Martin Roth (martinroth@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/12335
commit 4d51be9681d908b1a3b1966b828c5dc78e4eadf8 Author: Martin Roth martinroth@google.com Date: Thu Nov 5 09:00:20 2015 -0700
fsp_model_406dx: use external microcode .h files for rangeley
The microcode for the Rangeley chip is supplied as .h files in the Rangeley FSP POSTGOLD4 package.
When the rangeley microcode gets put into the blobs directory, this can be reverted and the binary file put into the makefile.
Change-Id: I30e7436f26a247bc9431f249becfa5fe8c581be7 Signed-off-by: Martin Roth martinroth@google.com --- src/cpu/intel/fsp_model_406dx/Kconfig | 18 +++++++----------- src/cpu/intel/fsp_model_406dx/Makefile.inc | 3 --- src/cpu/intel/fsp_model_406dx/model_406dx_init.c | 3 ++- 3 files changed, 9 insertions(+), 15 deletions(-)
diff --git a/src/cpu/intel/fsp_model_406dx/Kconfig b/src/cpu/intel/fsp_model_406dx/Kconfig index c36851d..edf18f5 100644 --- a/src/cpu/intel/fsp_model_406dx/Kconfig +++ b/src/cpu/intel/fsp_model_406dx/Kconfig @@ -33,6 +33,9 @@ config CPU_SPECIFIC_OPTIONS select TSC_SYNC_MFENCE select LAPIC_MONOTONIC_TIMER
+ # Microcode header files are delivered in FSP package + select USES_MICROCODE_HEADER_FILES if HAVE_FSP_BIN + choice prompt "Rangeley CPU Stepping" default FSP_MODEL_406DX_B0 @@ -53,16 +56,9 @@ config ENABLE_VMX bool "Enable VMX for virtualization" default n
-config HAVE_CPU_MICROCODE_FILE - bool "Add microcode file" - help - The microcode binary - -config CPU_MICROCODE_FILE - string "Path and filename of CPU microcode" - default "microcode.bin" - depends on HAVE_CPU_MICROCODE_FILE - help - The path and filename of the file containing the CPU microcode. +#set up microcode for rangeley POSTGOLD4 release +config CPU_MICROCODE_HEADER_FILES + string + default "../intel/cpu/rangeley/microcode/microcode-m01406d000e.h ../intel/cpu/rangeley/microcode/microcode-m01406d8128.h"
endif #CPU_INTEL_FSP_MODEL_406DX diff --git a/src/cpu/intel/fsp_model_406dx/Makefile.inc b/src/cpu/intel/fsp_model_406dx/Makefile.inc index 91c7d96..3e29348 100644 --- a/src/cpu/intel/fsp_model_406dx/Makefile.inc +++ b/src/cpu/intel/fsp_model_406dx/Makefile.inc @@ -23,6 +23,3 @@ cpu_microcode_bins += $(call strip_quotes,$(CONFIG_CPU_MICROCODE_FILE)) endif
CPPFLAGS_romstage += -I$(src)/cpu/intel/fsp_model_406dx -# We don't have microcode for this CPU -# Use CONFIG_CPU_MICROCODE_CBFS_EXTERNAL with a binary microcode file -# cpu_microcode_bins += ??? diff --git a/src/cpu/intel/fsp_model_406dx/model_406dx_init.c b/src/cpu/intel/fsp_model_406dx/model_406dx_init.c index 5482e74..17c46b3 100644 --- a/src/cpu/intel/fsp_model_406dx/model_406dx_init.c +++ b/src/cpu/intel/fsp_model_406dx/model_406dx_init.c @@ -170,7 +170,8 @@ static void model_406dx_init(struct device *cpu) x86_enable_cache();
/* Load microcode */ - intel_update_microcode_from_cbfs(); + if (IS_ENABLED(CONFIG_SUPPORT_CPU_UCODE_IN_CBFS)) + intel_update_microcode_from_cbfs();
/* Clear out pending MCEs */ configure_mca();
