Vladimir Serbinenko (phcoder@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/7682
commit 6ecebf88c409b9be63bad89e7f9030c5b0b4d1b5 Author: Vladimir Serbinenko phcoder@gmail.com Date: Sun Dec 7 13:03:16 2014 +0100
vx800/vga.c: Remove extraneous parentheses.
Change-Id: Ic81b5f66871ec78c72f2adc5723f22fa94a672e8 Signed-off-by: Vladimir Serbinenko phcoder@gmail.com --- src/northbridge/via/vx800/vga.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/src/northbridge/via/vx800/vga.c b/src/northbridge/via/vx800/vga.c index 7fe33f2..4ee249f 100644 --- a/src/northbridge/via/vx800/vga.c +++ b/src/northbridge/via/vx800/vga.c @@ -186,7 +186,7 @@ static void vga_init(device_t dev) printk(BIOS_DEBUG, "Enable VGA console\n"); vga_enable_console();
- if ((acpi_sleep_type == 3)/* || (PAYLOAD_IS_SEABIOS == 0)*/) { + if (acpi_sleep_type == 3/* || (PAYLOAD_IS_SEABIOS == 0)*/) { /* It's not clear if these need to be programmed before or after * the VGA bios runs. Try both, clean up later */ /* Set memory rate to 200MHz */
