Attention is currently required from: Angel Pons, Máté Kukri, Nicholas Chin.
Hello Angel Pons, Máté Kukri, Nicholas Chin, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/85884?usp=email
Change subject: mb/asrock: Add Z87M Extreme4 (Haswell) ......................................................................
This port was done via autoport and subsequent manual tweaking.
Working: - Haswell MRC.bin - All four DDR3/DDR3L DIMM slots - S3 suspend and resume - D-Sub Port - DVI-D Port - HDMI Port - RJ-45 Gigabit LAN Port - All four rear USB 2.0 Ports - All four rear USB 3.1 Gen1 Ports - Both USB 2.0 headers - USB 3.1 Gen1 header - All six SATA3 6.0 Gb/s connectors by Intel - Both PCI Express 3.0 x16 slots - PCI Express 2.0 x16 slot - PCI Express 2.0 x1 slots (tested with TL-WDN4800 WiFi adapter) - HD Audio Jack (Audio output tested only) - Front Audio Jack (Audio output tested only)
not (yet) tested: - IR header - COM Port header - eSATA connector - PS/2 Mouse/Keyboard Port
Change-Id: Icc2eb7430b77fe152cff1c90e80e6ba37cc903e1 Signed-off-by: Jan Philipp Groß jeangrande@mailbox.org --- A src/mainboard/asrock/z87m_extreme4/Kconfig A src/mainboard/asrock/z87m_extreme4/Kconfig.name A src/mainboard/asrock/z87m_extreme4/Makefile.mk A src/mainboard/asrock/z87m_extreme4/acpi/ec.asl A src/mainboard/asrock/z87m_extreme4/acpi/platform.asl A src/mainboard/asrock/z87m_extreme4/acpi/superio.asl A src/mainboard/asrock/z87m_extreme4/board_info.txt A src/mainboard/asrock/z87m_extreme4/bootblock.c A src/mainboard/asrock/z87m_extreme4/data.vbt A src/mainboard/asrock/z87m_extreme4/devicetree.cb A src/mainboard/asrock/z87m_extreme4/dsdt.asl A src/mainboard/asrock/z87m_extreme4/gma-mainboard.ads A src/mainboard/asrock/z87m_extreme4/gpio.c A src/mainboard/asrock/z87m_extreme4/hda_verb.c A src/mainboard/asrock/z87m_extreme4/romstage.c 15 files changed, 528 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/84/85884/3
