Edward O'Callaghan (eocallaghan@alterapraxis.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/7594
commit 7a2d253d8b811550db98e14ecf83cad732d11aa7 Author: Edward O'Callaghan eocallaghan@alterapraxis.com Date: Fri Nov 28 22:26:45 2014 +1100
vendorcode/amd/agesa: Make Porting.h common between families
Change-Id: Ica17b2452498f30b710533caf610c9f0c1a0452c Signed-off-by: Edward O'Callaghan eocallaghan@alterapraxis.com --- src/vendorcode/amd/agesa/Porting.h | 282 ++++++++++++++++++++++++++++ src/vendorcode/amd/agesa/f10/Makefile.inc | 1 + src/vendorcode/amd/agesa/f10/Porting.h | 282 ---------------------------- src/vendorcode/amd/agesa/f12/Makefile.inc | 1 + src/vendorcode/amd/agesa/f12/Porting.h | 282 ---------------------------- src/vendorcode/amd/agesa/f14/Makefile.inc | 1 + src/vendorcode/amd/agesa/f14/Porting.h | 282 ---------------------------- src/vendorcode/amd/agesa/f15/Makefile.inc | 1 + src/vendorcode/amd/agesa/f15/Porting.h | 282 ---------------------------- src/vendorcode/amd/agesa/f15tn/Makefile.inc | 1 + src/vendorcode/amd/agesa/f15tn/Porting.h | 282 ---------------------------- src/vendorcode/amd/agesa/f16kb/Makefile.inc | 1 + src/vendorcode/amd/agesa/f16kb/Porting.h | 282 ---------------------------- 13 files changed, 288 insertions(+), 1692 deletions(-)
diff --git a/src/vendorcode/amd/agesa/Porting.h b/src/vendorcode/amd/agesa/Porting.h new file mode 100644 index 0000000..fc65cfc --- /dev/null +++ b/src/vendorcode/amd/agesa/Porting.h @@ -0,0 +1,282 @@ +/* $NoKeywords:$ */ +/** + * @file + * + * Describes compiler dependencies - to support several compile time environments + * + * Contains compiler environment porting descriptions + * + * @xrefitem bom "File Content Label" "Release Content" + * @e project: AGESA + * @e sub-project: Includes + * @e $Revision: 44324 $ @e $Date: 2010-12-22 03:16:51 -0600 (Wed, 22 Dec 2010) $ + */ +/***************************************************************************** + * + * Copyright (c) 2008 - 2012, Advanced Micro Devices, Inc. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions are met: + * * Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * * Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in the + * documentation and/or other materials provided with the distribution. + * * Neither the name of Advanced Micro Devices, Inc. nor the names of + * its contributors may be used to endorse or promote products derived + * from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED + * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE + * DISCLAIMED. IN NO EVENT SHALL ADVANCED MICRO DEVICES, INC. BE LIABLE FOR ANY + * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES + * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; + * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND + * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS + * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + * + ***************************************************************************/ + +#ifndef _PORTING_H_ +#define _PORTING_H_ + +#if defined (_MSC_VER) + #include <intrin.h> + void _disable (void); + void _enable (void); + #pragma warning(disable: 4103 4001 4733) + #pragma intrinsic (_disable, _enable) + #pragma warning(push) + // ----------------------------------------------------------------------- + // Define a code_seg MACRO + // + #define MAKE_AS_A_STRING(arg) #arg + + #define CODE_GROUP(arg) __pragma (code_seg (MAKE_AS_A_STRING (.t##arg))) + + #define RDATA_GROUP(arg) __pragma (const_seg (MAKE_AS_A_STRING (.d##arg))) + #define FUNC_ATTRIBUTE(arg) __declspec(arg) + //#include <intrin.h> // MS has built-in functions + + #if _MSC_VER < 900 + // ----------------------------------------------------------------------- + // Assume MSVC 1.52C (16-bit) + // + // NOTE: When using MSVC 1.52C use the following command line: + // + // CL.EXE /G3 /AL /O1i /Fa <FILENAME.C> + // + // This will produce 32-bit code in USE16 segment that is optimized for code + // size. + typedef void VOID; + + // Create the universal 32, 16, and 8-bit data types + typedef unsigned long UINTN; + typedef long INT32; + typedef unsigned long UINT32; + typedef int INT16; + typedef unsigned int UINT16; + typedef char INT8; + typedef unsigned char UINT8; + typedef char CHAR8; + typedef unsigned short CHAR16; + + /// struct for 16-bit environment handling of 64-bit value + typedef struct _UINT64 { + IN OUT UINT32 lo; ///< lower 32-bits of 64-bit value + IN OUT UINT32 hi; ///< highest 32-bits of 64-bit value + } UINT64; + + // Create the Boolean type + #define TRUE 1 + #define FALSE 0 + typedef unsigned char BOOLEAN; + + #define CONST const + #define STATIC static + #define VOLATILE volatile + #define CALLCONV __pascal + #define ROMDATA __based( __segname( "_CODE" ) ) + #define _16BYTE_ALIGN __declspec(align(16)) + + // Force tight packing of structures + // Note: Entire AGESA (Project / Solution) will be using pragma pack 1 + #pragma warning( disable : 4103 ) // Disable '#pragma pack' in .h warning + #pragma pack(1) + + // Disable WORD->BYTE automatic conversion warnings. Example: + // BYTE LocalByte; + // void MyFunc(BYTE val); + // + // MyFunc(LocalByte*2+1); // Warning, automatic conversion + // + // The problem is any time math is performed on a BYTE, it is converted to a + // WORD by MSVC 1.52c, and then when it is converted back to a BYTE, a warning + // is generated. Disable warning C4761 + #pragma warning( disable : 4761 ) + + #else + // ----------------------------------------------------------------------- + // Assume a 32-bit MSVC++ + // + // Disable the following warnings: + // 4100 - 'identifier' : unreferenced formal parameter + // 4276 - 'function' : no prototype provided; assumed no parameters + // 4214 - non standard extension used : bit field types other than int + // 4001 - nonstandard extension 'single line comment' was used + // 4142 - benign redefinition of type for following declaration + // - typedef char INT8 + #if defined (_M_IX86) + #pragma warning (disable: 4100 4276 4214 4001 4142 4305 4306) + + #ifndef VOID + typedef void VOID; + #endif + // Create the universal 32, 16, and 8-bit data types + #ifndef UINTN + typedef unsigned __w64 UINTN; + #endif + typedef __int64 INT64; + typedef unsigned __int64 UINT64; + typedef int INT32; + typedef unsigned int UINT32; + typedef short INT16; + typedef unsigned short UINT16; + typedef char INT8; + typedef unsigned char UINT8; + typedef char CHAR8; + typedef unsigned short CHAR16; + + // Create the Boolean type + #ifndef TRUE + #define TRUE 1 + #endif + #ifndef FALSE + #define FALSE 0 + #endif + typedef unsigned char BOOLEAN; + + // Force tight packing of structures + // Note: Entire AGESA (Project / Solution) will be using pragma pack 1 + #pragma pack(1) + + #define CONST const + #define STATIC static + #define VOLATILE volatile + #define CALLCONV + #define ROMDATA + #define _16BYTE_ALIGN __declspec(align(64)) + // 64 bit of compiler + #else + #pragma warning (disable: 4100 4276 4214 4001 4142 4305 4306 4366) + + #ifndef VOID + typedef void VOID; + #endif + // Create the universal 32, 16, and 8-bit data types + #ifndef UINTN + typedef unsigned __int64 UINTN; + #endif + typedef __int64 INT64; + typedef unsigned __int64 UINT64; + typedef int INT32; + typedef unsigned int UINT32; + typedef short INT16; + typedef unsigned short UINT16; + typedef char INT8; + typedef unsigned char UINT8; + typedef char CHAR8; + typedef unsigned short CHAR16; + + // Create the Boolean type + #ifndef TRUE + #define TRUE 1 + #endif + #ifndef FALSE + #define FALSE 0 + #endif + typedef unsigned char BOOLEAN; + + // Force tight packing of structures + // Note: Entire AGESA (Project / Solution) will be using pragma pack 1 + #pragma pack(1) + + #define CONST const + #define STATIC static + #define VOLATILE volatile + #define CALLCONV + #define ROMDATA + #endif + #endif + // ----------------------------------------------------------------------- + // End of MS compiler versions + +#elif defined __GNUC__ + + #define IN + #define OUT + #define STATIC static + #define VOLATILE volatile + #define TRUE 1 + #define FALSE 0 +// #undef CONST + #define CONST const + #define ROMDATA + #define CALLCONV + #define _16BYTE_ALIGN __attribute__ ((aligned (16))) + + typedef unsigned char BOOLEAN; + typedef signed char INT8; + typedef signed short INT16; + typedef signed long INT32; + typedef char CHAR8; + typedef unsigned char UINT8; + typedef unsigned short UINT16; + typedef unsigned long UINT32; + typedef unsigned long UINTN; + typedef unsigned long long UINT64; + typedef long long INT64; + typedef void VOID; + //typedef unsigned long size_t; + + //#include <intrin.h> // MingW-w64 library header +#pragma pack(1) + +#define CODE_GROUP(arg) +#define RDATA_GROUP(arg) + +#define FUNC_ATTRIBUTE(arg) __attribute__((arg)) +#define MAKE_AS_A_STRING(arg) #arg +#include <stddef.h> +#include "gcc-intrin.h" + +#include <assert.h> +#include <console/console.h> +#include <console/loglevel.h> + +#ifndef NULL + #define NULL (void *)0 +#endif + +#else + // ----------------------------------------------------------------------- + // Unknown or unsupported compiler + // + #error "Unknown compiler in use" +#endif + +// ----------------------------------------------------------------------- +// Common definitions for all compilers +// + +//Support forward reference construct +#define AGESA_FORWARD_DECLARATION(x) typedef struct _##x x + +// The following are use in conformance to the UEFI style guide +#define IN +#define OUT + +#endif // _PORTING_H_ diff --git a/src/vendorcode/amd/agesa/f10/Makefile.inc b/src/vendorcode/amd/agesa/f10/Makefile.inc index b684a29..2d7e60c 100644 --- a/src/vendorcode/amd/agesa/f10/Makefile.inc +++ b/src/vendorcode/amd/agesa/f10/Makefile.inc @@ -22,6 +22,7 @@ AGESA_ROOT = src/vendorcode/amd/agesa/f10
AGESA_INC ?= -I$(src)/mainboard/$(MAINBOARDDIR) AGESA_INC += -I$(AGESA_ROOT) +AGESA_INC += -I$(AGESA_ROOT)../ AGESA_INC += -I$(AGESA_ROOT)/Include AGESA_INC += -I$(AGESA_ROOT)/Lib AGESA_INC += -I$(AGESA_ROOT)/Legacy diff --git a/src/vendorcode/amd/agesa/f10/Porting.h b/src/vendorcode/amd/agesa/f10/Porting.h deleted file mode 100644 index fc65cfc..0000000 --- a/src/vendorcode/amd/agesa/f10/Porting.h +++ /dev/null @@ -1,282 +0,0 @@ -/* $NoKeywords:$ */ -/** - * @file - * - * Describes compiler dependencies - to support several compile time environments - * - * Contains compiler environment porting descriptions - * - * @xrefitem bom "File Content Label" "Release Content" - * @e project: AGESA - * @e sub-project: Includes - * @e $Revision: 44324 $ @e $Date: 2010-12-22 03:16:51 -0600 (Wed, 22 Dec 2010) $ - */ -/***************************************************************************** - * - * Copyright (c) 2008 - 2012, Advanced Micro Devices, Inc. - * All rights reserved. - * - * Redistribution and use in source and binary forms, with or without - * modification, are permitted provided that the following conditions are met: - * * Redistributions of source code must retain the above copyright - * notice, this list of conditions and the following disclaimer. - * * Redistributions in binary form must reproduce the above copyright - * notice, this list of conditions and the following disclaimer in the - * documentation and/or other materials provided with the distribution. - * * Neither the name of Advanced Micro Devices, Inc. nor the names of - * its contributors may be used to endorse or promote products derived - * from this software without specific prior written permission. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND - * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED - * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL ADVANCED MICRO DEVICES, INC. BE LIABLE FOR ANY - * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES - * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; - * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND - * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT - * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS - * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. - * - ***************************************************************************/ - -#ifndef _PORTING_H_ -#define _PORTING_H_ - -#if defined (_MSC_VER) - #include <intrin.h> - void _disable (void); - void _enable (void); - #pragma warning(disable: 4103 4001 4733) - #pragma intrinsic (_disable, _enable) - #pragma warning(push) - // ----------------------------------------------------------------------- - // Define a code_seg MACRO - // - #define MAKE_AS_A_STRING(arg) #arg - - #define CODE_GROUP(arg) __pragma (code_seg (MAKE_AS_A_STRING (.t##arg))) - - #define RDATA_GROUP(arg) __pragma (const_seg (MAKE_AS_A_STRING (.d##arg))) - #define FUNC_ATTRIBUTE(arg) __declspec(arg) - //#include <intrin.h> // MS has built-in functions - - #if _MSC_VER < 900 - // ----------------------------------------------------------------------- - // Assume MSVC 1.52C (16-bit) - // - // NOTE: When using MSVC 1.52C use the following command line: - // - // CL.EXE /G3 /AL /O1i /Fa <FILENAME.C> - // - // This will produce 32-bit code in USE16 segment that is optimized for code - // size. - typedef void VOID; - - // Create the universal 32, 16, and 8-bit data types - typedef unsigned long UINTN; - typedef long INT32; - typedef unsigned long UINT32; - typedef int INT16; - typedef unsigned int UINT16; - typedef char INT8; - typedef unsigned char UINT8; - typedef char CHAR8; - typedef unsigned short CHAR16; - - /// struct for 16-bit environment handling of 64-bit value - typedef struct _UINT64 { - IN OUT UINT32 lo; ///< lower 32-bits of 64-bit value - IN OUT UINT32 hi; ///< highest 32-bits of 64-bit value - } UINT64; - - // Create the Boolean type - #define TRUE 1 - #define FALSE 0 - typedef unsigned char BOOLEAN; - - #define CONST const - #define STATIC static - #define VOLATILE volatile - #define CALLCONV __pascal - #define ROMDATA __based( __segname( "_CODE" ) ) - #define _16BYTE_ALIGN __declspec(align(16)) - - // Force tight packing of structures - // Note: Entire AGESA (Project / Solution) will be using pragma pack 1 - #pragma warning( disable : 4103 ) // Disable '#pragma pack' in .h warning - #pragma pack(1) - - // Disable WORD->BYTE automatic conversion warnings. Example: - // BYTE LocalByte; - // void MyFunc(BYTE val); - // - // MyFunc(LocalByte*2+1); // Warning, automatic conversion - // - // The problem is any time math is performed on a BYTE, it is converted to a - // WORD by MSVC 1.52c, and then when it is converted back to a BYTE, a warning - // is generated. Disable warning C4761 - #pragma warning( disable : 4761 ) - - #else - // ----------------------------------------------------------------------- - // Assume a 32-bit MSVC++ - // - // Disable the following warnings: - // 4100 - 'identifier' : unreferenced formal parameter - // 4276 - 'function' : no prototype provided; assumed no parameters - // 4214 - non standard extension used : bit field types other than int - // 4001 - nonstandard extension 'single line comment' was used - // 4142 - benign redefinition of type for following declaration - // - typedef char INT8 - #if defined (_M_IX86) - #pragma warning (disable: 4100 4276 4214 4001 4142 4305 4306) - - #ifndef VOID - typedef void VOID; - #endif - // Create the universal 32, 16, and 8-bit data types - #ifndef UINTN - typedef unsigned __w64 UINTN; - #endif - typedef __int64 INT64; - typedef unsigned __int64 UINT64; - typedef int INT32; - typedef unsigned int UINT32; - typedef short INT16; - typedef unsigned short UINT16; - typedef char INT8; - typedef unsigned char UINT8; - typedef char CHAR8; - typedef unsigned short CHAR16; - - // Create the Boolean type - #ifndef TRUE - #define TRUE 1 - #endif - #ifndef FALSE - #define FALSE 0 - #endif - typedef unsigned char BOOLEAN; - - // Force tight packing of structures - // Note: Entire AGESA (Project / Solution) will be using pragma pack 1 - #pragma pack(1) - - #define CONST const - #define STATIC static - #define VOLATILE volatile - #define CALLCONV - #define ROMDATA - #define _16BYTE_ALIGN __declspec(align(64)) - // 64 bit of compiler - #else - #pragma warning (disable: 