Hello Arthur Heymans, Paul Menzel, build bot (Jenkins), Patrick Georgi, Martin Roth,
https://review.coreboot.org/c/coreboot/+/27089
Change subject: mb/asus/p5qpl-am: Add p5g41t-m_lx as a variant ......................................................................
This board has more or less the same as the p5qpl-am except for DDR3 memory and different colors on the ports. Tested with Arch Linux with kernel 4.20.0-arch1-1-ARCH.
What is tested and works: - 800/1066/1333 MHz CPUs and DDR3 sticks at 800/1066 MHz Some bugs are still present in the DDR3 raminit code though. - Ethernet - Internal programmer with both coreboot and stock firmware. - PCI and PCIe x1 slots - All USB ports - S3 resume - SATA ports - PEG - Rear audio output
Change-Id: I92cd15a245c4f1d8f57b304c9c3a37ba29c35431 Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/mainboard/asus/p5qpl-am/Kconfig M src/mainboard/asus/p5qpl-am/Kconfig.name M src/mainboard/asus/p5qpl-am/Makefile.inc M src/mainboard/asus/p5qpl-am/devicetree.cb M src/mainboard/asus/p5qpl-am/romstage.c A src/mainboard/asus/p5qpl-am/variants/p5g41t-m_lx/gpio.c A src/mainboard/asus/p5qpl-am/variants/p5g41t-m_lx/overridetree.cb R src/mainboard/asus/p5qpl-am/variants/p5qpl-am/gpio.c A src/mainboard/asus/p5qpl-am/variants/p5qpl-am/overridetree.cb 9 files changed, 395 insertions(+), 91 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/89/27089/11
