Andrey Korolyov (andrey@xdel.ru) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/15565
commit a1b3519d35a1ecb31fbfadd94a6b70d602e23554 Author: Andrey Korolyov andrey@xdel.ru Date: Fri Jul 1 20:06:37 2016 +0300
Add support for F2950 single-board computer
This platform, also known as TONK 1201/TONK 1202, was originally produced as a Centerm F2950. Common configuration does include a 600 MHz GeodeLX CPU underclocked to 500 or 400 Mhz, 128 or 512 Mb of RAM in the single SODIMM slot and 128 or 512 IDE DOM. The board does have three USB 2.0 ports, PS/2, VGA, Geode audio controller and the serial port.
EEPROM needs to be soldered out and flashed externally at the time of this message because flashrom would neither be able to dump BIOS correctly while running vendor BIOS neither write flash contents.
At this moment GeodeVGA does not work out-of-box after initialization by SeaBIOS, thereby preventing selection of the bootable media, Linux lxfb driver works well. Except this, all peripheral components (USB, serial, IDE, PS/2, audio) are working well too.
Change-Id: I93f13ecb53bd05abc0e07e0bd7ba40e646dcb4c4 --- src/mainboard/amd/f2950/Kconfig | 27 ++++++++++++ src/mainboard/amd/f2950/Kconfig.name | 2 + src/mainboard/amd/f2950/board_info.txt | 6 +++ src/mainboard/amd/f2950/cmos.layout | 36 +++++++++++++++ src/mainboard/amd/f2950/devicetree.cb | 67 ++++++++++++++++++++++++++++ src/mainboard/amd/f2950/irq_tables.c | 64 +++++++++++++++++++++++++++ src/mainboard/amd/f2950/romstage.c | 80 ++++++++++++++++++++++++++++++++++ 7 files changed, 282 insertions(+)
diff --git a/src/mainboard/amd/f2950/Kconfig b/src/mainboard/amd/f2950/Kconfig new file mode 100644 index 0000000..5bfe120 --- /dev/null +++ b/src/mainboard/amd/f2950/Kconfig @@ -0,0 +1,27 @@ +if BOARD_AMD_F2950 + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select CPU_AMD_GEODE_LX + select NORTHBRIDGE_AMD_LX + select SOUTHBRIDGE_AMD_CS5536 + select SUPERIO_WINBOND_W83627HF + select HAVE_PIRQ_TABLE + select PIRQ_ROUTE + select UDELAY_TSC + select BOARD_ROMSIZE_KB_512 + select POWER_BUTTON_FORCE_ENABLE + +config MAINBOARD_DIR + string + default amd/f2950 + +config MAINBOARD_PART_NUMBER + string + default "F2950" + +config IRQ_SLOT_COUNT + int + default 3 + +endif # BOARD_AMD_F2950 diff --git a/src/mainboard/amd/f2950/Kconfig.name b/src/mainboard/amd/f2950/Kconfig.name new file mode 100644 index 0000000..8f6073a --- /dev/null +++ b/src/mainboard/amd/f2950/Kconfig.name @@ -0,0 +1,2 @@ +config BOARD_AMD_F2950 + bool "F2950" diff --git a/src/mainboard/amd/f2950/board_info.txt b/src/mainboard/amd/f2950/board_info.txt new file mode 100644 index 0000000..e957623 --- /dev/null +++ b/src/mainboard/amd/f2950/board_info.txt @@ -0,0 +1,6 @@ +Board name: F2950 +Category: mini +ROM package: PLCC +ROM protocol: FWH +ROM socketed: n +Flashrom support: y diff --git a/src/mainboard/amd/f2950/cmos.layout b/src/mainboard/amd/f2950/cmos.layout new file mode 100644 index 0000000..6de5ab6 --- /dev/null +++ b/src/mainboard/amd/f2950/cmos.layout @@ -0,0 +1,36 @@ +entries + +0 384 r 0 reserved_memory +384 1 e 4 boot_option +388 4 r 0 reboot_bits +392 3 e 5 baud_rate +400 1 e 1 power_on_after_fail +412 4 e 6 debug_level +456 1 e 1 ECC_memory +1008 16 h 0 check_sum + +enumerations + +#ID value text +1 0 Disable +1 1 Enable +2 0 Enable +2 1 Disable +4 0 Fallback +4 