Martin Roth (martinroth@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/12654
commit a3d77da697d1c6131002c6eac4f9ed02f7750e82 Author: Martin Roth martinroth@google.com Date: Sun Dec 6 12:13:11 2015 -0700
libpayload/configs/config.veyron: Use CONFIG_LP_8250_SERIAL_CONSOLE
- Update to use the CONFIG_LP_8250_SERIAL_CONSOLE instead of the removed CONFIG_LP_8250_MMIO32_SERIAL_CONSOLE. - CONFIG_LP_LZ4 and CONFIG_LP_PL011_SERIAL_CONSOLE are set to the default values for these new config options.
CONFIG_LP_8250_MMIO32_SERIAL_CONSOLE was removed in commit 4d5317e5 (libpayload: Remove redundant 8250 MMIO32 UART driver)
Change-Id: I97461c5e0c14075dcf8a35c96a0b0f1651e2e8e4 Signed-off-by: Martin Roth martinroth@google.com --- payloads/libpayload/configs/config.veyron | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/payloads/libpayload/configs/config.veyron b/payloads/libpayload/configs/config.veyron index 8843098..aca5817 100644 --- a/payloads/libpayload/configs/config.veyron +++ b/payloads/libpayload/configs/config.veyron @@ -30,6 +30,7 @@ CONFIG_LP_LIBC=y # CONFIG_LP_CURSES is not set CONFIG_LP_CBFS=y CONFIG_LP_LZMA=y +CONFIG_LP_LZ4=y
# # Console Options @@ -37,11 +38,11 @@ CONFIG_LP_LZMA=y CONFIG_LP_SKIP_CONSOLE_INIT=y CONFIG_LP_CBMEM_CONSOLE=y CONFIG_LP_SERIAL_CONSOLE=y -# CONFIG_LP_8250_SERIAL_CONSOLE is not set +CONFIG_LP_8250_SERIAL_CONSOLE=y # CONFIG_LP_S5P_SERIAL_CONSOLE is not set -CONFIG_LP_8250_MMIO32_SERIAL_CONSOLE=y # CONFIG_LP_IPQ806X_SERIAL_CONSOLE is not set # CONFIG_LP_BG4CD_SERIAL_CONSOLE is not set +# CONFIG_LP_PL011_SERIAL_CONSOLE is not set # CONFIG_LP_SERIAL_SET_SPEED is not set # CONFIG_LP_SERIAL_ACS_FALLBACK is not set CONFIG_LP_VIDEO_CONSOLE=y