4100 4276 4214 4001 4142 4305 4306 4366) - - #ifndef VOID - typedef void VOID; - #endif - // Create the universal 32, 16, and 8-bit data types - #ifndef UINTN - typedef unsigned __int64 UINTN; - #endif - typedef __int64 INT64; - typedef unsigned __int64 UINT64; - typedef int INT32; - typedef unsigned int UINT32; - typedef short INT16; - typedef unsigned short UINT16; - typedef char INT8; - typedef unsigned char UINT8; - typedef char CHAR8; - typedef unsigned short CHAR16; - - // Create the Boolean type - #ifndef TRUE - #define TRUE 1 - #endif - #ifndef FALSE - #define FALSE 0 - #endif - typedef unsigned char BOOLEAN; - - // Force tight packing of structures - // Note: Entire AGESA (Project / Solution) will be using pragma pack 1 - #pragma pack(1) - - #define CONST const - #define STATIC static - #define VOLATILE volatile - #define CALLCONV - #define ROMDATA - #endif - #endif - // ----------------------------------------------------------------------- - // End of MS compiler versions - -#elif defined __GNUC__ - - #define IN - #define OUT - #define STATIC static - #define VOLATILE volatile - #define TRUE 1 - #define FALSE 0 -// #undef CONST - #define CONST const - #define ROMDATA - #define CALLCONV - #define _16BYTE_ALIGN __attribute__ ((aligned (16))) - - typedef unsigned char BOOLEAN; - typedef signed char INT8; - typedef signed short INT16; - typedef signed long INT32; - typedef char CHAR8; - typedef unsigned char UINT8; - typedef unsigned short UINT16; - typedef unsigned long UINT32; - typedef unsigned long UINTN; - typedef unsigned long long UINT64; - typedef long long INT64; - typedef void VOID; - //typedef unsigned long size_t; - - //#include <intrin.h> // MingW-w64 library header -#pragma pack(1) - -#define CODE_GROUP(arg) -#define RDATA_GROUP(arg) - -#define FUNC_ATTRIBUTE(arg) __attribute__((arg)) -#define MAKE_AS_A_STRING(arg) #arg -#include <stddef.h> -#include "gcc-intrin.h" - -#include <assert.h> -#include <console/console.h> -#include <console/loglevel.h> - -#ifndef NULL - #define NULL (void *)0 -#endif - -#else - // ----------------------------------------------------------------------- - // Unknown or unsupported compiler - // - #error "Unknown compiler in use" -#endif - -// ----------------------------------------------------------------------- -// Common definitions for all compilers -// - -//Support forward reference construct -#define AGESA_FORWARD_DECLARATION(x) typedef struct _##x x - -// The following are use in conformance to the UEFI style guide -#define IN -#define OUT - -#endif // _PORTING_H_ diff --git a/src/vendorcode/amd/agesa/f12/Makefile.inc b/src/vendorcode/amd/agesa/f12/Makefile.inc index b7f9d92..c4578d5 100644 --- a/src/vendorcode/amd/agesa/f12/Makefile.inc +++ b/src/vendorcode/amd/agesa/f12/Makefile.inc @@ -32,6 +32,7 @@ AGESA_ROOT = src/vendorcode/amd/agesa/f12
AGESA_INC = -Isrc/mainboard/$(MAINBOARDDIR) AGESA_INC += -I$(AGESA_ROOT) +AGESA_INC += -I$(AGESA_ROOT)../ AGESA_INC += -I$(AGESA_ROOT)/Proc/CPU AGESA_INC += -I$(AGESA_ROOT)/Proc/CPU/Family AGESA_INC += -I$(AGESA_ROOT)/Include diff --git a/src/vendorcode/amd/agesa/f12/Porting.h b/src/vendorcode/amd/agesa/f12/Porting.h deleted file mode 100644 index fc65cfc..0000000 --- a/src/vendorcode/amd/agesa/f12/Porting.h +++ /dev/null @@ -1,282 +0,0 @@ -/* $NoKeywords:$ */ -/** - * @file - * - * Describes compiler dependencies - to support several compile time environments - * - * Contains compiler environment porting descriptions - * - * @xrefitem bom "File Content Label" "Release Content" - * @e project: AGESA - * @e sub-project: Includes - * @e $Revision: 44324 $ @e $Date: 2010-12-22 03:16:51 -0600 (Wed, 22 Dec 2010) $ - */ -/***************************************************************************** - * - * Copyright (c) 2008 - 2012, Advanced Micro Devices, Inc. - * All rights reserved. - * - * Redistribution and use in source and binary forms, with or without - * modification, are permitted provided that the following conditions are met: - * * Redistributions of source code must retain the above copyright - * notice, this list of conditions and the following disclaimer. - * * Redistributions in binary form must reproduce the above copyright - * notice, this list of conditions and the following disclaimer in the - * documentation and/or other materials provided with the distribution. - * * Neither the name of Advanced Micro Devices, Inc. nor the names of - * its contributors may be used to endorse or promote products derived - * from this software without specific prior written permission. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND - * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED - * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL ADVANCED MICRO DEVICES, INC. BE LIABLE FOR ANY - * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES - * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; - * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND - * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT - * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS - * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. - * - ***************************************************************************/ - -#ifndef _PORTING_H_ -#define _PORTING_H_ - -#if defined (_MSC_VER) - #include <intrin.h> - void _disable (void); - void _enable (void); - #pragma warning(disable: 4103 4001 4733) - #pragma intrinsic (_disable, _enable) - #pragma warning(push) - // ----------------------------------------------------------------------- - // Define a code_seg MACRO - // - #define MAKE_AS_A_STRING(arg) #arg - - #define CODE_GROUP(arg) __pragma (code_seg (MAKE_AS_A_STRING (.t##arg))) - - #define RDATA_GROUP(arg) __pragma (const_seg (MAKE_AS_A_STRING (.d##arg))) - #define FUNC_ATTRIBUTE(arg) __declspec(arg) - //#include <intrin.h> // MS has built-in functions - - #if _MSC_VER < 900 - // ----------------------------------------------------------------------- - // Assume MSVC 1.52C (16-bit) - // - // NOTE: When using MSVC 1.52C use the following command line: - // - // CL.EXE /G3 /AL /O1i /Fa <FILENAME.C> - // - // This will produce 32-bit code in USE16 segment that is optimized for code - // size. - typedef void VOID; - - // Create the universal 32, 16, and 8-bit data types - typedef unsigned long UINTN; - typedef long INT32; - typedef unsigned long UINT32; - typedef int INT16; - typedef unsigned int UINT16; - typedef char INT8; - typedef unsigned char UINT8; - typedef char CHAR8; - typedef unsigned short CHAR16; - - /// struct for 16-bit environment handling of 64-bit value - typedef struct _UINT64 { - IN OUT UINT32 lo; ///< lower 32-bits of 64-bit value - IN OUT UINT32 hi; ///< highest 32-bits of 64-bit value - } UINT64; - - // Create the Boolean type - #define TRUE 1 - #define FALSE 0 - typedef unsigned char BOOLEAN; - - #define CONST const - #define STATIC static - #define VOLATILE volatile - #define CALLCONV __pascal - #define ROMDATA __based( __segname( "_CODE" ) ) - #define _16BYTE_ALIGN __declspec(align(16)) - - // Force tight packing of structures - // Note: Entire AGESA (Project / Solution) will be using pragma pack 1 - #pragma warning( disable : 4103 ) // Disable '#pragma pack' in .h warning - #pragma pack(1) - - // Disable WORD->BYTE automatic conversion warnings. Example: - // BYTE LocalByte; - // void MyFunc(BYTE val); - // - // MyFunc(LocalByte*2+1); // Warning, automatic conversion - // - // The problem is any time math is performed on a BYTE, it is converted to a - // WORD by MSVC 1.52c, and then when it is converted back to a BYTE, a warning - // is generated. Disable warning C4761 - #pragma warning( disable : 4761 ) - - #else - // ----------------------------------------------------------------------- - // Assume a 32-bit MSVC++ - // - // Disable the following warnings: - // 4100 - 'identifier' : unreferenced formal parameter - // 4276 - 'function' : no prototype provided; assumed no parameters - // 4214 - non standard extension used : bit field types other than int - // 4001 - nonstandard extension 'single line comment' was