Arthur Heymans has uploaded this change for review. ( https://review.coreboot.org/23470
Change subject: cpu/intel/socket_LGA775: Use common CAR ......................................................................
This code will most likely not work on Intel Netburst CPUs but there are reports that these don't work anyway and on some boards Netburst CPUs don't even get to output a post_code (even if placed very early on, after entering 32bit protected mode).
Change-Id: I6bf2fe603b4458f14fb7cfaa55d68ebf6d75b347 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/cpu/intel/socket_LGA775/Kconfig M src/cpu/intel/socket_LGA775/Makefile.inc 2 files changed, 4 insertions(+), 3 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/70/23470/1
diff --git a/src/cpu/intel/socket_LGA775/Kconfig b/src/cpu/intel/socket_LGA775/Kconfig index 8b227bd..a965d13 100644 --- a/src/cpu/intel/socket_LGA775/Kconfig +++ b/src/cpu/intel/socket_LGA775/Kconfig @@ -6,14 +6,15 @@ config SOCKET_SPECIFIC_OPTIONS # dummy def_bool y select CPU_INTEL_MODEL_6FX - select CPU_INTEL_MODEL_F3X - select CPU_INTEL_MODEL_F4X + select CPU_INTEL_MODEL_F3X # Probably not working + select CPU_INTEL_MODEL_F4X # Probably not working # select CPU_INTEL_MODEL_F6X # select CPU_INTEL_MODEL_1066X select CPU_INTEL_MODEL_1067X select MMX select SSE select SIPI_VECTOR_IN_ROM + select CPU_INTEL_COMMON_CAR
config DCACHE_RAM_SIZE hex diff --git a/src/cpu/intel/socket_LGA775/Makefile.inc b/src/cpu/intel/socket_LGA775/Makefile.inc index ffcd1cb..b53d9af 100644 --- a/src/cpu/intel/socket_LGA775/Makefile.inc +++ b/src/cpu/intel/socket_LGA775/Makefile.inc @@ -13,6 +13,6 @@ subdirs-y += ../hyperthreading subdirs-y += ../speedstep
-cpu_incs-y += $(src)/cpu/intel/car/cache_as_ram_ht.inc +subdirs-y += ../car romstage-y += ../car/romstage.c romstage-y += ../car/romstage.c
