Martin Roth has uploaded this change for review. ( https://review.coreboot.org/22798
Change subject: soc/amd/common: Collect timestamps before and after AGESA calls ......................................................................
BUG=b:70432544 TEST=Build & boot kahlee. Look at timestamps.
Change-Id: I8209160f8e23ab77987f8e515c7b00d94f68c8be Signed-off-by: Martin Roth martinroth@google.com --- M src/soc/amd/common/agesawrapper.c 1 file changed, 19 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/98/22798/1
diff --git a/src/soc/amd/common/agesawrapper.c b/src/soc/amd/common/agesawrapper.c index b939183..6d8796c 100644 --- a/src/soc/amd/common/agesawrapper.c +++ b/src/soc/amd/common/agesawrapper.c @@ -20,6 +20,7 @@ #include <cpu/x86/mtrr.h> #include <BiosCallOuts.h> #include <string.h> +#include <timestamp.h>
void __attribute__((weak)) SetMemParams(AMD_POST_PARAMS *PostParams) {} void __attribute__((weak)) OemPostParams(AMD_POST_PARAMS *PostParams) {} @@ -62,7 +63,10 @@ AmdResetParams.FchInterface.SataEnable = !((CONFIG_STONEYRIDGE_SATA_MODE == 0) || (CONFIG_STONEYRIDGE_SATA_MODE == 3)); AmdResetParams.FchInterface.IdeEnable = (CONFIG_STONEYRIDGE_SATA_MODE == 0) || (CONFIG_STONEYRIDGE_SATA_MODE == 3);
+ timestamp_add_now(TS_AGESA_INIT_RESET_START); status = AmdInitReset(&AmdResetParams); + timestamp_add_now(TS_AGESA_INIT_RESET_DONE); + if (status != AGESA_SUCCESS) agesawrapper_amdreadeventlog(AmdParamStruct.StdHeader.HeapStatus); AmdReleaseStruct (&AmdParamStruct); return status; @@ -88,7 +92,10 @@ OemCustomizeInitEarly (AmdEarlyParamsPtr);
AmdEarlyParamsPtr->GnbConfig.PsppPolicy = PsppDisabled; + + timestamp_add_now(TS_AGESA_INIT_EARLY_START); status = AmdInitEarly ((AMD_EARLY_PARAMS *)AmdParamStruct.NewStructPtr); + timestamp_add_now(TS_AGESA_INIT_EARLY_DONE);
if (status != AGESA_SUCCESS) agesawrapper_amdreadeventlog(AmdParamStruct.StdHeader.HeapStatus); AmdReleaseStruct (&AmdParamStruct); @@ -127,7 +134,9 @@ "unknown" );
+ timestamp_add_now(TS_AGESA_INIT_POST_START); status = AmdInitPost (PostParams); + timestamp_add_now(TS_AGESA_INIT_POST_DONE);
/* If UMA is enabled we currently have it below TOP_MEM as well. * UMA may or may not be cacheable, so Sub4GCacheTop could be @@ -189,7 +198,10 @@ EnvParam->FchInterface.SataIdeMode = (CONFIG_STONEYRIDGE_SATA_MODE == 3); EnvParam->GnbEnvConfiguration.IommuSupport = FALSE;
+ timestamp_add_now(TS_AGESA_INIT_ENV_START); status = AmdInitEnv (EnvParam); + timestamp_add_now(TS_AGESA_INIT_ENV_DONE); + if (status != AGESA_SUCCESS) agesawrapper_amdreadeventlog(EnvParam->StdHeader.HeapStatus); /* Initialize Subordinate Bus Number and Secondary Bus Number * In platform BIOS this address is allocated by PCI enumeration code @@ -257,7 +269,10 @@ MidParam->FchInterface.IdeEnable = (CONFIG_STONEYRIDGE_SATA_MODE == 0) || (CONFIG_STONEYRIDGE_SATA_MODE == 3); MidParam->FchInterface.SataIdeMode = (CONFIG_STONEYRIDGE_SATA_MODE == 3);
+ timestamp_add_now(TS_AGESA_INIT_MID_START); status = AmdInitMid ((AMD_MID_PARAMS *)AmdParamStruct.NewStructPtr); + timestamp_add_now(TS_AGESA_INIT_MID_DONE); + if (status != AGESA_SUCCESS) agesawrapper_amdreadeventlog(AmdParamStruct.StdHeader.HeapStatus); AmdReleaseStruct (&AmdParamStruct);
@@ -284,7 +299,11 @@ /* NOTE: if not call amdcreatestruct, the initializer(AmdInitLateInitializer) would not be called */ AmdCreateStruct(&AmdParamStruct); AmdLateParams = (AMD_LATE_PARAMS *)AmdParamStruct.NewStructPtr; + + timestamp_add_now(TS_AGESA_INIT_LATE_START); Status = AmdInitLate(AmdLateParams); + timestamp_add_now(TS_AGESA_INIT_LATE_DONE); + if (Status != AGESA_SUCCESS) { agesawrapper_amdreadeventlog(AmdLateParams->StdHeader.HeapStatus); ASSERT(Status == AGESA_SUCCESS);
