Martin Roth (martinroth@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/17939
commit 14fffaafa21eaf10af43885e660e2904f4f94f29 Author: Martin Roth martinroth@google.com Date: Thu Dec 22 10:21:11 2016 -0700
Kconfig: Remind users to delete .config when switching boards
Because Kconfig default values *ONLY* get set when they are first configured, if you switch mainboards with an existing .config, the values will not be set as expected for the new board.
This seems to confuse most users, so put a warning in a visible location to let them know.
Change-Id: Ie6a9c2d139ecd841d654943f14c119ebafd632f2 Signed-off-by: Martin Roth martinroth@google.com --- src/mainboard/Kconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/src/mainboard/Kconfig b/src/mainboard/Kconfig index 24c1fe3..bdaa9e7 100644 --- a/src/mainboard/Kconfig +++ b/src/mainboard/Kconfig @@ -1,3 +1,5 @@ +comment "Important: Run 'make distclean' before switching boards" + choice prompt "Mainboard vendor" default VENDOR_EMULATION
