Marshall Dawson has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/33765
Change subject: soc/amd/picasso: Update calculation for TSC frequency ......................................................................
Remove the Family 15h step of finding the number of boost states and get the frequency directly out of the Pstate0 register.
Signed-off-by: Marshall Dawson marshalldawson3rd@gmail.com Change-Id: I909743483309279eb8c3bf68852d6082381f0dff --- M src/soc/amd/picasso/tsc_freq.c 1 file changed, 3 insertions(+), 13 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/65/33765/1
diff --git a/src/soc/amd/picasso/tsc_freq.c b/src/soc/amd/picasso/tsc_freq.c index 29121b9..2277b33 100644 --- a/src/soc/amd/picasso/tsc_freq.c +++ b/src/soc/amd/picasso/tsc_freq.c @@ -19,26 +19,16 @@ #include <cpu/amd/msr.h> #include <cpu/x86/tsc.h> #include <console/console.h> -#include <soc/pci_devs.h> -#include <device/pci_ops.h>
unsigned long tsc_freq_mhz(void) { msr_t msr; uint8_t cpufid; uint8_t cpudid; - uint8_t boost_states; + uint8_t high_state;
- /* - * See the Family 15h Models 70h-7Fh BKDG (PID 55072) definition for - * MSR0000_0010. The TSC increments at the P0 frequency. According - * to the "Software P-state Numbering" section, P0 is the highest - * non-boosted state. freq = 100MHz * (CpuFid + 10h) / (2^(CpuDid)). - */ - boost_states = (pci_read_config32(SOC_PM_DEV, CORE_PERF_BOOST_CTRL) - >> 2) & 0x7; - - msr = rdmsr(PSTATE_0_MSR + boost_states); + high_state = rdmsr(PS_LIM_REG).lo & 0x7; + msr = rdmsr(PSTATE_0_MSR + high_state); if (!(msr.hi & 0x80000000)) die("Unknown error: cannot determine P-state 0\n");
Kyösti Mälkki has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/33765 )
Patch Set 4:
https://review.coreboot.org/c/coreboot/+/33765/4/src/soc/amd/picasso/tsc_fre... File src/soc/amd/picasso/tsc_freq.c:
https://review.coreboot.org/c/coreboot/+/33765/4/src/soc/amd/picasso/tsc_fre... PS4, Line 38: return (100 * (cpufid + 0x10)) / (0x01 << cpudid); If this is constant, you may want to cache the result (declare static variable for return value) as rdmsr is sometimes heavy for execution and worth skipping when possible.
Marshall Dawson has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/33765 )
Change subject: soc/amd/picasso: Update TSC and monotonic timer ......................................................................
Patch Set 11:
If this is constant, you may want to cache the result (declare static variable for return value) as […]
Done. Unsure how long the cycle takes for this register.
Richard Spiegel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/33765 )
Patch Set 13: Code-Review+2
Patch Set 14: Code-Review+2
Martin Roth has submitted this change. ( https://review.coreboot.org/c/coreboot/+/33765 )
Picasso's TimeStamp Counter is a new design and different than Stoney Ridge. Although advertised as invariant, the ST TSC did not become so until midway through POST making it an unreliable source for measuring time. This is not the case for Picasso.
Remove the Stoney Ridge monotonic timer code and rely on the TSC.
Modify the calculation used in Family 15h of finding the number of boost states first, and get the frequency directly out of the Pstate0 register.