used - // 4142 - benign redefinition of type for following declaration - // - typedef char INT8 - #if defined (_M_IX86) - #pragma warning (disable: 4100 4276 4214 4001 4142 4305 4306) - - #ifndef VOID - typedef void VOID; - #endif - // Create the universal 32, 16, and 8-bit data types - #ifndef UINTN - typedef unsigned __w64 UINTN; - #endif - typedef __int64 INT64; - typedef unsigned __int64 UINT64; - typedef int INT32; - typedef unsigned int UINT32; - typedef short INT16; - typedef unsigned short UINT16; - typedef char INT8; - typedef unsigned char UINT8; - typedef char CHAR8; - typedef unsigned short CHAR16; - - // Create the Boolean type - #ifndef TRUE - #define TRUE 1 - #endif - #ifndef FALSE - #define FALSE 0 - #endif - typedef unsigned char BOOLEAN; - - // Force tight packing of structures - // Note: Entire AGESA (Project / Solution) will be using pragma pack 1 - #pragma pack(1) - - #define CONST const - #define STATIC static - #define VOLATILE volatile - #define CALLCONV - #define ROMDATA - #define _16BYTE_ALIGN __declspec(align(64)) - // 64 bit of compiler - #else - #pragma warning (disable: 4100 4276 4214 4001 4142 4305 4306 4366) - - #ifndef VOID - typedef void VOID; - #endif - // Create the universal 32, 16, and 8-bit data types - #ifndef UINTN - typedef unsigned __int64 UINTN; - #endif - typedef __int64 INT64; - typedef unsigned __int64 UINT64; - typedef int INT32; - typedef unsigned int UINT32; - typedef short INT16; - typedef unsigned short UINT16; - typedef char INT8; - typedef unsigned char UINT8; - typedef char CHAR8; - typedef unsigned short CHAR16; - - // Create the Boolean type - #ifndef TRUE - #define TRUE 1 - #endif - #ifndef FALSE - #define FALSE 0 - #endif - typedef unsigned char BOOLEAN; - - // Force tight packing of structures - // Note: Entire AGESA (Project / Solution) will be using pragma pack 1 - #pragma pack(1) - - #define CONST const - #define STATIC static - #define VOLATILE volatile - #define CALLCONV - #define ROMDATA - #endif - #endif - // ----------------------------------------------------------------------- - // End of MS compiler versions - -#elif defined __GNUC__ - - #define IN - #define OUT - #define STATIC static - #define VOLATILE volatile - #define TRUE 1 - #define FALSE 0 -// #undef CONST - #define CONST const - #define ROMDATA - #define CALLCONV - #define _16BYTE_ALIGN __attribute__ ((aligned (16))) - - typedef unsigned char BOOLEAN; - typedef signed char INT8; - typedef signed short INT16; - typedef signed long INT32; - typedef char CHAR8; - typedef unsigned char UINT8; - typedef unsigned short UINT16; - typedef unsigned long UINT32; - typedef unsigned long UINTN; - typedef unsigned long long UINT64; - typedef long long INT64; - typedef void VOID; - //typedef unsigned long size_t; - - //#include <intrin.h> // MingW-w64 library header -#pragma pack(1) - -#define CODE_GROUP(arg) -#define RDATA_GROUP(arg) - -#define FUNC_ATTRIBUTE(arg) __attribute__((arg)) -#define MAKE_AS_A_STRING(arg) #arg -#include <stddef.h> -#include "gcc-intrin.h" - -#include <assert.h> -#include <console/console.h> -#include <console/loglevel.h> - -#ifndef NULL - #define NULL (void *)0 -#endif - -#else - // ----------------------------------------------------------------------- - // Unknown or unsupported compiler - // - #error "Unknown compiler in use" -#endif - -// ----------------------------------------------------------------------- -// Common definitions for all compilers -// - -//Support forward reference construct -#define AGESA_FORWARD_DECLARATION(x) typedef struct _##x x - -// The following are use in conformance to the UEFI style guide -#define IN -#define OUT - -#endif // _PORTING_H_ diff --git a/src/vendorcode/amd/agesa/f14/Makefile.inc b/src/vendorcode/amd/agesa/f14/Makefile.inc index 0f570d7..5e36684 100644 --- a/src/vendorcode/amd/agesa/f14/Makefile.inc +++ b/src/vendorcode/amd/agesa/f14/Makefile.inc @@ -32,6 +32,7 @@ AGESA_ROOT = src/vendorcode/amd/agesa/f14
AGESA_INC = -Isrc/mainboard/$(MAINBOARDDIR) AGESA_INC += -I$(AGESA_ROOT) +AGESA_INC += -I$(AGESA_ROOT)../ AGESA_INC += -I$(AGESA_ROOT)/Include AGESA_INC += -I$(AGESA_ROOT)/Lib AGESA_INC += -I$(AGESA_ROOT)/Legacy diff --git a/src/vendorcode/amd/agesa/f14/Porting.h b/src/vendorcode/amd/agesa/f14/Porting.h deleted file mode 100644 index fc65cfc..0000000 --- a/src/vendorcode/amd/agesa/f14/Porting.h +++ /dev/null @@ -1,282 +0,0 @@ -/* $NoKeywords:$ */ -/** - * @file - * - * Describes compiler dependencies - to support several compile time environments - * - * Contains compiler environment porting descriptions - * - * @xrefitem bom "File Content Label" "Release Content" - * @e project: AGESA - * @e sub-project: Includes - * @e $Revision: 44324 $ @e $Date: 2010-12-22 03:16:51 -0600 (Wed, 22 Dec 2010) $ - */ -/***************************************************************************** - * - * Copyright (c) 2008 - 2012, Advanced Micro Devices, Inc. - * All rights reserved. - * - * Redistribution and use in source and binary forms, with or without - * modification, are permitted provided that the following conditions are met: - * * Redistributions of source code must retain the above copyright - * notice, this list of conditions and the following disclaimer. - * * Redistributions in binary form must reproduce the above copyright - * notice, this list of conditions and the following disclaimer in the - * documentation and/or other materials provided with the distribution. - * * Neither the name of Advanced Micro Devices, Inc. nor the names of - * its contributors may be used to endorse or promote products derived - * from this software without specific prior written permission. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND - * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED - * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL ADVANCED MICRO DEVICES, INC. BE LIABLE FOR ANY - * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES - * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; - * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND - * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT - * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS - * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. - * - ***************************************************************************/ - -#ifndef _PORTING_H_ -#define _PORTING_H_ - -#if defined (_MSC_VER) - #include <intrin.h> - void _disable (void); - void _enable (void); - #pragma warning(disable: 4103 4001 4733) - #pragma intrinsic (_disable, _enable) - #pragma warning(push) - // ----------------------------------------------------------------------- - // Define a code_seg MACRO - // - #define MAKE_AS_A_STRING(arg) #arg - - #define CODE_GROUP(arg) __pragma (code_seg (MAKE_AS_A_STRING (.t##arg))) - - #define RDATA_GROUP(arg) __pragma (const_seg (MAKE_AS_A_STRING (.d##arg))) - #define FUNC_ATTRIBUTE(arg) __declspec(arg) - //#include <intrin.h> // MS has built-in functions - - #if _MSC_VER < 900 - // ----------------------------------------------------------------------- - // Assume MSVC 1.52C (16-bit) - // - // NOTE: When using MSVC 1.52C use the following command line: - // - // CL.EXE /G3 /AL /O1i /Fa <FILENAME.C> - // - // This will produce 32-bit code in USE16 segment that is optimized for code - // size. - typedef void VOID; - - // Create the universal 32, 16, and 8-bit data types - typedef unsigned long UINTN; - typedef long INT32; - typedef unsigned long UINT32; - typedef int INT16; - typedef unsigned int UINT16; - typedef char INT8; - typedef unsigned char UINT8; - typedef char CHAR8; - typedef unsigned short CHAR16; - - /// struct for 16-bit environment handling of 64-bit value - typedef struct _UINT64 { - IN OUT UINT32 lo; ///< lower 32-bits of 64-bit value - IN OUT UINT32 hi; ///< highest 32-bits of 64-bit value - } UINT64; - - // Create the Boolean type - #define TRUE 1 - #define FALSE 0 - typedef unsigned char BOOLEAN; - - #define CONST const - #define STATIC static - #define VOLATILE volatile - #define CALLCONV __pascal - #define ROMDATA __based( __segname( "_CODE" ) ) - #define _16BYTE_ALIGN __declspec(align(16)) - - // Force tight packing of structures - // Note: Entire AGESA (Project / Solution) will be using pragma pack 1 - #pragma warning( disable : 4103 ) // Disable '#pragma pack' in .h warning - #pragma pack(1) - - // Disable WORD->BYTE automatic conversion warnings. Example: - // BYTE LocalByte; - // void MyFunc(BYTE val); - // - // MyFunc(LocalByte*2+1); // Warning, automatic conversion - // - // The problem is any time math is performed on a BYTE, it is converted to a - // WORD by MSVC 1.52c, and then when it is converted back to a BYTE, a warning - // is generated. Disable warning C4761 - #pragma warning( disable : 4761 ) - - #else - // ----------------------------------------------------------------------- - // Assume a 32-bit MSVC++ - // - // Disable the following warnings: - // 4100 - 'identifier' : unreferenced formal parameter - // 4276 - 'function' : no prototype provided; assumed no parameters - // 4214 - non standard extension used : bit field types other than int - // 4001 - nonstandard extension 'single line comment' was used - // 4142 - benign redefinition of type for following declaration - // - typedef char INT8 - #if defined (_M_IX86) - #pragma warning (disable: 4100 4276 4214 4001 4142 4305 4306) - - #ifndef VOID - typedef void VOID; - #endif - // Create the universal 32, 16, and 8-bit data types - #ifndef UINTN - typedef unsigned __w64 UINTN; - #endif - typedef __int64 INT64; - typedef unsigned __int64 UINT64; - typedef int INT32; - typedef unsigned int UINT32; - typedef short INT16; - typedef unsigned short UINT16; - typedef char INT8; - typedef unsigned char UINT8; - typedef char CHAR8; - typedef unsigned short CHAR16; - - // Create the Boolean type - #ifndef TRUE - #define TRUE 1 - #endif - #ifndef FALSE - #define FALSE 0 - #endif - typedef unsigned char BOOLEAN; - - // Force tight packing of structures - // Note: Entire AGESA (Project / Solution) will be using pragma pack 1 - #pragma pack(1) - - #define CONST const - #define STATIC static - #define VOLATILE volatile - #define CALLCONV - #define ROMDATA - #define _16BYTE_ALIGN __declspec(align(64)) - // 64 bit of compiler - #else - #pragma warning (disable: 4100 4276 4214 4001 4142 4305 4306 4366) - - #ifndef VOID - typedef void VOID; - #endif - // Create the universal 32, 16, and 8-bit data types - #ifndef UINTN - typedef unsigned __int64 UINTN; - #endif - typedef __int64 INT64; - typedef unsigned __int64 UINT64; - typedef int INT32; - typedef unsigned int UINT32; - typedef short INT16; - typedef unsigned short UINT16; - typedef char INT8; - typedef unsigned char UINT8; - typedef char CHAR8; - typedef unsigned short CHAR16; - - // Create the Boolean type - #ifndef TRUE - #define TRUE 1 - #endif - #ifndef FALSE - #define FALSE 0 - #endif - typedef unsigned char BOOLEAN; - - // Force tight packing of structures - // Note: Entire AGESA (Project / Solution) will be using pragma pack 1 - #pragma pack(1) - - #define CONST const - #define STATIC static - #define VOLATILE volatile - #define CALLCONV - #define ROMDATA - #endif - #endif - // ----------------------------------------------------------------------- - // End of MS compiler versions - -#elif defined __GNUC__ - - #define IN - #define OUT - #define STATIC static - #define VOLATILE volatile - #define TRUE 1 - #define FALSE 0 -// #undef CONST - #define CONST const - #define ROMDATA - #define CALLCONV - #define _16BYTE_ALIGN __attribute__ ((aligned (16))) - - typedef unsigned char BOOLEAN; - typedef signed char INT8; - typedef signed short INT16; - typedef signed long INT32; - typedef char CHAR8; - typedef unsigned char UINT8; - typedef unsigned short UINT16; - typedef unsigned long UINT32; - typedef unsigned long UINTN; - typedef unsigned long long UINT64; - typedef long long INT64; - typedef void VOID; - //typedef unsigned long size_t; - - //#include <intrin.h> // MingW-w64 library header -#pragma pack(1) - -#define CODE_GROUP(arg) -#define RDATA_GROUP(arg) - -#define FUNC_ATTRIBUTE(arg) __attribute__((arg)) -#define MAKE_AS_A_STRING(arg) #arg -#include <stddef.h> -#include "gcc-intrin.h" - -#include <assert.h> -#include <console/console.h> -#include <console/loglevel.h> - -#ifndef NULL - #define NULL (void *)0 -#endif - -#else - // ----------------------------------------------------------------------- - // Unknown or unsupported compiler - // - #error "Unknown compiler in use" -#endif - -// ----------------------------------------------------------------------- -// Common definitions for all compilers -// - -//Support forward reference construct -#define AGESA_FORWARD_DECLARATION(x) typedef struct _##x x - -// The following are use in conformance to the UEFI style guide -#define IN -#define OUT - -#endif // _PORTING_H_ diff --git a/src/vendorcode/amd/agesa/f15/Makefile.inc b/src/vendorcode/amd/agesa/f15/Makefile.inc index 7c1359e..f086e4e 100644 --- a/src/vendorcode/amd/agesa/f15/Makefile.inc +++ b/src/vendorcode/amd/agesa/f15/Makefile.inc @@ -22,6 +22,7 @@ AGESA_ROOT ?= $(PWD)
AGESA_INC ?= -I$(src)/mainboard/$(MAINBOARDDIR) AGESA_INC += -I$(AGESA_ROOT) +AGESA_INC += -I$(AGESA_ROOT)../ AGESA_INC += -I$(AGESA_ROOT)/Include AGESA_INC += -I$(AGESA_ROOT)/Lib AGESA_INC += -I$(AGESA_ROOT)/Legacy diff --git a/src/vendorcode/amd/agesa/f15/Porting.h b/src/vendorcode/amd/agesa/f15/Porting.h deleted file mode 100644 index fc65cfc..0000000 --- a/src/vendorcode/amd/agesa/f15/Porting.h +++ /dev/null @@ -1,282 +0,0 @@ -/* $NoKeywords:$ */ -/** - * @file - * - * Describes compiler dependencies - to support several compile time environments - * - * Contains compiler environment porting descriptions - * - * @xrefitem bom "File Content Label" "Release Content" - * @e project: AGESA - * @e sub-project: Includes - * @e $Revision: 44324 $ @e $Date: 2010-12-22 03:16:51 -0600 (Wed, 22 Dec 2010) $ - */ -/***************************************************************************** - * - * Copyright (c) 2008 - 2012, Advanced Micro Devices, Inc. - * All rights reserved. - * - * Redistribution and use in source and binary forms, with or without - * modification, are permitted provided that the following conditions are met: - * * Redistributions of source code must retain the above copyright - * notice, this list of conditions and the following disclaimer. - * * Redistributions in binary form must reproduce the above copyright - * notice, this list of conditions and the following disclaimer in the - * documentation and/or other materials provided with the distribution. - * * Neither the name of Advanced Micro Devices, Inc. nor the names of - * its contributors may be used to endorse or promote products derived - * from this software without specific prior written permission. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND - * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED - * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL ADVANCED MICRO DEVICES, INC. BE LIABLE FOR ANY - * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES - * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; - * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND - * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT - * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS - * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. - * - ***************************************************************************/ - -#ifndef _PORTING_H_ -#define _PORTING_H_ - -#if defined (_MSC_VER) - #include <intrin.h> - void _disable (void); - void _enable (void); - #pragma warning(disable: 4103 4001 4733) - #pragma intrinsic (_disable, _enable) - #pragma warning(push) - // ----------------------------------------------------------------------- - // Define a code_seg MACRO - // - #define MAKE_AS_A_STRING(arg) #arg - - #define CODE_GROUP(arg) __pragma (code_seg (MAKE_AS_A_STRING (.t##arg))) - - #define RDATA_GROUP(arg) __pragma (const_seg (MAKE_AS_A_STRING (.d##arg))) - #define FUNC_ATTRIBUTE(arg) __declspec(arg) - //#include <intrin.h> // MS has built-in functions - - #if _MSC_VER < 900 - // ----------------------------------------------------------------------- - // Assume MSVC 1.52C (16-bit) - // - // NOTE: When using MSVC 1.52C use the following command line: - // - // CL.EXE /G3 /AL /O1i /Fa <FILENAME.C> - // - // This will produce 32-bit code in USE16 segment that is optimized for code - // size. - typedef void VOID; - - // Create the universal 32, 16, and 8-bit data types - typedef unsigned long UINTN; - typedef long INT32; - typedef unsigned long UINT32; - typedef int INT16; - typedef unsigned int UINT16; - typedef char INT8; - typedef unsigned char UINT8; - typedef char CHAR8; - typedef unsigned short CHAR16; - - /// struct for 16-bit environment handling of 64-bit value - typedef struct _UINT64 { - IN OUT UINT32 lo; ///< lower 32-bits of 64-bit value - IN OUT UINT32 hi; ///< highest 32-bits of 64-bit value - } UINT64; - - // Create the Boolean type - #define TRUE 1 - #define FALSE 0 - typedef unsigned char BOOLEAN; - - #define CONST const - #define STATIC static - #define VOLATILE volatile - #define CALLCONV __pascal - #define ROMDATA __based( __segname( "_CODE" ) ) - #define _16BYTE_ALIGN __declspec(align(16)) - - // Force tight packing of structures - // Note: Entire AGESA (Project / Solution) will be using pragma pack 1 - #pragma warning( disable : 4103 ) // Disable '#pragma pack' in .h warning - #pragma pack(1) - - // Disable WORD->BYTE automatic conversion warnings. Example: - // BYTE LocalByte; - // void MyFunc(BYTE val); - // - // MyFunc(LocalByte*2+1); // Warning, automatic conversion - // - // The problem is any time math is performed on a BYTE, it is converted to a - // WORD by MSVC 1.52c, and then when it is converted back to a BYTE, a warning - // is generated. Disable warning C4761 - #pragma warning( disable : 4761 ) - - #else - // ----------------------------------------------------------------------- - // Assume a 32-bit MSVC++ - // - // Disable the following warnings: - // 4100 - 'identifier' : unreferenced formal parameter - // 4276 - 'function' : no prototype provided; assumed no parameters - // 4214 - non standard extension used : bit field types other than int - // 4001 - nonstandard extension 'single line comment' was used - // 4142 - benign redefinition of type for following declaration - // - typedef char INT8 - #if defined (_M_IX86) - #pragma warning (disable: 4100 4276 4214 4001 4142 4305 4306) - - #ifndef VOID - typedef void VOID; - #endif - // Create the universal 32, 16, and 8-bit data types - #ifndef UINTN - typedef unsigned __w64 UINTN; - #endif - typedef __int64 INT64; - typedef unsigned __int64 UINT64; - typedef int INT32; - typedef unsigned int UINT32; - typedef short INT16; - typedef unsigned short UINT16; - typedef char INT8; - typedef unsigned char UINT8; - typedef char CHAR8; - typedef unsigned short CHAR16; - - // Create the Boolean type - #ifndef TRUE - #define TRUE 1 - #endif - #ifndef FALSE - #define FALSE 0 - #endif - typedef unsigned char BOOLEAN; - - // Force tight packing of structures - // Note: Entire AGESA (Project / Solution) will be using pragma pack 1 - #pragma pack(1) - - #define CONST const - #define STATIC static - #define VOLATILE volatile - #define CALLCONV - #define ROMDATA - #define _16BYTE_ALIGN __declspec(align(64)) - // 64 bit of compiler - #else - #pragma warning (disable: 4100 4276 4214 4001 4142 4305 4306 4366) - - #ifndef VOID - typedef void VOID; - #endif - // Create the universal 32, 16, and 8-bit data types - #ifndef UINTN - typedef unsigned __int64 UINTN; - #endif - typedef __int64 INT64; - typedef unsigned __int64 UINT64; - typedef int INT32; - typedef unsigned int UINT32; - typedef short INT16; - typedef unsigned short UINT16; - typedef char INT8; - typedef unsigned char UINT8; - typedef char CHAR8; - typedef unsigned short CHAR16; - - // Create the Boolean type - #ifndef TRUE - #define TRUE 1 - #endif - #ifndef FALSE - #define FALSE 0 - #endif - typedef unsigned char BOOLEAN; - - // Force tight packing of structures - // Note: Entire AGESA (Project / Solution) will be using pragma pack 1 - #pragma pack(1) - - #define CONST const - #define STATIC static - #define VOLATILE volatile - #define CALLCONV - #define ROMDATA - #endif - #endif - // ----------------------------------------------------------------------- - // End of MS compiler versions - -#elif defined __GNUC__ - - #define IN - #define OUT - #define STATIC static - #define VOLATILE volatile - #define TRUE 1 - #define FALSE 0 -// #undef CONST - #define CONST const - #define ROMDATA - #define CALLCONV - #define _16BYTE_ALIGN __attribute__ ((aligned (16))) - - typedef unsigned char BOOLEAN; - typedef signed char INT8; - typedef signed short INT16; - typedef signed long INT32; - typedef char CHAR8; - typedef unsigned char UINT8; - typedef unsigned short UINT16; - typedef unsigned long UINT32; - typedef unsigned long UINTN; - typedef unsigned long long UINT64; - typedef long long INT64; - typedef void VOID; - //typedef unsigned long size_t; - - //#include <intrin.h> // MingW-w64 library header -#pragma pack(1) - -#define CODE_GROUP(arg) -#define RDATA_GROUP(arg) - -#define FUNC_ATTRIBUTE(arg) __attribute__((arg)) -#define MAKE_AS_A_STRING(arg) #arg -#include <stddef.h> -#include "gcc-intrin.h" - -#include <assert.h> -#include <console/console.h> -#include <console/loglevel.h> - -#ifndef NULL - #define NULL (void *)0 -#endif - -#else - // ----------------------------------------------------------------------- - // Unknown or unsupported compiler - // - #error "Unknown compiler in use" -#endif - -// ----------------------------------------------------------------------- -// Common definitions for all compilers -// - -//Support forward reference construct -#define AGESA_FORWARD_DECLARATION(x) typedef struct _##x x - -// The following are use in conformance to the UEFI style guide -#define IN -#define OUT - -#endif // _PORTING_H_ diff --git a/src/vendorcode/amd/agesa/f15tn/Makefile.inc b/src/vendorcode/amd/agesa/f15tn/Makefile.inc index 4b44cef..db932e5 100644 --- a/src/vendorcode/amd/agesa/f15tn/Makefile.inc +++ b/src/vendorcode/amd/agesa/f15tn/Makefile.inc @@ -32,6 +32,7 @@ AGESA_ROOT = src/vendorcode/amd/agesa/f15tn
AGESA_INC = -Isrc/mainboard/$(MAINBOARDDIR) AGESA_INC += -I$(AGESA_ROOT) +AGESA_INC += -I$(AGESA_ROOT)../ AGESA_INC += -I$(AGESA_ROOT)/Include AGESA_INC += -I$(AGESA_ROOT)/Lib AGESA_INC += -I$(AGESA_ROOT)/Legacy diff --git a/src/vendorcode/amd/agesa/f15tn/Porting.h b/src/vendorcode/amd/agesa/f15tn/Porting.h deleted file mode 100644 index fc65cfc..0000000 --- a/src/vendorcode/amd/agesa/f15tn/Porting.h +++ /dev/null @@ -1,282 +0,0 @@ -/* $NoKeywords:$ */ -/** - * @file - * - * Describes compiler dependencies - to support several compile time environments - * - * Contains compiler environment porting descriptions - * - * @xrefitem bom "File Content Label" "Release Content" - * @e project: AGESA - * @e sub-project: Includes - * @e $Revision: 44324 $ @e $Date: 2010-12-22 03:16:51 -0600 (Wed, 22 Dec 2010) $ - */ -/***************************************************************************** - * - * Copyright (c) 2008 - 2012, Advanced Micro Devices, Inc. - * All rights reserved. - * - * Redistribution and use in source and binary forms, with or without - * modification, are permitted provided that the following conditions are met: - * * Redistributions of source code must retain the above copyright - * notice, this list of conditions and the following disclaimer. - * * Redistributions in binary form must reproduce the above copyright - * notice, this list of conditions and the following disclaimer in the - * documentation and/or other materials provided with the distribution. - * * Neither the name of Advanced Micro Devices, Inc. nor the names of - * its contributors may be used to endorse or promote products derived - * from this software without specific prior written permission. