Mike Banon has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/33917
Change subject: src/mainboard/asus/am1i-a/buildOpts.c: add includes for adjusting RAM timings ......................................................................
These tables may be used to adjust memory timing settings.
Signed-off-by: Mike Banon mikebdp2@gmail.com Change-Id: I782f76119c5ce9a3cc4bc07596d27dd42b615b6d --- M src/mainboard/asus/am1i-a/buildOpts.c 1 file changed, 3 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/17/33917/1
diff --git a/src/mainboard/asus/am1i-a/buildOpts.c b/src/mainboard/asus/am1i-a/buildOpts.c index dfd27cd..643b306 100644 --- a/src/mainboard/asus/am1i-a/buildOpts.c +++ b/src/mainboard/asus/am1i-a/buildOpts.c @@ -42,6 +42,9 @@ #include <vendorcode/amd/agesa/f16kb/Proc/Common/CreateStruct.h> #include <vendorcode/amd/agesa/f16kb/Proc/CPU/cpuEarlyInit.h> #include <vendorcode/amd/agesa/f16kb/Proc/CPU/cpuLateInit.h> +/* These tables are optional and may be used to adjust memory timing settings */ +#include <vendorcode/amd/agesa/f16kb/Proc/Mem/mm.h> +#include <vendorcode/amd/agesa/f16kb/Proc/Mem/mn.h>
/* Select the CPU family. */ #define INSTALL_FAMILY_16_MODEL_0x_SUPPORT TRUE
Mike Banon has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/33917 )
Patch Set 1:
am1i-a/buildOpts.c patch series [5/8] : 1st = CB:33913 , 2nd = CB:33914 , 3rd = CB:33915 , 4th = CB:33916 ; 5th = CB:33917 <-- you are here ; 6th = CB:33918 , 7th = CB:33919 , 8th = CB:33920
Patch Set 1:
I'm not using them yet, but they might become useful soon...
Hello build bot (Jenkins),
Change subject: mb/asus/am1i-a/buildOpts.c: add includes for adjusting RAM timings ......................................................................
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/17/33917/6
Patch Set 6:
Same SHA256 when built with "make BUILD_TIMELESS=1" - probably because I didn't use anything from these includes yet.
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/33917 )
Patch Set 6:
Patch Set 6:
Maybe include them in the patch that uses them?
These tables may be used to adjust memory timing settings. Tested with BUILD_TIMELESS=1, hashes do not change.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/17/33917/8
Patch Set 8:
Patch Set 6:
Patch Set 6:
Would be nice to have these includes already in place, also considering that the other boards like G505S have them.
HAOUAS Elyes has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/33917 )
Patch Set 8:
why? are those included used?
Mike Banon has abandoned this change. ( https://review.coreboot.org/c/coreboot/+/33917 )
Abandoned
Working setup for the memory timings: see CB:40489 and other AMD_XMP.