Signed-off-by: Marshall Dawson marshalldawson3rd@gmail.com Change-Id: I909743483309279eb8c3bf68852d6082381f0dff Reviewed-on: https://review.coreboot.org/c/coreboot/+/33765 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Richard Spiegel richard.spiegel@silverbackltd.com --- M src/soc/amd/picasso/Kconfig M src/soc/amd/picasso/Makefile.inc D src/soc/amd/picasso/monotonic_timer.c M src/soc/amd/picasso/tsc_freq.c 4 files changed, 12 insertions(+), 61 deletions(-)
Approvals: build bot (Jenkins): Verified Richard Spiegel: Looks good to me, approved
diff --git a/src/soc/amd/picasso/Kconfig b/src/soc/amd/picasso/Kconfig index 26b2ec4..b3ee50c 100644 --- a/src/soc/amd/picasso/Kconfig +++ b/src/soc/amd/picasso/Kconfig @@ -29,14 +29,15 @@ select X86_AMD_FIXED_MTRRS select X86_AMD_INIT_SIPI select ACPI_AMD_HARDWARE_SLEEP_VALUES - select COLLECT_TIMESTAMPS_NO_TSC select DRIVERS_I2C_DESIGNWARE select GENERIC_GPIO_LIB - select GENERIC_UDELAY select IOAPIC select HAVE_USBDEBUG_OPTIONS select SPI_FLASH if HAVE_ACPI_RESUME + select TSC_CONSTANT_RATE + select TSC_MONOTONIC_TIMER select TSC_SYNC_LFENCE + select UDELAY_TSC select COLLECT_TIMESTAMPS select SOC_AMD_PI select SOC_AMD_COMMON @@ -66,10 +67,6 @@ select VBOOT_VBNV_CMOS select VBOOT_VBNV_CMOS_BACKUP_TO_FLASH
-config UDELAY_LAPIC_FIXED_FSB - int - default 200 - config HAVE_BOOTBLOCK bool default n diff --git a/src/soc/amd/picasso/Makefile.inc b/src/soc/amd/picasso/Makefile.inc index 67d8904..ee9b407 100644 --- a/src/soc/amd/picasso/Makefile.inc +++ b/src/soc/amd/picasso/Makefile.inc @@ -40,7 +40,6 @@ romstage-y += i2c.c romstage-y += romstage.c romstage-y += gpio.c -romstage-y += monotonic_timer.c romstage-y += pmutil.c romstage-y += reset.c romstage-y += smbus.c @@ -53,7 +52,6 @@
verstage-y += gpio.c verstage-y += i2c.c -verstage-y += monotonic_timer.c verstage-y += pmutil.c verstage-y += reset.c verstage-$(CONFIG_PICASSO_UART) += uart.c @@ -72,7 +70,6 @@ ramstage-y += mca.c ramstage-$(CONFIG_HAVE_ACPI_TABLES) += acpi.c ramstage-y += gpio.c -ramstage-y += monotonic_timer.c ramstage-y += southbridge.c ramstage-y += northbridge.c ramstage-y += pmutil.c @@ -89,7 +86,6 @@ ramstage-$(CONFIG_SPI_FLASH) += spi.c ramstage-y += finalize.c
-smm-y += monotonic_timer.c smm-y += smihandler.c smm-y += smi_util.c smm-y += tsc_freq.c diff --git a/src/soc/amd/picasso/monotonic_timer.c b/src/soc/amd/picasso/monotonic_timer.c deleted file mode 100644 index 7ea571f..0000000 --- a/src/soc/amd/picasso/monotonic_timer.c +++ /dev/null @@ -1,38 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright 2018 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include <cpu/x86/msr.h> -#include <timer.h> -#include <timestamp.h> - -#define CU_PTSC_MSR 0xc0010280 -#define PTSC_FREQ_MHZ 100 - -void timer_monotonic_get(struct mono_time *mt) -{ - mono_time_set_usecs(mt, timestamp_get()); -} - -uint64_t timestamp_get(void) -{ - unsigned long long val; - msr_t msr; - - msr = rdmsr(CU_PTSC_MSR); - - val = ((unsigned long long)msr.hi << 32) | msr.lo; - - return val / PTSC_FREQ_MHZ; -} diff --git a/src/soc/amd/picasso/tsc_freq.c b/src/soc/amd/picasso/tsc_freq.c index 29121b9..6167726 100644 --- a/src/soc/amd/picasso/tsc_freq.c +++ b/src/soc/amd/picasso/tsc_freq.c @@ -19,31 +19,27 @@ #include <cpu/amd/msr.h> #include <cpu/x86/tsc.h> #include <console/console.h> -#include <soc/pci_devs.h> -#include <device/pci_ops.h> + +static unsigned long mhz;
- /* - * See the Family 15h Models 70h-7Fh BKDG (PID 55072) definition for - * MSR0000_0010. The TSC increments at the P0 frequency. According - * to the "Software P-state Numbering" section, P0 is the highest - * non-boosted state. freq = 100MHz * (CpuFid + 10h) / (2^(CpuDid)). - */ - boost_states = (pci_read_config32(SOC_PM_DEV, CORE_PERF_BOOST_CTRL) - >> 2) & 0x7; + if (mhz) + return mhz;
cpufid = (msr.lo & 0x3f); cpudid = (msr.lo & 0x1c0) >> 6;
- return (100 * (cpufid + 0x10)) / (0x01 << cpudid); + mhz = (100 * (cpufid + 0x10)) / (0x01 << cpudid); + return mhz; }