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND - * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED - * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL ADVANCED MICRO DEVICES, INC. BE LIABLE FOR ANY - * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES - * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; - * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND - * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT - * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS - * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. - * - ***************************************************************************/ - -#ifndef _PORTING_H_ -#define _PORTING_H_ - -#if defined (_MSC_VER) - #include <intrin.h> - void _disable (void); - void _enable (void); - #pragma warning(disable: 4103 4001 4733) - #pragma intrinsic (_disable, _enable) - #pragma warning(push) - // ----------------------------------------------------------------------- - // Define a code_seg MACRO - // - #define MAKE_AS_A_STRING(arg) #arg - - #define CODE_GROUP(arg) __pragma (code_seg (MAKE_AS_A_STRING (.t##arg))) - - #define RDATA_GROUP(arg) __pragma (const_seg (MAKE_AS_A_STRING (.d##arg))) - #define FUNC_ATTRIBUTE(arg) __declspec(arg) - //#include <intrin.h> // MS has built-in functions - - #if _MSC_VER < 900 - // ----------------------------------------------------------------------- - // Assume MSVC 1.52C (16-bit) - // - // NOTE: When using MSVC 1.52C use the following command line: - // - // CL.EXE /G3 /AL /O1i /Fa <FILENAME.C> - // - // This will produce 32-bit code in USE16 segment that is optimized for code - // size. - typedef void VOID; - - // Create the universal 32, 16, and 8-bit data types - typedef unsigned long UINTN; - typedef long INT32; - typedef unsigned long UINT32; - typedef int INT16; - typedef unsigned int UINT16; - typedef char INT8; - typedef unsigned char UINT8; - typedef char CHAR8; - typedef unsigned short CHAR16; - - /// struct for 16-bit environment handling of 64-bit value - typedef struct _UINT64 { - IN OUT UINT32 lo; ///< lower 32-bits of 64-bit value - IN OUT UINT32 hi; ///< highest 32-bits of 64-bit value - } UINT64; - - // Create the Boolean type - #define TRUE 1 - #define FALSE 0 - typedef unsigned char BOOLEAN; - - #define CONST const - #define STATIC static - #define VOLATILE volatile - #define CALLCONV __pascal - #define ROMDATA __based( __segname( "_CODE" ) ) - #define _16BYTE_ALIGN __declspec(align(16)) - - // Force tight packing of structures - // Note: Entire AGESA (Project / Solution) will be using pragma pack 1 - #pragma warning( disable : 4103 ) // Disable '#pragma pack' in .h warning - #pragma pack(1) - - // Disable WORD->BYTE automatic conversion warnings. Example: - // BYTE LocalByte; - // void MyFunc(BYTE val); - // - // MyFunc(LocalByte*2+1); // Warning, automatic conversion - // - // The problem is any time math is performed on a BYTE, it is converted to a - // WORD by MSVC 1.52c, and then when it is converted back to a BYTE, a warning - // is generated. Disable warning C4761 - #pragma warning( disable : 4761 ) - - #else - // ----------------------------------------------------------------------- - // Assume a 32-bit MSVC++ - // - // Disable the following warnings: - // 4100 - 'identifier' : unreferenced formal parameter - // 4276 - 'function' : no prototype provided; assumed no parameters - // 4214 - non standard extension used : bit field types other than int - // 4001 - nonstandard extension 'single line comment' was used - // 4142 - benign redefinition of type for following declaration - // - typedef char INT8 - #if defined (_M_IX86) - #pragma warning (disable: 4100 4276 4214 4001 4142 4305 4306) - - #ifndef VOID - typedef void VOID; - #endif - // Create the universal 32, 16, and 8-bit data types - #ifndef UINTN - typedef unsigned __w64 UINTN; - #endif - typedef __int64 INT64; - typedef unsigned __int64 UINT64; - typedef int INT32; - typedef unsigned int UINT32; - typedef short INT16; - typedef unsigned short UINT16; - typedef char INT8; - typedef unsigned char UINT8; - typedef char CHAR8; - typedef unsigned short CHAR16; - - // Create the Boolean type - #ifndef TRUE - #define TRUE 1 - #endif - #ifndef FALSE - #define FALSE 0 - #endif - typedef unsigned char BOOLEAN; - - // Force tight packing of structures - // Note: Entire AGESA (Project / Solution) will be using pragma pack 1 - #pragma pack(1) - - #define CONST const - #define STATIC static - #define VOLATILE volatile - #define CALLCONV - #define ROMDATA - #define _16BYTE_ALIGN __declspec(align(64)) - // 64 bit of compiler - #else - #pragma warning (disable: 4100 4276 4214 4001 4142 4305 4306 4366) - - #ifndef VOID - typedef void VOID; - #endif - // Create the universal 32, 16, and 8-bit data types - #ifndef UINTN - typedef unsigned __int64 UINTN; - #endif - typedef __int64 INT64; - typedef unsigned __int64 UINT64; - typedef int INT32; - typedef unsigned int UINT32; - typedef short INT16; - typedef unsigned short UINT16; - typedef char INT8; - typedef unsigned char UINT8; - typedef char CHAR8; - typedef unsigned short CHAR16; - - // Create the Boolean type - #ifndef TRUE - #define TRUE 1 - #endif - #ifndef FALSE - #define FALSE 0 - #endif - typedef unsigned char BOOLEAN; - - // Force tight packing of structures - // Note: Entire AGESA (Project / Solution) will be using pragma pack 1 - #pragma pack(1) - - #define CONST const - #define STATIC static - #define VOLATILE volatile - #define CALLCONV - #define ROMDATA - #endif - #endif - // ----------------------------------------------------------------------- - // End of MS compiler versions - -#elif defined __GNUC__ - - #define IN - #define OUT - #define STATIC static - #define VOLATILE volatile - #define TRUE 1 - #define FALSE 0 -// #undef CONST - #define CONST const - #define ROMDATA - #define CALLCONV - #define _16BYTE_ALIGN __attribute__ ((aligned (16))) - - typedef unsigned char BOOLEAN; - typedef signed char INT8; - typedef signed short INT16; - typedef signed long INT32; - typedef char CHAR8; - typedef unsigned char UINT8; - typedef unsigned short UINT16; - typedef unsigned long UINT32; - typedef unsigned long UINTN; - typedef unsigned long long UINT64; - typedef long long INT64; - typedef void VOID; - //typedef unsigned long size_t; - - //#include <intrin.h> // MingW-w64 library header -#pragma pack(1) - -#define CODE_GROUP(arg) -#define RDATA_GROUP(arg) - -#define FUNC_ATTRIBUTE(arg) __attribute__((arg)) -#define MAKE_AS_A_STRING(arg) #arg -#include <stddef.h> -#include "gcc-intrin.h" - -#include <assert.h> -#include <console/console.h> -#include <console/loglevel.h> - -#ifndef NULL - #define NULL (void *)0 -#endif - -#else - // ----------------------------------------------------------------------- - // Unknown or unsupported compiler - // - #error "Unknown compiler in use" -#endif - -// ----------------------------------------------------------------------- -// Common definitions for all compilers -// - -//Support forward reference construct -#define AGESA_FORWARD_DECLARATION(x) typedef struct _##x x - -// The following are use in conformance to the UEFI style guide -#define IN -#define OUT - -#endif // _PORTING_H_ diff --git a/src/vendorcode/amd/agesa/f16kb/Makefile.inc b/src/vendorcode/amd/agesa/f16kb/Makefile.inc index 164b305..0708dc3 100644 --- a/src/vendorcode/amd/agesa/f16kb/Makefile.inc +++ b/src/vendorcode/amd/agesa/f16kb/Makefile.inc @@ -32,6 +32,7 @@ AGESA_ROOT = src/vendorcode/amd/agesa/f16kb
