Abhay Kumar has uploaded this change for review. ( https://review.coreboot.org/22799
Change subject: soc/intel/cannonlake: Initialize DDI-A lane in absence of Pre-OS graphics. ......................................................................
TEST=Edp should come up in normal mode.
Change-Id: I6353020f892f2d7b75997eace88b3074adc32aef Signed-off-by: Abhay Kumar abhay.kumar@intel.com --- M src/soc/intel/cannonlake/graphics.c 1 file changed, 37 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/99/22799/1
diff --git a/src/soc/intel/cannonlake/graphics.c b/src/soc/intel/cannonlake/graphics.c index 5cf0ec8..6e1142a 100644 --- a/src/soc/intel/cannonlake/graphics.c +++ b/src/soc/intel/cannonlake/graphics.c @@ -21,12 +21,49 @@ #include <device/pci.h> #include <drivers/intel/gma/opregion.h> #include <intelblocks/graphics.h> +#include <drivers/intel/gma/i915_reg.h>
uintptr_t fsp_soc_get_igd_bar(void) { return graphics_get_memory_base(); }
+void graphics_soc_init(struct device *dev) +{ + u32 ddi_buf_ctl; + + /* + * Enable DDI-A (eDP) 4-lane operation if the link is not up yet. + * This will allow the kernel to use 4-lane eDP links properly + * if the VBIOS or GOP driver does not execute. + */ + ddi_buf_ctl = graphics_gtt_read(DDI_BUF_CTL_A); + if (!acpi_is_wakeup_s3() && !(ddi_buf_ctl & DDI_BUF_CTL_ENABLE)) { + ddi_buf_ctl |= DDI_A_4_LANES; + graphics_gtt_write(DDI_BUF_CTL_A, ddi_buf_ctl); + } + + /* + * GFX PEIM module inside FSP binary is taking care of graphics + * initialization based on INTEL_GMA_ADD_VBT_DATA_FILE Kconfig + * option and input VBT file. Hence no need to load/execute legacy VGA + * OpROM in order to initialize GFX. + * + * In case of non-FSP solution, SoC need to select VGA_ROM_RUN + * Kconfig to perform GFX initialization through VGA OpRom. + */ + if (IS_ENABLED(CONFIG_INTEL_GMA_ADD_VBT_DATA_FILE)) + return; + + /* IGD needs to Bus Master */ + u32 reg32 = pci_read_config32(dev, PCI_COMMAND); + reg32 |= PCI_COMMAND_MASTER | PCI_COMMAND_MEMORY | PCI_COMMAND_IO; + pci_write_config32(dev, PCI_COMMAND, reg32); + + /* Initialize PCI device, load/execute BIOS Option ROM */ + pci_dev_init(dev); +} + uintptr_t graphics_soc_write_acpi_opregion(struct device *device, uintptr_t current, struct acpi_rsdp *rsdp) {
