem_get_board_machtype(void); +typedef enum { + PHY_INTERFACE_MODE_MII, + PHY_INTERFACE_MODE_GMII, + PHY_INTERFACE_MODE_SGMII, + PHY_INTERFACE_MODE_QSGMII, + PHY_INTERFACE_MODE_TBI, + PHY_INTERFACE_MODE_RMII, + PHY_INTERFACE_MODE_RGMII, + PHY_INTERFACE_MODE_RGMII_ID, + PHY_INTERFACE_MODE_RGMII_RXID, + PHY_INTERFACE_MODE_RGMII_TXID, + PHY_INTERFACE_MODE_RTBI, + PHY_INTERFACE_MODE_XGMII, + PHY_INTERFACE_MODE_NONE /* Must be last */ +} phy_interface_t;
typedef struct { unsigned int gpio; @@ -73,17 +87,17 @@ typedef struct { } spinorflash_params_t;
typedef struct { - uint count; - u8 addr[7]; + unsigned count; + uint8_t addr[7]; } ipq_gmac_phy_addr_t;
typedef struct { - uint base; + unsigned base; int unit; - uint is_macsec; - uint mac_pwr0; - uint mac_pwr1; - uint mac_conn_to_phy; + unsigned is_macsec; + unsigned mac_pwr0; + unsigned mac_pwr1; + unsigned mac_conn_to_phy; phy_interface_t phy; ipq_gmac_phy_addr_t phy_addr; } ipq_gmac_board_cfg_t; @@ -98,6 +112,7 @@ typedef struct { unsigned int uart_gsbi_base; unsigned int uart_dm_base; unsigned int clk_dummy; +#if 0 uart_clk_mnd_t mnd_value; unsigned int gmac_gpio_count; gpio_func_data_t *gmac_gpio; @@ -105,10 +120,12 @@ typedef struct { flash_desc flashdesc; spinorflash_params_t flash_param; gpio_func_data_t dbg_uart_gpio[NO_OF_DBG_UART_GPIOS]; +#endif } __attribute__ ((__packed__)) board_ipq806x_params_t;
extern board_ipq806x_params_t *gboard_param;
+#if 0 static inline int gmac_cfg_is_valid(ipq_gmac_board_cfg_t *cfg) { /* @@ -121,7 +138,8 @@ static inline int gmac_cfg_is_valid(ipq_gmac_board_cfg_t *cfg) (cfg < &gboard_param->gmac_cfg[IPQ_GMAC_NMACS]) && (cfg->unit >= 0) && (cfg->unit < IPQ_GMAC_NMACS)); } +#endif
-unsigned int get_board_index(unsigned int machid); -void ipq_configure_gpio(gpio_func_data_t *gpio, uint count); +unsigned int get_board_index(unsigned machid); +void ipq_configure_gpio(gpio_func_data_t *gpio, unsigned count); #endif diff --git a/src/soc/qualcomm/ipq806x/include/iomap.h b/src/soc/qualcomm/ipq806x/include/iomap.h index 5fcfde9..8642410 100644 --- a/src/soc/qualcomm/ipq806x/include/iomap.h +++ b/src/soc/qualcomm/ipq806x/include/iomap.h @@ -43,6 +43,8 @@ */ #define readl_i(a) read32((const void *)(a)) #define writel_i(v,a) write32(v,(void *)a) +#include <arch/io.h> +#include <cdp.h>
#define MSM_CLK_CTL_BASE 0x00900000
@@ -50,7 +52,7 @@ #define MSM_GPT_BASE (MSM_TMR_BASE + 0x04) #define MSM_DGT_BASE (MSM_TMR_BASE + 0x24)
-#define GPT_REG(off) (MSM_GPT_BASE + (off)) +#define GPT_REG(off) (((uint8_t *)(MSM_GPT_BASE)) + (off)) #define DGT_REG(off) (MSM_DGT_BASE + (off))
#define APCS_WDT0_EN (MSM_TMR_BASE + 0x0040) diff --git a/src/soc/qualcomm/ipq806x/include/ipq_timer.h b/src/soc/qualcomm/ipq806x/include/ipq_timer.h new file mode 100644 index 0000000..4e1ef34 --- /dev/null +++ b/src/soc/qualcomm/ipq806x/include/ipq_timer.h @@ -0,0 +1,40 @@ +/* + * Copyright (c) 2011-2012, Code Aurora Forum. All rights reserved. + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions + * are met: + * * Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * * Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in + * the documentation and/or other materials provided with the + * distribution. + * * Neither the name of Google, Inc. nor the names of its contributors + * may be used to endorse or promote products derived from this + * software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS + * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT + * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS + * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE + * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, + * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS + * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED + * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, + * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT + * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF + * SUCH DAMAGE. + */ + +#define TIMER_LOAD_VAL 0x21 + +#define