the following patch was just integrated into master: commit eee4f6b224b897184327539fcbeb23f9b26f02d9 Author: Arthur Heymans arthur@aheymans.xyz Date: Tue Jan 3 00:49:45 2017 +0100
nb/x4x/raminit: Fix programming dram timings
The results were obtained by comparing the MCHBAR registers of vendor bios with coreboot at the same dram timings.
This fixes 2 issues: * 1333MHz fsb CPUs were limited to 667MHz ddr2 speeds, because with 800MHz raminit failed; * 1067MHz fsb CPUs did not boot when second dimm slot was populated.
TESTED on ga-g41m-es2l on 800, 1067 and 1333MHz CPUs with DDR2 667 and 800MHz dimms.
Change-Id: I70f554f97b44947c2c78713b4d73a47c06d7ba60 Signed-off-by: Arthur Heymans arthur@aheymans.xyz Reviewed-on: https://review.coreboot.org/18022 Tested-by: build bot (Jenkins) Reviewed-by: Nico Huber nico.h@gmx.de
See https://review.coreboot.org/18022 for details.
