Naresh Solanki (naresh.solanki@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/17247
commit 11c75ee1bfeb8c713060f2336f6ee4902e9f1a45 Author: Naresh G Solanki naresh.solanki@intel.com Date: Sun Nov 6 13:37:34 2016 +0530
intel/kblrvp: Update mainboard configuration
Update devicetree.cb as per RVP3 mainboard.
Disable pull down for power button in gpio.h.
Change-Id: I235a1d44dabef16ded2aaad13aef36ca57f37c8e Signed-off-by: Naresh G Solanki naresh.solanki@intel.com --- src/mainboard/intel/kblrvp/devicetree.cb | 192 ++++++++++--------------------- src/mainboard/intel/kblrvp/gpio.h | 4 +- 2 files changed, 64 insertions(+), 132 deletions(-)
diff --git a/src/mainboard/intel/kblrvp/devicetree.cb b/src/mainboard/intel/kblrvp/devicetree.cb index 8dded98..ad4d877 100644 --- a/src/mainboard/intel/kblrvp/devicetree.cb +++ b/src/mainboard/intel/kblrvp/devicetree.cb @@ -1,14 +1,14 @@ chip soc/intel/skylake
# Enable deep Sx states - register "deep_s5_enable" = "1" + register "deep_s5_enable" = "0" register "deep_sx_config" = "DSX_EN_LAN_WAKE_PIN"
# GPE configuration # Note that GPE events called out in ASL code rely on this # route. i.e. If this route changes then the affected GPE # offset bits also need to be changed. - register "gpe0_dw0" = "GPP_B" + register "gpe0_dw0" = "GPP_C" register "gpe0_dw1" = "GPP_D" register "gpe0_dw2" = "GPP_E"
@@ -23,9 +23,6 @@ chip soc/intel/skylake register "dptf_enable" = "1"
# FSP Configuration - register "EnableAzalia" = "1" - register "DspEnable" = "1" - register "IoBufferOwnership" = "3" register "SmbusEnable" = "1" register "ScsEmmcEnabled" = "1" register "ScsEmmcHs400Enabled" = "1" @@ -63,23 +60,10 @@ chip soc/intel/skylake register "SerialIrqConfigSirqEnable" = "0x01"
# VR Settings Configuration for 5 Domains - #+----------------+-------+-------+-------------+-------------+-------+ - #| Domain/Setting | SA | IA | Ring Sliced | GT Unsliced | GT | - #+----------------+-------+-------+-------------+-------------+-------+ - #| Psi1Threshold | 20A | 20A | 20A | 20A | 20A | - #| Psi2Threshold | 4A | 5A | 5A | 5A | 5A | - #| Psi3Threshold | 1A | 1A | 1A | 1A | 1A | - #| Psi3Enable | 1 | 1 | 1 | 1 | 1 | - #| Psi4Enable | 1 | 1 | 1 | 1 | 1 | - #| ImonSlope | 0 | 0 | 0 | 0 | 0 | - #| ImonOffset | 0 | 0 | 0 | 0 | 0 | - #| IccMax | 7A | 34A | 34A | 35A | 35A | - #| VrVoltageLimit | 1.52V | 1.52V | 1.52V | 1.52V | 1.52V | - #+----------------+-------+-------+-------------+-------------+-------+ register "domain_vr_config[VR_SYSTEM_AGENT]" = "{ .vr_config_enable = 1, \ .psi1threshold = 0x50, \ - .psi2threshold = 0x10, \ + .psi2threshold = 0x14, \ .psi3threshold = 0x4, \ .psi3enable = 1, \ .psi4enable = 1, \ @@ -124,7 +108,7 @@ chip soc/intel/skylake .imon_slope = 0x0, \ .imon_offset = 0x0, \ .icc_max = 0x8C ,\ - .voltage_limit = 0x5F0 \ + .voltage_limit = 0x5F0, \ }"
register "domain_vr_config[VR_GT_SLICED]" = "{ @@ -142,29 +126,56 @@ chip soc/intel/skylake