GPT_ENABLE_CLR_ON_MATCH_EN 2 +#define GPT_ENABLE_EN 1 +#define DGT_ENABLE_CLR_ON_MATCH_EN 2 +#define DGT_ENABLE_EN 1 + +#define SPSS_TIMER_STATUS_DGT_EN (1 << 0) + + diff --git a/src/soc/qualcomm/ipq806x/include/timer.h b/src/soc/qualcomm/ipq806x/include/timer.h deleted file mode 100644 index 4e1ef34..0000000 --- a/src/soc/qualcomm/ipq806x/include/timer.h +++ /dev/null @@ -1,40 +0,0 @@ -/* - * Copyright (c) 2011-2012, Code Aurora Forum. All rights reserved. - * - * Redistribution and use in source and binary forms, with or without - * modification, are permitted provided that the following conditions - * are met: - * * Redistributions of source code must retain the above copyright - * notice, this list of conditions and the following disclaimer. - * * Redistributions in binary form must reproduce the above copyright - * notice, this list of conditions and the following disclaimer in - * the documentation and/or other materials provided with the - * distribution. - * * Neither the name of Google, Inc. nor the names of its contributors - * may be used to endorse or promote products derived from this - * software without specific prior written permission. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS - * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT - * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS - * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE - * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, - * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, - * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS - * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED - * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, - * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT - * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF - * SUCH DAMAGE. - */ - -#define TIMER_LOAD_VAL 0x21 - -#define GPT_ENABLE_CLR_ON_MATCH_EN 2 -#define GPT_ENABLE_EN 1 -#define DGT_ENABLE_CLR_ON_MATCH_EN 2 -#define DGT_ENABLE_EN 1 - -#define SPSS_TIMER_STATUS_DGT_EN (1 << 0) - - diff --git a/src/soc/qualcomm/ipq806x/timer.c b/src/soc/qualcomm/ipq806x/timer.c index 691ccbd..5c0dcb2 100644 --- a/src/soc/qualcomm/ipq806x/timer.c +++ b/src/soc/qualcomm/ipq806x/timer.c @@ -31,14 +31,10 @@ * SUCH DAMAGE. */
-#include <asm/arch-ipq806x/iomap.h> -#include <asm/io.h> -#include <common.h> -#include <asm/types.h> -#include <asm/arch-ipq806x/timer.h> - -static ulong timestamp; -static ulong lastinc; +#include <delay.h> +#include <iomap.h> +#include <ipq_timer.h> +#include <timer.h>
#define GPT_FREQ_KHZ 32 #define GPT_FREQ (GPT_FREQ_KHZ * 1000) /* 32 KHz */ @@ -46,36 +42,24 @@ static ulong lastinc; /** * timer_init - initialize timer */ -int timer_init(void) +void init_timer(void) { writel(0, GPT_ENABLE); writel(GPT_ENABLE_EN, GPT_ENABLE); - return 0; -} - -/** - * get_timer - returns time lapsed - * @base: base/start time - * - * Returns time lapsed, since the specified base time value. - */ -ulong get_timer(ulong base) -{ - return get_timer_masked() - base; }
/** - * __udelay - generates micro second delay. + * udelay - generates micro second delay. * @usec: delay duration in microseconds * * With 32KHz clock, minimum possible delay is 31.25 Micro seconds and * its multiples. In Rumi GPT clock is 32 KHz */ -void __udelay(unsigned long usec) +void udelay(unsigned usec) { - unsigned int val; - ulong now, last; - ulong runcount; + unsigned val; + unsigned now, last; + unsigned runcount;
usec = (usec + GPT_FREQ_KHZ - 1) / GPT_FREQ_KHZ; last = readl(GPT_COUNT_VAL); @@ -92,6 +76,15 @@ void __udelay(unsigned long usec) } while (runcount < val); }
+#if 0 + +/* + * TODO(vbendeb) clean it up later. + * Compile out the below code but leave it for now in case it will become + * necessary later in order to make the platform fully functional. + */ +static unsigned long timestamp; +static unsigned long lastinc;
inline ulong gpt_to_sys_freq(unsigned int gpt) { @@ -137,3 +130,4 @@ ulong get_tbclk(void) { return GPT_FREQ; } +#endif
