Martin Roth (martinroth@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/18000
commit fd02183158256418aa9f484a2d3cb8998cac9ac6 Author: Martin Roth gaumless@gmail.com Date: Fri Dec 30 16:26:13 2016 -0700
util/docker: Update makefile target names
- Use dashes instead of underscores for consistency and to match other coreboot targets - Fix a couple of places where old target names were referenced - Remove double 'help' target from .PHONEY target list
Change-Id: I3b464ebf74653a8cc880e982316fd883757ec728 Signed-off-by: Martin Roth gaumless@gmail.com --- util/docker/Makefile | 47 +++++++++++++++++++++++------------------------ 1 file changed, 23 insertions(+), 24 deletions(-)
diff --git a/util/docker/Makefile b/util/docker/Makefile index 113e1ca..f669b93 100644 --- a/util/docker/Makefile +++ b/util/docker/Makefile @@ -16,42 +16,41 @@ export top=$(abspath $(CURDIR)/../..) export crossgcc_version=$(shell $(top)/util/crossgcc/buildgcc --version | grep 'cross toolchain' | sed 's/^.*\sv//' | sed 's/\s.*$$//') export DOCKER:=$(shell env sh -c "command -v docker")
-test_docker: +test-docker: $(if $(DOCKER),,\ $(warning Docker command not found. Please install docker) \ $(warning https://docs.docker.com/engine/installation ) \ $(error halting))
-test_docker_login: test_docker +test-docker-login: test-docker $(if $(shell if [ ! -f ~/.docker/config.json ]; then \ echo "docker authentication file not found"; fi), \ $(error Docker authentication file not found. Run 'docker login'))
-coreboot-sdk: test_docker +coreboot-sdk: test-docker $(DOCKER) build -t coreboot/coreboot-sdk:$(crossgcc_version) coreboot-sdk
-upload-coreboot-sdk: test_docker_login +upload-coreboot-sdk: test-docker-login $(DOCKER) push coreboot/coreboot-sdk:$(crossgcc_version)
-coreboot-jenkins-node: test_docker +coreboot-jenkins-node: test-docker $(DOCKER) build -t coreboot/coreboot-jenkins-node:$(crossgcc_version) coreboot-jenkins-node
-upload-coreboot-jenkins-node: test_docker_login +upload-coreboot-jenkins-node: test-docker-login $(DOCKER) push coreboot/coreboot-jenkins-node:$(crossgcc_version)
-docker-killall: test_docker +docker-killall: test-docker @if [ -n "$$($(DOCKER) ps | grep 'coreboot')" ]; then \ $(DOCKER) kill $$($(DOCKER) ps | grep 'coreboot' | cut -f1 -d ' '); \ fi
-clean_coreboot_containers: docker-killall +clean-coreboot-containers: docker-killall $(DOCKER) rm $(docker ps -a | grep 'coreboot' | sed 's|\s.*$||')
-clean_coreboot_images: docker-killall +clean-coreboot-images: docker-killall $(DOCKER) rmi $(docker images | grep coreboot | sed 's|^\S+\s+\S+\s+||' | sed 's|\s.*$||')
-docker_build_coreboot: test_docker - +docker-build-coreboot: test-docker $(DOCKER) run -u root -it -v $(top):/home/coreboot/coreboot \ --rm coreboot/coreboot-sdk:$(crossgcc_version) \ /bin/bash -c "cd /home/coreboot/coreboot && \ @@ -61,7 +60,7 @@ docker_build_coreboot: test_docker @echo "Exiting now will leave built files owned by root" sudo chown -R $$(whoami):$$(id -gn $$(whoami)) $(top)
-docker_abuild: test_docker +docker-abuild: test-docker $(DOCKER) run -u root -it -v $(top):/home/coreboot/coreboot \ --rm coreboot/coreboot-sdk:$(crossgcc_version) \ /bin/bash -c "cd /home/coreboot/coreboot && \ @@ -73,20 +72,20 @@ docker_abuild: test_docker
help: @echo "Commands for working with docker images:" - @echo " build-coreboot-sdk - Build coreboot-sdk container" + @echo " coreboot-sdk - Build coreboot-sdk container" @echo " upload-coreboot-sdk - Upload coreboot-sdk to hub.docker.com" - @echo " build-coreboot-jenkins-node - Build coreboot-jenkins-node container" + @echo " coreboot-jenkins-node - Build coreboot-jenkins-node container" @echo " upload-coreboot-jenkins-node - Upload coreboot-jenkins-node to hub.docker.com" - @echo " clean_coreboot_containers - remove all docker coreboot containers" - @echo " clean_coreboot_images - remove all docker coreboot images" + @echo " clean-coreboot-containers - remove all docker coreboot containers" + @echo " clean-coreboot-images - remove all docker coreboot images" @echo @echo "Commands for using docker images" - @echo " docker_build_coreboot <BUILD_CMD=target> - Build coreboot under coreboot-sdk" - @echo " docker_abuild <ABUILD_ARGS='-a -B'> - Run abuild under coreboot-sdk" + @echo " docker-build-coreboot <BUILD_CMD=target> - Build coreboot under coreboot-sdk" + @echo " docker-abuild <ABUILD_ARGS='-a -B'> - Run abuild under coreboot-sdk"
-.PHONY: test_docker test_docker_login help -.PHONY: build-coreboot-jenkins-node upload-coreboot-jenkins-node -.PHONY: build-coreboot-sdk upload-coreboot-sdk -.PHONY: clean_coreboot_containers clean_coreboot_images -.PHONY: docker_build_coreboot docker_abuild -.PHONY: help \ No newline at end of file +.PHONY: test-docker test-docker-login +.PHONY: coreboot-jenkins-node upload-coreboot-jenkins-node +.PHONY: coreboot-sdk upload-coreboot-sdk +.PHONY: clean-coreboot-containers clean-coreboot-images +.PHONY: docker-abuild +.PHONY: help