1 Normal +5 0 115200 +5 1 57600 +5 2 38400 +5 3 19200 +5 4 9600 +5 5 4800 +5 6 2400 +5 7 1200 +6 6 Notice +6 7 Info +6 8 Debug +6 9 Spew + +checksums + +checksum 392 1007 1008 diff --git a/src/mainboard/amd/f2950/devicetree.cb b/src/mainboard/amd/f2950/devicetree.cb new file mode 100644 index 0000000..4e563d2 --- /dev/null +++ b/src/mainboard/amd/f2950/devicetree.cb @@ -0,0 +1,67 @@ +chip northbridge/amd/lx + device domain 0 on + device pci 1.0 on end # Northbridge + device pci 1.1 on end # Graphics + device pci 1.2 on end # Integrated cryptoaccelerator + chip southbridge/amd/cs5536 + # IRQ 12 and 1 unmasked, Keyboard and Mouse IRQs. OK + # SIRQ Mode = Active(Quiet) mode. Save power.... + # Invert mask = IRQ 12 and 1 are active high. Keyboard and Mouse, UARTs, etc IRQs. OK + register "lpc_serirq_enable" = "0x0000105a" + register "lpc_serirq_polarity" = "0x0000EFA5" + register "lpc_serirq_mode" = "1" + register "enable_gpio_int_route" = "0x0D0C0700" + register "enable_ide_nand_flash" = "0" # 0:ide mode, 1:flash + register "enable_USBP4_device" = "1" # 0: host, 1:device + register "enable_USBP4_overcurrent" = "0" #0:off, xxxx:overcurrent setting CS5536 Data Book (pages 380-381) + register "com1_enable" = "0" + register "com1_address" = "0x3F8" + register "com1_irq" = "4" + register "com2_enable" = "0" + register "com2_address" = "0x2F8" + register "com2_irq" = "3" + register "unwanted_vpci[0]" = "0" # End of list has a zero + device pci d.0 on end # Ethernet + device pci f.0 on # ISA Bridge + chip superio/winbond/w83627hf + device pnp 2e.0 off # Floppy + io 0x60 = 0x3f0 + irq 0x70 = 6 + drq 0x74 = 2 + end + device pnp 2e.1 off # Parallel port + io 0x60 = 0x378 + irq 0x70 = 7 + end + device pnp 2e.2 on # Com1 + io 0x60 = 0x3f8 + irq 0x70 = 4 + end + device pnp 2e.3 off end # Com2 + device pnp 2e.5 on # Keyboard + io 0x60 = 0x60 + io 0x62 = 0x64 + irq 0x70 = 1 + irq 0x72 = 12 + end + device pnp 2e.6 off end # CIR + device pnp 2e.7 off end # GAME_MIDI_GIPO1 + device pnp 2e.8 off end # GPIO2 + device pnp 2e.9 off end # GPIO3 + device pnp 2e.a off end # ACPI + device pnp 2e.b off end # HW Monitor + end + end + device pci f.2 on end # IDE Controller + device pci f.3 on end # Audio + device pci f.4 on end # OHCI + device pci f.5 on end # EHCI + end + end + # APIC cluster is late CPU init. + device cpu_cluster 0 on + chip cpu/amd/geode_lx + device lapic 0 on end + end + end +end diff --git a/src/mainboard/amd/f2950/irq_tables.c b/src/mainboard/amd/f2950/irq_tables.c new file mode 100644 index 0000000..b438f02 --- /dev/null +++ b/src/mainboard/amd/f2950/irq_tables.c @@ -0,0 +1,64 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <arch/pirq_routing.h> +#include <console/console.h> +#include <arch/io.h> +#include <arch/pirq_routing.h> +#include "southbridge/amd/cs5536/cs5536.h" + +/* Platform IRQs */ +#define PIRQA 11 +#define PIRQB 5 +#define PIRQC 10 +#define PIRQD 10 + +/* Map */ +#define M_PIRQA (1 << PIRQA) /* Bitmap of supported IRQs */ +#define M_PIRQB (1 << PIRQB) /* Bitmap of supported IRQs */ +#define M_PIRQC (1 << PIRQC) /* Bitmap of supported IRQs */ +#define M_PIRQD (1 << PIRQD) /* Bitmap of supported IRQs */ + +/* Link */ +#define L_PIRQA 1 /* Means Slot INTx# Connects To Chipset INTA# */ +#define L_PIRQB 2 /* Means Slot INTx# Connects To Chipset INTB# */ +#define L_PIRQC 3 /* Means