Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/8687
commit 0529538485786c10ffeb4e14e7de9e53a63eea40 Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Thu Mar 12 16:16:59 2015 +0200
HyperTransport: Move pci_scan_bus() call
Allows to remove parameter max from the call, it is not involved with the unitid assignment.
Change-Id: I087622f4ff69474f0b27cfd8709106ab8ac4ca98 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/device/hypertransport.c | 13 ++++++++----- src/include/device/hypertransport.h | 2 +- src/northbridge/amd/amdfam10/northbridge.c | 6 +++++- src/northbridge/amd/amdk8/northbridge.c | 6 +++++- 4 files changed, 19 insertions(+), 8 deletions(-)
diff --git a/src/device/hypertransport.c b/src/device/hypertransport.c index d27e66b..1f73047 100644 --- a/src/device/hypertransport.c +++ b/src/device/hypertransport.c @@ -249,7 +249,7 @@ static void ht_collapse_early_enumeration(struct bus *bus, }
unsigned int hypertransport_scan_chain(struct bus *bus, unsigned min_devfn, - unsigned max_devfn, unsigned int max, + unsigned max_devfn, unsigned *ht_unitid_base, unsigned offset_unitid) { @@ -474,9 +474,7 @@ end_of_chain: last_func->sibling = old_devices; }
- /* Now that nothing is overlapping it is safe to scan the children. */ - max = pci_scan_bus(bus, 0x00, ((next_unitid - 1) << 3) | 7, max); - return max; + return next_unitid; }
/** @@ -498,8 +496,13 @@ static unsigned int hypertransport_scan_chain_x(struct bus *bus, { unsigned int ht_unitid_base[4]; unsigned int offset_unitid = 1; - return hypertransport_scan_chain(bus, min_devfn, max_devfn, max, + + unsigned int next_unitid = hypertransport_scan_chain(bus, min_devfn, max_devfn, ht_unitid_base, offset_unitid); + + /* Now that nothing is overlapping it is safe to scan the children. */ + max = pci_scan_bus(bus, 0x00, ((next_unitid - 1) << 3) | 7, max); + return max; }
unsigned int ht_scan_bridge(struct device *dev, unsigned int max) diff --git a/src/include/device/hypertransport.h b/src/include/device/hypertransport.h index e927d61..03e327d 100644 --- a/src/include/device/hypertransport.h +++ b/src/include/device/hypertransport.h @@ -4,7 +4,7 @@ #include <device/hypertransport_def.h>
unsigned int hypertransport_scan_chain(struct bus *bus, - unsigned min_devfn, unsigned max_devfn, unsigned int max, unsigned *ht_unit_base, unsigned offset_unitid); + unsigned min_devfn, unsigned max_devfn, unsigned *ht_unit_base, unsigned offset_unitid); unsigned int ht_scan_bridge(struct device *dev, unsigned int max); extern struct device_operations default_ht_ops_bus;
diff --git a/src/northbridge/amd/amdfam10/northbridge.c b/src/northbridge/amd/amdfam10/northbridge.c index 9206de7..b6e08a2 100644 --- a/src/northbridge/amd/amdfam10/northbridge.c +++ b/src/northbridge/amd/amdfam10/northbridge.c @@ -163,6 +163,7 @@ static u32 amdfam10_scan_chain(device_t dev, u32 nodeid, struct bus *link, bool
int i; + unsigned int next_unitid; u32 ht_c_index; u32 ht_unitid_base[4]; // here assume only 4 HT device on chain u32 max_bus; @@ -257,7 +258,10 @@ static u32 amdfam10_scan_chain(device_t dev, u32 nodeid, struct bus *link, bool else max_devfn = (0x1f<<3) | 7;
- max = hypertransport_scan_chain(link, 0, max_devfn, max, ht_unitid_base, offset_unit_id(is_sblink)); + next_unitid = hypertransport_scan_chain(link, 0, max_devfn, ht_unitid_base, offset_unit_id(is_sblink)); + + /* Now that nothing is overlapping it is safe to scan the children. */ + max = pci_scan_bus(link, 0x00, ((next_unitid - 1) << 3) | 7, max);
/* We know the number of busses behind this bridge. Set the * subordinate bus number to it's real value diff --git a/src/northbridge/amd/amdk8/northbridge.c b/src/northbridge/amd/amdk8/northbridge.c index a17aa65..77eedb5 100644 --- a/src/northbridge/amd/amdk8/northbridge.c +++ b/src/northbridge/amd/amdk8/northbridge.c @@ -105,6 +105,7 @@ static u32 amdk8_scan_chain(device_t dev, u32 nodeid, struct bus *link, bool is_ u32 max) { int i; + unsigned int next_unitid; u32 busses, config_busses; u32 free_reg, config_reg; u32 ht_unitid_base[4]; // here assume only 4 HT device on chain @@ -209,7 +210,10 @@ static u32 amdk8_scan_chain(device_t dev, u32 nodeid, struct bus *link, bool is_ else max_devfn = (0x1f<<3) | 7;
