Martin L Roth has submitted this change. ( https://review.coreboot.org/c/coreboot/+/71591 )
Change subject: drivers/amd: Update to use defined post codes ......................................................................
Signed-off-by: Martin Roth gaumless@gmail.com Change-Id: I2d5700534c07e89b3908a2e6b827db919a48795d Reviewed-on: https://review.coreboot.org/c/coreboot/+/71591 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Felix Held felix-coreboot@felixheld.de Reviewed-by: Fred Reitberger reitbergerfred@gmail.com --- M src/drivers/amd/agesa/cache_as_ram.S 1 file changed, 17 insertions(+), 2 deletions(-)
Approvals: build bot (Jenkins): Verified Felix Held: Looks good to me, approved Fred Reitberger: Looks good to me, approved
diff --git a/src/drivers/amd/agesa/cache_as_ram.S b/src/drivers/amd/agesa/cache_as_ram.S index 0d678d1..e342039 100644 --- a/src/drivers/amd/agesa/cache_as_ram.S +++ b/src/drivers/amd/agesa/cache_as_ram.S @@ -12,6 +12,7 @@
#include <cpu/x86/lapic_def.h> #include <cpu/x86/post_code.h> +#include <amdblocks/post_codes.h>
.section .init
@@ -30,7 +31,7 @@ */ bootblock_pre_c_entry:
- post_code(0xa0) + post_code(POST_BOOTBLOCK_PRE_C_ENTRY)
AMD_ENABLE_STACK
@@ -56,7 +57,7 @@ movd %mm1, %eax pushl %eax /* tsc[31:0] */
- post_code(0xa2) + post_code(POST_BOOTBLOCK_PRE_C_DONE)
call bootblock_c_entry