register "FspSkipMpInit" = "1"
- # Enable Root port 1 and 5. + # Enable Root ports. + # PCIE Port 1 x4 -> SLOT1 register "PcieRpEnable[0]" = "1" - register "PcieRpEnable[4]" = "1" - # Enable CLKREQ# register "PcieRpClkReqSupport[0]" = "1" - register "PcieRpClkReqSupport[4]" = "1" - # RP 1 uses SRCCLKREQ1# while RP 5 uses SRCCLKREQ2# - register "PcieRpClkReqNumber[0]" = "1" - register "PcieRpClkReqNumber[4]" = "2" + register "PcieRpClkReqNumber[0]" = "2"
- register "usb2_ports[0]" = "USB2_PORT_TYPE_C" # Type-C Port 1 - register "usb2_ports[1]" = "USB2_PORT_TYPE_C" # Type-C Port 2 - register "usb2_ports[2]" = "USB2_PORT_MID" # Bluetooth - register "usb2_ports[4]" = "USB2_PORT_MID" # Type-A Port (card) - register "usb2_ports[6]" = "USB2_PORT_FLEX" # Camera - register "usb2_ports[8]" = "USB2_PORT_LONG" # Type-A Port (board) - - register "usb3_ports[0]" = "USB3_PORT_DEFAULT" # Type-C Port 1 - register "usb3_ports[1]" = "USB3_PORT_DEFAULT" # Type-C Port 2 - register "usb3_ports[2]" = "USB3_PORT_DEFAULT" # Type-A Port (card) - register "usb3_ports[3]" = "USB3_PORT_DEFAULT" # Type-A Port (board) - - register "i2c[4].voltage" = "I2C_VOLTAGE_1V8" # I2C4 is 1.8V + # PCIE Port 5 x1 -> SLOT2/LAN + register "PcieRpEnable[4]" = "1" + register "PcieRpClkReqSupport[4]" = "1" + register "PcieRpClkReqNumber[4]" = "3" + + # PCIE Port 6 x1 -> SLOT3 + register "PcieRpEnable[5]" = "1" + register "PcieRpClkReqSupport[5]" = "1" + register "PcieRpClkReqNumber[5]" = "1" + + # PCIE Port 7 Disabled + # PCIE Port 8 Disabled + # PCIE Port 9 x1 -> WLAN + register "PcieRpEnable[8]" = "1" + register "PcieRpClkReqSupport[8]" = "1" + register "PcieRpClkReqNumber[8]" = "5" + + # PCIE Port 10 x1 -> WiGig + register "PcieRpEnable[9]" = "1" + register "PcieRpClkReqSupport[9]" = "1" + register "PcieRpClkReqNumber[9]" = "4" + + # USB 2.0 Enable all ports + register "usb2_ports[0]" = "USB2_PORT_MAX" # TYPE-A Port + register "usb2_ports[1]" = "USB2_PORT_MAX" # TYPE-A Port + register "usb2_ports[2]" = "USB2_PORT_MAX" # Bluetooth + register "usb2_ports[4]" = "USB2_PORT_MAX" # Type-A Port + register "usb2_ports[5]" = "USB2_PORT_MAX" # TYPE-A Port + register "usb2_ports[6]" = "USB2_PORT_MAX" # TYPE-A Port + register "usb2_ports[7]" = "USB2_PORT_MAX" # TYPE-A Port + register "usb2_ports[8]" = "USB2_PORT_MAX" # TYPE-A Port + register "usb2_ports[9]" = "USB2_PORT_MAX" # TYPE-A Port + register "usb2_ports[10]" = "USB2_PORT_MAX" # TYPE-A Port + register "usb2_ports[11]" = "USB2_PORT_MAX" # TYPE-A Port + + # USB 3.0 Enable Port 1-4. Port 5 & 6 Disabled + register "usb3_ports[0]" = "USB3_PORT_DEFAULT" # TYPE-A Port + register "usb3_ports[1]" = "USB3_PORT_DEFAULT" # TYPE-A Port + register "usb3_ports[2]" = "USB3_PORT_DEFAULT" # TYPE-A Port + register "usb3_ports[3]" = "USB3_PORT_DEFAULT" # TYPE-A Port + register "usb3_ports[4]" = "USB3_PORT_EMPTY" # Disabled + register "usb3_ports[5]" = "USB3_PORT_EMPTY" # Disabled + + register "SsicPortEnable" = "1" # Enable SSIC for WWAN
