Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/10427
commit a9f65af84c145b426825644e2fd7c384cdbbd4cf Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Thu Jun 4 13:34:23 2015 -0500
northbridge/amd/amdmct: Honor MMCONF_BASE_ADDRESS
The MMIO hole start address was hardcoded on AMD Family 10h systems. Use the MMCONF_BASE_ADDRESS Kconfig setting instead.
Change-Id: I204e904d96d14e99529fa5e524fd73e6ea256dc0 Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/northbridge/amd/amdmct/wrappers/mcti_d.c | 14 ++++++-------- 1 file changed, 6 insertions(+), 8 deletions(-)
diff --git a/src/northbridge/amd/amdmct/wrappers/mcti_d.c b/src/northbridge/amd/amdmct/wrappers/mcti_d.c index 1706fce..3c730af 100644 --- a/src/northbridge/amd/amdmct/wrappers/mcti_d.c +++ b/src/northbridge/amd/amdmct/wrappers/mcti_d.c @@ -159,17 +159,15 @@ static u16 mctGet_NVbits(u8 index) //val = 1; /* enable */ break; case NV_BottomIO: -#if !CONFIG_GFXUMA - val = 0xE0; /* address bits [31:24] */ -#elif CONFIG_GFXUMA - val = 0xC0; /* address bits [31:24] */ -#endif - break; case NV_BottomUMA: + /* address bits [31:24] */ #if !CONFIG_GFXUMA - val = 0xE0; /* address bits [31:24] */ + val = (CONFIG_MMCONF_BASE_ADDRESS >> 24); #elif CONFIG_GFXUMA - val = 0xC0; /* address bits [31:24] */ + #if CONFIG_MMCONF_BASE_ADDRESS < 0x21000000) + #error "MMCONF_BASE_ADDRESS is too small" + #endif + val = (CONFIG_MMCONF_BASE_ADDRESS - 0x20000000 >> 24); #endif break; case NV_ECC:
