Marc Jones (marc@marcjonesconsulting.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/18438
commit bf937343c3d42bb424b59480d502232c29581994 Author: Marshall Dawson marshalldawson3rd@gmail.com Date: Wed Jan 25 15:23:47 2017 -0700
cpu/amd/pi: Change wrapper to use config option
Add a check for vboot when locating the binaryPI image.
There is currently an ordering problem using cbmem to locate the image when vboot is present. Vboot inserts its locator into the search process so that memory can be checked before flash is queried. For the earliest calls using the wrapper, DRAM has not been set up and cbmem not initialized in romstage. This change prevents an endless loop when vboot searches cbmem.
This change has another side effect. When vboot is in effect, the change forces the RO binaryPI to be used even when on either of the RW paths. There is currently no ability to relocate the XIP image for use in a RW region.
Signed-off-by: Marshall Dawson marshalldawson3rd@gmail.com Reviewed-by: Marc Jones marcj303@gmail.com (cherry picked from commit 6efe9217c38cf93fd9b38e52cf3ec90fee3d0474)
Change-Id: I0c14bd729f8a67bca37cbdbd3a5e266c99c86d54 Signed-off-by: Marc Jones marcj303@gmail.com --- src/northbridge/amd/pi/agesawrapper.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/src/northbridge/amd/pi/agesawrapper.c b/src/northbridge/amd/pi/agesawrapper.c index 0fe8eab..543aa80 100644 --- a/src/northbridge/amd/pi/agesawrapper.c +++ b/src/northbridge/amd/pi/agesawrapper.c @@ -603,8 +603,14 @@ const void *agesawrapper_locate_module (const CHAR8 name[8]) const AMD_MODULE_HEADER* module; size_t file_size;
+#if IS_ENABLED(CONFIG_VBOOT) + /* Use phys. location in flash and prevent vboot from searching cbmem */ + agesa = (void *)CONFIG_AGESA_BINARY_PI_LOCATION; + file_size = 0x100000; +#else agesa = cbfs_boot_map_with_leak((const char *)CONFIG_CBFS_AGESA_NAME, CBFS_TYPE_RAW, &file_size); +#endif if (!agesa) return NULL; image = LibAmdLocateImage(agesa, agesa + file_size - 1, 4096, name);