# Must leave UART0 enabled or SD/eMMC will not work as PCI register "SerialIoDevMode" = "{ \ @@ -181,9 +192,6 @@ chip soc/intel/skylake [PchSerialIoIndexUart2] = PchSerialIoSkipInit, \ }"
- # PL2 override 25W - register "tdp_pl2_override" = "25" - # Send an extra VR mailbox command for the PS4 exit issue register "SendVrMbxCmd" = "2"
@@ -191,7 +199,7 @@ chip soc/intel/skylake register "VmxEnable" = "0"
# Use default SD card detect GPIO configuration - register "sdcard_cd_gpio_default" = "GPP_A7" + register "sdcard_cd_gpio_default" = "GPP_D10"
device cpu_cluster 0 on device lapic 0 on end @@ -202,23 +210,8 @@ chip soc/intel/skylake device pci 14.0 on end # USB xHCI device pci 14.1 off end # USB xDCI (OTG) device pci 14.2 on end # Thermal Subsystem - device pci 15.0 on - chip drivers/i2c/generic - register "hid" = ""ELAN0001"" - register "desc" = ""ELAN Touchscreen"" - register "irq" = "IRQ_EDGE_LOW(GPP_E7_IRQ)" - device i2c 10 on end - end - end # I2C #0 - device pci 15.1 on - chip drivers/i2c/generic - register "hid" = ""ELAN0000"" - register "desc" = ""ELAN Touchpad"" - register "irq" = "IRQ_EDGE_LOW(GPP_B3_IRQ)" - register "wake" = "GPE0_DW0_05" - device i2c 15 on end - end - end # I2C #1 + device pci 15.0 on end # I2C #0 + device pci 15.1 on end # I2C #1 device pci 15.2 off end # I2C #2 device pci 15.3 off end # I2C #3 device pci 16.0 on end # Management Engine Interface 1 @@ -229,61 +222,14 @@ chip soc/intel/skylake device pci 17.0 off end # SATA device pci 19.0 on end # UART #2 device pci 19.1 off end # I2C #5 - device pci 19.2 on - chip drivers/i2c/nau8825 - register "irq" = "IRQ_LEVEL_LOW(GPP_F10_IRQ)" - register "jkdet_enable" = "1" - register "jkdet_pull_enable" = "1" - register "jkdet_pull_up" = "1" - register "jkdet_polarity" = "1" # ActiveLow - register "vref_impedance" = "2" # 125kOhm - register "micbias_voltage" = "6" # 2.754 - register "sar_threshold_num" = "4" - register "sar_threshold[0]" = "0x08" - register "sar_threshold[1]" = "0x12" - register "sar_threshold[2]" = "0x26" - register "sar_threshold[3]" = "0x73" - register "sar_hysteresis" = "0" - register "sar_voltage" = "6" - register "sar_compare_time" = "1" # 1us - register "sar_sampling_time" = "1" # 4us - register "short_key_debounce" = "3" # 30ms - register "jack_insert_debounce" = "7" # 512ms - register "jack_eject_debounce" = "0" - device i2c 1a on end - end - chip drivers/i2c/generic - register "hid" = ""INT343B"" - register "desc" = ""SSM4567 Left Speaker Amp"" - register "uid" = "0" - register "device_present_gpio" = "GPP_E3" - device i2c 34 on end - end - chip drivers/i2c/generic - register "hid" = ""INT343B"" - register "desc" = ""SSM4567 Right Speaker Amp"" - register "uid" = "1" - register "device_present_gpio" = "GPP_E3" - device i2c 35 on end - end - end # I2C #4 - device pci 1c.0 on - chip drivers/intel/wifi - register "wake" = "GPE0_DW0_16" - device pci 00.0 on end - end - end # PCI Express Port 1 - device pci 1c.1 off end # PCI Express Port 2 - device pci 1c.2 off end # PCI Express Port 3 - device pci 1c.3 off end # PCI Express Port 4 - device pci 1c.4 on end # PCI Express Port 5 - device pci 1c.5 off end # PCI Express Port 6 + device pci 19.2 on end + device pci 1c.0 on end # PCI Express Port 1 x4 SLOT1 + device pci 1c.4 on end # PCI Express Port 5 x1 SLOT2/LAN + device pci 1c.5 on end # PCI Express Port 6 x1 SLOT3 device pci 1c.6 off end # PCI Express Port 7 device pci 1c.7 off end # PCI Express Port 8 - device pci 1d.0 off end # PCI Express Port 9 - device pci 1d.1 off end # PCI Express Port 10 - device pci 1d.2 off end # PCI Express Port 11 - device pci 1d.3 off end # PCI Express Port 12 + device pci 1d.0 on end # PCI Express Port 9 x1 WLAN + device pci 1d.1 on end # PCI Express Port 10 x1 WIGIG device pci 1e.0 on end # UART #0 device pci 1e.1 off end # UART #1 device pci 1e.2 off end # GSPI #0 @@ -291,24 +237,10 @@ chip soc/intel/skylake device pci 1e.4 on end # eMMC device pci 1e.5 off end # SDIO device pci 1e.6 on end # SDCard - device pci 1f.0 on - chip drivers/pc80/tpm - device pnp 0c31.0 on end - end - chip ec/google/chromeec - device pnp 0c09.0 on end - end - end # LPC Interface + device pci 1f.0 on end # LPC Interface device pci 1f.1 on end # P2SB device pci 1f.2 on end # Power Management Controller - device pci 1f.3 on - chip drivers/generic/max98357a - register "sdmode_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_E3)" - register "device_present_gpio" = "GPP_E3" - register "device_present_gpio_invert" = "1" - device generic 0 on end - end - end # Intel HDA + device pci 1f.3 on end # Intel HDA device pci 1f.4 on end # SMBus device pci 1f.5 on end # PCH SPI device pci 1f.6 off end # GbE diff --git a/src/mainboard/intel/kblrvp/gpio.h b/src/mainboard/intel/kblrvp/gpio.h index f8ee994..5e251d8 100644 --- a/src/mainboard/intel/kblrvp/gpio.h +++ b/src/mainboard/intel/kblrvp/gpio.h @@ -185,7 +185,7 @@ static const struct pad_config gpio_table[] = { /* PCH_BATLOW */ PAD_CFG_NF(GPD0, NONE, DEEP, NF1), /* AC_PRESENT */ PAD_CFG_NF(GPD1, NONE, DEEP, NF1), /* PCH_WAKE */ PAD_CFG_NF(GPD2, NONE, DEEP, NF1), -/* PCH_PWRBTN */ PAD_CFG_NF(GPD3, 20K_PD, DEEP, NF1), +/* PCH_PWRBTN */ PAD_CFG_NF(GPD3, NONE, DEEP, NF1), /* PM_SLP_S3# */ PAD_CFG_NF(GPD4, NONE, DEEP, NF1), /* PM_SLP_S4# */ PAD_CFG_NF(GPD5, NONE, DEEP, NF1), /* PM_SLP_SA# */ PAD_CFG_NF(GPD6, NONE, DEEP, NF1), @@ -204,4 +204,4 @@ static const struct pad_config early_gpio_table[] = {
#endif
-#endif \ No newline at end of file +#endif