Slot INTx# Connects To Chipset INTC# */ +#define L_PIRQD 4 /* Means Slot INTx# Connects To Chipset INTD# */ + +static const struct irq_routing_table intel_irq_routing_table = { + PIRQ_SIGNATURE, /* u32 signature */ + PIRQ_VERSION, /* u16 version */ + 32 + 16 * CONFIG_IRQ_SLOT_COUNT, /* there can be total CONFIG_IRQ_SLOT_COUNT devices on the bus */ + 0x00, /* Where the interrupt router lies (bus) */ + (0x0F << 3) | 0x0, /* Where the interrupt router lies (dev) */ + 0x00, /* IRQs devoted exclusively to PCI usage */ + 0x100B, /* Vendor */ + 0x002B, /* Device */ + 0, /* Miniport data */ + {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}, /* u8 rfu[11] */ + 0x00, /* u8 checksum , this has to set to some value that would give 0 after the sum of all bytes for this structure (including checksum) */ + { + /* If you change the number of entries, change the CONFIG_IRQ_SLOT_COUNT above! */ + /* bus, dev|fn, {link, bitmap}, {link, bitmap}, {link, bitmap}, {link, bitmap}, slot, rfu */ + {0x00, (0x01 << 3) | 0x0, {{L_PIRQA, M_PIRQA}, {0x00, 0x00}, {0x00, 0x00}, {0x00, 0x00}}, 0x0, 0x0}, /* cpu */ + {0x00, (0x0F << 3) | 0x0, {{L_PIRQA, M_PIRQA}, {L_PIRQB, M_PIRQB}, {L_PIRQC, M_PIRQC}, {L_PIRQD, M_PIRQD}}, 0x0, 0x0}, /* chipset */ + {0x00, (0x0D << 3) | 0x0, {{L_PIRQB, M_PIRQB}, {0x00, 0x00}, {0x00, 0x00}, {0x00, 0x00}}, 0x0, 0x0}, /* ethernet */ + } +}; + +unsigned long write_pirq_routing_table(unsigned long addr) +{ + return copy_pirq_routing_table(addr, &intel_irq_routing_table); +} diff --git a/src/mainboard/amd/f2950/romstage.c b/src/mainboard/amd/f2950/romstage.c new file mode 100644 index 0000000..318149d --- /dev/null +++ b/src/mainboard/amd/f2950/romstage.c @@ -0,0 +1,80 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <stdint.h> +#include <stdlib.h> +#include <device/pci_def.h> +#include <arch/io.h> +#include <device/pnp_def.h> +#include <console/console.h> +#include <cpu/x86/bist.h> +#include <cpu/x86/msr.h> +#include <cpu/amd/car.h> +#include <cpu/amd/lxdef.h> +#include <southbridge/amd/cs5536/cs5536.h> +#include <spd.h> +#include "southbridge/amd/cs5536/early_smbus.c" +#include "southbridge/amd/cs5536/early_setup.c" +#include <superio/winbond/common/winbond.h> +#include <superio/winbond/w83627hf/w83627hf.h> +#include <northbridge/amd/lx/raminit.h> + +#define SERIAL_DEV PNP_DEV(0x2e, W83627HF_SP1) + +int spd_read_byte(unsigned int device, unsigned int address) +{ + if (device != DIMM0) + return 0xFF; + + return smbus_read_byte(device, address); +} + +#include "northbridge/amd/lx/pll_reset.c" +#include "lib/generic_sdram.c" +#include "cpu/amd/geode_lx/cpureginit.c" +#include "cpu/amd/geode_lx/syspreinit.c" +#include "cpu/amd/geode_lx/msrinit.c" + +void main(unsigned long bist) +{ + + static const struct mem_controller memctrl[] = { + {.channel0 = {DIMM0, DIMM1}} + }; + + SystemPreInit(); + msr_init(); + + cs5536_early_setup(); + + /* Note: must do this AFTER the early_setup! It is counting on some + * early MSR setup for CS5536. + */ + winbond_enable_serial(SERIAL_DEV, CONFIG_TTYS0_BASE); + console_init(); + + /* Halt if there was a built in self test failure */ + report_bist_failure(bist); + + pll_reset(); + + cpuRegInit(0, DIMM0, DIMM1, DRAM_TERMINATED); + + sdram_initialize(1, memctrl); + + /* Memory is setup. Return to cache_as_ram.inc and continue to boot. */ + return; +}
