Subrata Banik (subrata.banik@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/18449
commit 28482bf2f5cbe4aaf0ceecc3e9347fbf28b8f4e6 Author: Subrata Banik subrata.banik@intel.com Date: Wed Feb 22 15:01:26 2017 +0530
soc/intel/glk: Add Kconfig and Makefile.inc for GLK SoC[WIP]
Copied from APL latest git.
Change-Id: Icf1bb95cd2503e12f8ce26d77d2cd940a2ea1b69 Signed-off-by: Subrata Banik subrata.banik@intel.com --- src/soc/intel/glk/Kconfig | 232 +++++++++++++++++++++++++++++++++++++++++ src/soc/intel/glk/Makefile.inc | 40 +++++++ 2 files changed, 272 insertions(+)
diff --git a/src/soc/intel/glk/Kconfig b/src/soc/intel/glk/Kconfig new file mode 100644 index 0000000..a0f9664 --- /dev/null +++ b/src/soc/intel/glk/Kconfig @@ -0,0 +1,232 @@ +config SOC_INTEL_GLK + bool + help + Intel GLK support + +if SOC_INTEL_GLK + +config CPU_SPECIFIC_OPTIONS + def_bool y + select ACPI_INTEL_HARDWARE_SLEEP_VALUES + select ARCH_BOOTBLOCK_X86_32 + select ARCH_RAMSTAGE_X86_32 + select ARCH_ROMSTAGE_X86_32 + select ARCH_VERSTAGE_X86_32 + select BOOTBLOCK_CONSOLE + select BOOT_DEVICE_SPI_FLASH_RW_NOMMAP_EARLY if BOOT_DEVICE_SPI_FLASH + select BOOT_DEVICE_SUPPORTS_WRITES + # CPU specific options + select CPU_INTEL_FIRMWARE_INTERFACE_TABLE + select IOAPIC + select SMP + select SSE2 + select SUPPORT_CPU_UCODE_IN_CBFS + # Audio options + select ACPI_NHLT + select SOC_INTEL_COMMON_NHLT + # Misc options + select C_ENVIRONMENT_BOOTBLOCK + select CACHE_RELOCATED_RAMSTAGE_OUTSIDE_CBMEM if RELOCATABLE_RAMSTAGE + select COLLECT_TIMESTAMPS + select COMMON_FADT + select GENERIC_GPIO_LIB + select HAVE_INTEL_FIRMWARE + select HAVE_SMI_HANDLER + select MRC_SETTINGS_PROTECT + select NO_FIXED_XIP_ROM_SIZE + select NO_XIP_EARLY_STAGES + select PARALLEL_MP + select PARALLEL_MP_AP_WORK + select PCIEXP_ASPM + select PCIEXP_COMMON_CLOCK + select PCIEXP_CLK_PM + select PCIEXP_L1_SUB_STATE + select POSTCAR_CONSOLE + select POSTCAR_STAGE + select REG_SCRIPT + select RELOCATABLE_RAMSTAGE # Build fails if this is not selected + select RTC + select SMM_TSEG + select SOC_INTEL_COMMON + select SOC_INTEL_COMMON_ACPI + select SOC_INTEL_COMMON_ACPI_WAKE_SOURCE + select SOC_INTEL_COMMON_LPSS_I2C + select SOC_INTEL_COMMON_SMI + select SOC_INTEL_COMMON_SPI_FLASH_PROTECT + select UDELAY_TSC + select TSC_CONSTANT_RATE + select TSC_MONOTONIC_TIMER + select HAVE_MONOTONIC_TIMER + select PLATFORM_USES_FSP2_0 + select HAVE_HARD_RESET + select SOC_INTEL_COMMON + select SOC_INTEL_COMMON_GFX_OPREGION + select ADD_VBT_DATA_FILE + +config CHROMEOS + select CHROMEOS_RAMOOPS_DYNAMIC + select EC_SOFTWARE_SYNC if EC_GOOGLE_CHROMEEC + select SEPARATE_VERSTAGE + select VBOOT_OPROM_MATTERS + select VBOOT_SAVE_RECOVERY_REASON_ON_REBOOT + select VBOOT_STARTS_IN_BOOTBLOCK + select VBOOT_VBNV_CMOS + select VBOOT_VBNV_CMOS_BACKUP_TO_FLASH + select VIRTUAL_DEV_SWITCH + +config TPM_ON_FAST_SPI + bool + default n + select LPC_TPM + help + TPM part is conntected on Fast SPI interface, but the LPC MMIO + TPM transactions are decoded and serialized over the SPI interface. + +config SOC_INTEL_COMMON_RESET + bool + default y + +config MMCONF_BASE_ADDRESS + hex "PCI MMIO Base Address" + default 0xe0000000 + +config IOSF_BASE_ADDRESS + hex "MMIO Base Address of sideband bus" + default 0xd0000000 + +config DCACHE_RAM_BASE + hex "Base address of cache-as-RAM" + default 0xfef00000 + +config DCACHE_RAM_SIZE + hex "Length in bytes of cache-as-RAM" + default 0xc0000 + help + The size of the cache-as-ram region required during bootblock + and/or romstage. + +config DCACHE_BSP_STACK_SIZE + hex + default 0x4000 + help + The amount of anticipated stack usage in CAR by bootblock and + other stages. + +config CPU_ADDR_BITS + int + default 36 + +config SOC_INTEL_COMMON_LPSS_I2C_CLOCK_MHZ + depends on SOC_INTEL_COMMON_LPSS_I2C + int + default 133 + +config CONSOLE_UART_BASE_ADDRESS + depends on CONSOLE_SERIAL + hex "MMIO base address for UART" + default 0xde000000 + +config SOC_UART_DEBUG + bool "Enable SoC UART debug port selected by UART_FOR_CONSOLE." + default n + select CONSOLE_SERIAL + select DRIVERS_UART + select DRIVERS_UART_8250MEM_32 + select NO_UART_ON_SUPERIO + +# 32KiB bootblock is all that is mapped in by the CSE at top of 4GiB. +config C_ENV_BOOTBLOCK_SIZE + hex + default 0x8000 + +# This SoC does not map SPI flash like many previous SoC. Therefore we provide +# a custom media driver that facilitates mapping +config X86_TOP4G_BOOTMEDIA_MAP + bool + default n + +config ROMSTAGE_ADDR + hex + default 0xfef20000 + help + The base address (in CAR) where romstage should be linked + +config VERSTAGE_ADDR + hex + default 0xfef40000 + help + The base address (in CAR) where verstage should be linked + +config CACHE_MRC_SETTINGS + bool + default y + +config MRC_SETTINGS_VARIABLE_DATA + bool + default y + +config FSP_M_ADDR + hex + default 0xfef40000 + help + The address FSP-M will be relocated to during build time + +config NEED_LBP2 + bool "Write contents for logical boot partition 2." + default n + help + Write the contents from a file into the logical boot partition 2 + region defined by LBP2_FMAP_NAME. + +config LBP2_FMAP_NAME + string "Name of FMAP region to put logical boot partition 2" + depends on NEED_LBP2 + default "SIGN_CSE" + help + Name of FMAP region to write logical boot partition 2 data. + +config LBP2_FILE_NAME + string "Path of file to write to logical boot partition 2 region" + depends on NEED_LBP2 + default "3rdparty/blobs/mainboard/$(CONFIG_MAINBOARD_DIR)/lbp2.bin" + help + Name of file to store in the logical boot partition 2 region. + +config NEED_IFWI + bool "Write content into IFWI region" + default n + help + Write the content from a file into IFWI region defined by + IFWI_FMAP_NAME. + +config IFWI_FMAP_NAME + string "Name of FMAP region to pull IFWI into" + depends on NEED_IFWI + default "IFWI" + help + Name of FMAP region to write IFWI. + +config IFWI_FILE_NAME + string "Path of file to write to IFWI region" + depends on NEED_IFWI + default "3rdparty/blobs/mainboard/$(CONFIG_MAINBOARD_DIR)/ifwi.bin" + help + Name of file to store in the IFWI region. + +config HEAP_SIZE + hex + default 0x8000 + +config SPI_FLASH_INCLUDE_ALL_DRIVERS + bool + default n + +config SMM_RESERVED_SIZE + hex + default 0x100000 + +config IFD_CHIPSET + string + default "aplk" + +endif diff --git a/src/soc/intel/glk/Makefile.inc b/src/soc/intel/glk/Makefile.inc new file mode 100644 index 0000000..92c3bc2 --- /dev/null +++ b/src/soc/intel/glk/Makefile.inc @@ -0,0 +1,40 @@ +ifeq ($(CONFIG_SOC_INTEL_GLK),y) + +subdirs-y += ../../../cpu/intel/microcode +subdirs-y += ../../../cpu/intel/turbo +subdirs-y += ../../../cpu/x86/lapic +subdirs-y += ../../../cpu/x86/mtrr +subdirs-y += ../../../cpu/x86/smm +subdirs-y += ../../../cpu/x86/tsc +subdirs-y += ../../../cpu/x86/cache + +CPPFLAGS_common += -I$(src)/soc/intel/glk/include +CPPFLAGS_common += -I$(src)/vendorcode/intel/fsp/fsp2_0/glk + +# Since FSP-M runs in CAR we need to relocate it to a specific address +$(CONFIG_FSP_M_CBFS)-options := -b $(CONFIG_FSP_M_ADDR) + +ifeq ($(CONFIG_NEED_LBP2),y) +files_added:: + $(CBFSTOOL) $(obj)/coreboot.rom write -r $(CONFIG_LBP2_FMAP_NAME) -f $(CONFIG_LBP2_FILE_NAME) --fill-upward +endif + +# Bootblock on GLK platform lies in the IFWI region. In order to place +# the bootblock at the right location in IFWI image - +# a. Using ifwitool: +# 1. Create IFWI image (ifwi.bin.tmp) from input image +# (CONFIG_IFWI_FILE_NAME). +# 2. Delete OBBP sub-partition, if present. +# 3. Replace IBBL directory entry in IBBP sub-partition with currently +# generated bootblock.bin. +# b. Using cbfstool: +# 1. Write ifwi.bin.tmp to coreboot.rom using CONFIG_IFWI_FMAP_NAME. +ifeq ($(CONFIG_NEED_IFWI),y) +files_added:: $(IFWITOOL) + $(IFWITOOL) $(CONFIG_IFWI_FILE_NAME) create -f $(objcbfs)/ifwi.bin.tmp + $(IFWITOOL) $(objcbfs)/ifwi.bin.tmp delete -n OBBP + $(IFWITOOL) $(objcbfs)/ifwi.bin.tmp replace -n IBBP -f $(objcbfs)/bootblock.bin -d -e IBBL + $(CBFSTOOL) $(obj)/coreboot.rom write -r $(CONFIG_IFWI_FMAP_NAME) -f $(objcbfs)/ifwi.bin.tmp --fill-upward +endif + +endif
