Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/15467
commit 60f50d4e060a9cc237e8fd1b5b6f0a17d71da1aa Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Mon Jun 27 15:25:14 2016 +0300
AMD binaryPI: Split romstage ram stack
Change-Id: Ibbff1fdb1af247550815532ef12f078229f12321 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/cpu/amd/pi/heapmanager.c | 10 +++------- src/cpu/amd/pi/s3_resume.c | 9 +++++---- src/cpu/amd/pi/s3_resume.h | 8 ++++++++ 3 files changed, 16 insertions(+), 11 deletions(-)
diff --git a/src/cpu/amd/pi/heapmanager.c b/src/cpu/amd/pi/heapmanager.c index c5e4202..d4a79b8 100644 --- a/src/cpu/amd/pi/heapmanager.c +++ b/src/cpu/amd/pi/heapmanager.c @@ -25,13 +25,9 @@ UINT32 GetHeapBase(AMD_CONFIG_PARAMS *StdHeader) { UINT32 heap = BIOS_HEAP_START_ADDRESS;
-#if CONFIG_HAVE_ACPI_RESUME - /* Both romstage and ramstage has this S3 detect. */ - if (acpi_get_sleep_type() == 3) - heap = (UINT32) cbmem_find(CBMEM_ID_RESUME_SCRATCH) + - (CONFIG_HIGH_SCRATCH_MEMORY_SIZE - BIOS_HEAP_SIZE); - /* himem_heap_base + high_stack_size */ -#endif + if (acpi_is_wakeup_s3()) + heap = (UINT32) cbmem_find(CBMEM_ID_RESUME_SCRATCH); + return heap; }
diff --git a/src/cpu/amd/pi/s3_resume.c b/src/cpu/amd/pi/s3_resume.c index 576a208..830d174 100644 --- a/src/cpu/amd/pi/s3_resume.c +++ b/src/cpu/amd/pi/s3_resume.c @@ -137,11 +137,12 @@ void restore_mtrr(void) #ifdef __PRE_RAM__ static void move_stack_high_mem(void) { - void *high_stack; + void *high_stack = cbmem_find(CBMEM_ID_ROMSTAGE_RAM_STACK); + if (high_stack == NULL) + halt();
- high_stack = cbmem_find(CBMEM_ID_RESUME_SCRATCH); - memcpy(high_stack, (void *)BSP_STACK_BASE_ADDR, - (CONFIG_HIGH_SCRATCH_MEMORY_SIZE - BIOS_HEAP_SIZE)); + /* TODO: Make the switch with empty stack instead. */ + memcpy(high_stack, (void *)BSP_STACK_BASE_ADDR, HIGH_ROMSTAGE_STACK_SIZE);
#ifdef __x86_64__ __asm__ diff --git a/src/cpu/amd/pi/s3_resume.h b/src/cpu/amd/pi/s3_resume.h index f952055..3b6ecfa 100644 --- a/src/cpu/amd/pi/s3_resume.h +++ b/src/cpu/amd/pi/s3_resume.h @@ -31,4 +31,12 @@ void OemAgesaSaveMtrr (void);
void spi_SaveS3info(u32 pos, u32 size, u8 *buf, u32 len);
+#if 1 +/* This covers node 0 only. */ +#define HIGH_ROMSTAGE_STACK_SIZE (0x48000 - BSP_STACK_BASE_ADDR) +#else +/* This covers total of 8 nodes. */ +#define HIGH_ROMSTAGE_STACK_SIZE (0xA0000 - BSP_STACK_BASE_ADDR) +#endif + #endif
