Patrick Georgi (patrick@georgi-clan.de) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/4443
commit 0bd2f34204c027e26588efb5dbe4db8d5220cd37 Author: David Hendricks dhendrix@chromium.org Date: Mon Aug 5 21:09:32 2013 -0700
exynos5420: init APLL at 1800MHz
This initializes the APLL at 1800MHz.
Change-Id: I366bf4e75510847ab93d9c9f214a49c731cca08a Reviewed-on: https://gerrit.chromium.org/gerrit/64745 Reviewed-by: Gabe Black gabeblack@chromium.org Commit-Queue: David Hendricks dhendrix@chromium.org Tested-by: David Hendricks dhendrix@chromium.org --- src/cpu/samsung/exynos5420/clock_init.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/src/cpu/samsung/exynos5420/clock_init.c b/src/cpu/samsung/exynos5420/clock_init.c index b62ebe4..3521636 100644 --- a/src/cpu/samsung/exynos5420/clock_init.c +++ b/src/cpu/samsung/exynos5420/clock_init.c @@ -65,7 +65,7 @@ void system_clock_init(void)
/* Set APLL */ writel(APLL_CON1_VAL, &clk->apll_con1); - val = set_pll(0xc8, 0x3, 0x1); + val = set_pll(225, 3, 0); /* FOUT=1800MHz */ writel(val, &clk->apll_con0); while ((readl(&clk->apll_con0) & PLL_LOCKED) == 0) ;
