Arthur Heymans has uploaded this change for review. ( https://review.coreboot.org/22802
Change subject: [WIP/NOTFORMERGE]sb/intel/i82801ix: Automatically generate pirq ACPI ......................................................................
Does not work at all...
Change-Id: Iee38eaee8d443286cdcecc4f9df0b713639da669 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/southbridge/intel/i82801ix/lpc.c 1 file changed, 45 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/02/22802/1
diff --git a/src/southbridge/intel/i82801ix/lpc.c b/src/southbridge/intel/i82801ix/lpc.c index bc45b9d..65d6dae 100644 --- a/src/southbridge/intel/i82801ix/lpc.c +++ b/src/southbridge/intel/i82801ix/lpc.c @@ -562,8 +562,53 @@ { device_t dev = dev_find_slot(0, PCI_DEVFN(0x1f,0)); config_t *chip = dev->chip_info; + device_t irq_dev; + u8 int_pin; + + const char *link_list[4] = {"\_SB.PCI0.LPCB.LNKA", + "\_SB.PCI0.LPCB.LNKB", + "\_SB.PCI0.LPCB.LNKC", + "\_SB.PCI0.LPCB.LNKD"};
intel_acpi_pcie_hotplug_generator(chip->pcie_hotplug_map, 8); + + acpigen_write_scope("\_SB"); + acpigen_write_device("PCI0"); + acpigen_write_method("_PRT", 0); + acpigen_write_if(); + acpigen_emit_namestring("PICM"); + acpigen_emit_byte(RETURN_OP); + acpigen_emit_byte(PACKAGE_OP); + for (irq_dev = all_devices; irq_dev; irq_dev = irq_dev->next) { + int_pin = pci_read_config8(irq_dev, PCI_INTERRUPT_PIN); + acpigen_write_package(4); + acpigen_emit_dword((((irq_dev->bus->secondary >> 11) & 0x1f) << 16) & 0xffff); + acpigen_emit_dword(int_pin); + acpigen_emit_dword(0); + acpigen_emit_dword(16 + (int_pin - 1)); + acpigen_pop_len(); + } + acpigen_pop_len(); /* package */ + acpigen_pop_len(); /* return PICM */ + acpigen_pop_len(); /* if PICM */ + acpigen_write_else(); + acpigen_emit_byte(RETURN_OP); + acpigen_emit_byte(PACKAGE_OP); + for (irq_dev = all_devices; irq_dev; irq_dev = irq_dev->next) { + int_pin = pci_read_config8(irq_dev, PCI_INTERRUPT_PIN); + acpigen_write_package(4); + acpigen_emit_dword((((irq_dev->bus->secondary >> 11) & 0x1f) << 16) & 0xffff); + acpigen_emit_dword(int_pin); + acpigen_write_string(link_list[int_pin - 1]); + acpigen_emit_dword(0); + acpigen_pop_len(); + } + acpigen_pop_len(); /* package */ + acpigen_pop_len(); /* return else PICM */ + acpigen_pop_len(); /* else PICM*/ + acpigen_pop_len(); /* _PRT */ + acpigen_pop_len(); /* PCI0 */ + acpigen_pop_len(); /* _SB */ }
static struct pci_operations pci_ops = {