AGESA_INC = -Isrc/mainboard/$(MAINBOARDDIR) AGESA_INC += -I$(AGESA_ROOT) +AGESA_INC += -I$(AGESA_ROOT)../ AGESA_INC += -I$(AGESA_ROOT)/Include AGESA_INC += -I$(AGESA_ROOT)/Lib AGESA_INC += -I$(AGESA_ROOT)/Legacy diff --git a/src/vendorcode/amd/agesa/f16kb/Porting.h b/src/vendorcode/amd/agesa/f16kb/Porting.h deleted file mode 100644 index fc65cfc..0000000 --- a/src/vendorcode/amd/agesa/f16kb/Porting.h +++ /dev/null @@ -1,282 +0,0 @@ -/* $NoKeywords:$ */ -/** - * @file - * - * Describes compiler dependencies - to support several compile time environments - * - * Contains compiler environment porting descriptions - * - * @xrefitem bom "File Content Label" "Release Content" - * @e project: AGESA - * @e sub-project: Includes - * @e $Revision: 44324 $ @e $Date: 2010-12-22 03:16:51 -0600 (Wed, 22 Dec 2010) $ - */ -/***************************************************************************** - * - * Copyright (c) 2008 - 2012, Advanced Micro Devices, Inc. - * All rights reserved. - * - * Redistribution and use in source and binary forms, with or without - * modification, are permitted provided that the following conditions are met: - * * Redistributions of source code must retain the above copyright - * notice, this list of conditions and the following disclaimer. - * * Redistributions in binary form must reproduce the above copyright - * notice, this list of conditions and the following disclaimer in the - * documentation and/or other materials provided with the distribution. - * * Neither the name of Advanced Micro Devices, Inc. nor the names of - * its contributors may be used to endorse or promote products derived - * from this software without specific prior written permission. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND - * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED - * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL ADVANCED MICRO DEVICES, INC. BE LIABLE FOR ANY - * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES - * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; - * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND - * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT - * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS - * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. - * - ***************************************************************************/ - -#ifndef _PORTING_H_ -#define _PORTING_H_ - -#if defined (_MSC_VER) - #include <intrin.h> - void _disable (void); - void _enable (void); - #pragma warning(disable: 4103 4001 4733) - #pragma intrinsic (_disable, _enable) - #pragma warning(push) - // ----------------------------------------------------------------------- - // Define a code_seg MACRO - // - #define MAKE_AS_A_STRING(arg) #arg - - #define CODE_GROUP(arg) __pragma (code_seg (MAKE_AS_A_STRING (.t##arg))) - - #define RDATA_GROUP(arg) __pragma (const_seg (MAKE_AS_A_STRING (.d##arg))) - #define FUNC_ATTRIBUTE(arg) __declspec(arg) - //#include <intrin.h> // MS has built-in functions - - #if _MSC_VER < 900 - // ----------------------------------------------------------------------- - // Assume MSVC 1.52C (16-bit) - // - // NOTE: When using MSVC 1.52C use the following command line: - // - // CL.EXE /G3 /AL /O1i /Fa <FILENAME.C> - // - // This will produce 32-bit code in USE16 segment that is optimized for code - // size. - typedef void VOID; - - // Create the universal 32, 16, and 8-bit data types - typedef unsigned long UINTN; - typedef long INT32; - typedef unsigned long UINT32; - typedef int INT16; - typedef unsigned int UINT16; - typedef char INT8; - typedef unsigned char UINT8; - typedef char CHAR8; - typedef unsigned short CHAR16; - - /// struct for 16-bit environment handling of 64-bit value - typedef struct _UINT64 { - IN OUT UINT32 lo; ///< lower 32-bits of 64-bit value - IN OUT UINT32 hi; ///< highest 32-bits of 64-bit value - } UINT64; - - // Create the Boolean type - #define TRUE 1 - #define FALSE 0 - typedef unsigned char BOOLEAN; - - #define CONST const - #define STATIC static - #define VOLATILE volatile - #define CALLCONV __pascal - #define ROMDATA __based( __segname( "_CODE" ) ) - #define _16BYTE_ALIGN __declspec(align(16)) - - // Force tight packing of structures - // Note: Entire AGESA (Project / Solution) will be using pragma pack 1 - #pragma warning( disable : 4103 ) // Disable '#pragma pack' in .h warning - #pragma pack(1) - - // Disable WORD->BYTE automatic conversion warnings. Example: - // BYTE LocalByte; - // void MyFunc(BYTE val); - // - // MyFunc(LocalByte*2+1); // Warning, automatic conversion - // - // The problem is any time math is performed on a BYTE, it is converted to a - // WORD by MSVC 1.52c, and then when it is converted back to a BYTE, a warning - // is generated. Disable warning C4761 - #pragma warning( disable : 4761 ) - - #else - // ----------------------------------------------------------------------- - // Assume a 32-bit MSVC++ - // - // Disable the following warnings: - // 4100 - 'identifier' : unreferenced formal parameter - // 4276 - 'function' : no prototype provided; assumed no parameters - // 4214 - non standard extension used : bit field types other than int - // 4001 - nonstandard extension 'single line comment' was used - // 4142 - benign redefinition of type for following declaration - // - typedef char INT8 - #if defined (_M_IX86) - #pragma warning (disable: 4100 4276 4214 4001 4142 4305 4306) - - #ifndef VOID - typedef void VOID; - #endif - // Create the universal 32, 16, and 8-bit data types - #ifndef UINTN - typedef unsigned __w64 UINTN; - #endif - typedef __int64 INT64; - typedef unsigned __int64 UINT64; - typedef int INT32; - typedef unsigned int UINT32; - typedef short INT16; - typedef unsigned short UINT16; - typedef char INT8; - typedef unsigned char UINT8; - typedef char CHAR8; - typedef unsigned short CHAR16; - - // Create the Boolean type - #ifndef TRUE - #define TRUE 1 - #endif - #ifndef FALSE - #define FALSE 0 - #endif - typedef unsigned char BOOLEAN; - - // Force tight packing of structures - // Note: Entire AGESA (Project / Solution) will be using pragma pack 1 - #pragma pack(1) - - #define CONST const - #define STATIC static - #define VOLATILE volatile - #define CALLCONV - #define ROMDATA - #define _16BYTE_ALIGN __declspec(align(64)) - // 64 bit of compiler - #else - #pragma warning (disable: 4100 4276 4214 4001 4142 4305 4306 4366) - - #ifndef VOID - typedef void VOID; - #endif - // Create the universal 32, 16, and 8-bit data types - #ifndef UINTN - typedef unsigned __int64 UINTN; - #endif - typedef __int64 INT64; - typedef unsigned __int64 UINT64; - typedef int INT32; - typedef unsigned int UINT32; - typedef short INT16; - typedef unsigned short UINT16; - typedef char INT8; - typedef unsigned char UINT8; - typedef char CHAR8; - typedef unsigned short CHAR16; - - // Create the Boolean type - #ifndef TRUE - #define TRUE 1 - #endif - #ifndef FALSE - #define FALSE 0 - #endif - typedef unsigned char BOOLEAN; - - // Force tight packing of structures - // Note: Entire AGESA (Project / Solution) will be using pragma pack 1 - #pragma pack(1) - - #define CONST const - #define STATIC static - #define VOLATILE volatile - #define CALLCONV - #define ROMDATA - #endif - #endif - // ----------------------------------------------------------------------- - // End of MS compiler versions - -#elif defined __GNUC__ - - #define IN - #define OUT - #define STATIC static - #define VOLATILE volatile - #define TRUE 1 - #define FALSE 0 -// #undef CONST - #define CONST const - #define ROMDATA - #define CALLCONV - #define _16BYTE_ALIGN __attribute__ ((aligned (16))) - - typedef unsigned char BOOLEAN; - typedef signed char INT8; - typedef signed short INT16; - typedef signed long INT32; - typedef char CHAR8; - typedef unsigned char UINT8; - typedef unsigned short UINT16; - typedef unsigned long UINT32; - typedef unsigned long UINTN; - typedef unsigned long long UINT64; - typedef long long INT64; - typedef void VOID; - //typedef unsigned long size_t; - - //#include <intrin.h> // MingW-w64 library header -#pragma pack(1) - -#define CODE_GROUP(arg) -#define RDATA_GROUP(arg) - -#define FUNC_ATTRIBUTE(arg) __attribute__((arg)) -#define MAKE_AS_A_STRING(arg) #arg -#include <stddef.h> -#include "gcc-intrin.h" - -#include <assert.h> -#include <console/console.h> -#include <console/loglevel.h> - -#ifndef NULL - #define NULL (void *)0 -#endif - -#else - // ----------------------------------------------------------------------- - // Unknown or unsupported compiler - // - #error "Unknown compiler in use" -#endif - -// ----------------------------------------------------------------------- -// Common definitions for all compilers -// - -//Support forward reference construct -#define AGESA_FORWARD_DECLARATION(x) typedef struct _##x x - -// The following are use in conformance to the UEFI style guide -#define IN -#define OUT - -#endif // _PORTING_H_
