Nico Huber (nico.h@gmx.de) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/17587
commit 119a153efe54c3ca1370c3790cf9a2cd72c14759 Author: Nico Huber nico.h@gmx.de Date: Wed Nov 23 23:56:53 2016 +0100
nb/intel/x4x: Fix and deflate `dimm_config` in raminit
By shifting the `chan` right instead of left, values were always taken from the DIMMs of the first channel. The diff-stat also looks like an improvement.
Change-Id: I605eb4f9b04520c51eea9995a2d4a1f050f02ecc Signed-off-by: Nico Huber nico.h@gmx.de --- src/northbridge/intel/x4x/raminit.c | 112 ++++-------------------------------- src/northbridge/intel/x4x/x4x.h | 4 ++ 2 files changed, 16 insertions(+), 100 deletions(-)
diff --git a/src/northbridge/intel/x4x/raminit.c b/src/northbridge/intel/x4x/raminit.c index bc0af04..0867c31 100644 --- a/src/northbridge/intel/x4x/raminit.c +++ b/src/northbridge/intel/x4x/raminit.c @@ -140,108 +140,20 @@ static void sdram_read_spds(struct sysinfo *s) }
FOR_EACH_POPULATED_CHANNEL(s->dimms, chan) { - if (s->dimms[chan>>1].sides == 0) { - // NC - if (s->dimms[(chan>>1) + 1].sides == 0) { - // NC/NC - s->dimm_config[chan] = 0; - } else if (s->dimms[(chan>>1) + 1].sides == 1) { - // NC/SS - if (s->dimms[(chan>>1) + 1].width == 0) { - // NC/8SS - s->dimm_config[chan] = 4; - } else { - // NC/16SS - s->dimm_config[chan] = 12; - } + FOR_EACH_POPULATED_DIMM_IN_CHANNEL(s->dimms, chan, i) { + int dimm_config; + if (s->dimms[i].ranks == 1) { + if (s->dimms[i].width == 0) /* x8 */ + dimm_config = 1; + else /* x16 */ + dimm_config = 3; } else { - // NC/DS - if (s->dimms[(chan>>1) + 1].width == 0) { - // NC/8DS - s->dimm_config[chan] = 8; - } else { - // NOT SUPPORTED - die("16DS Not supported\n"); - } - } - } else if (s->dimms[chan>>1].sides == 1) { - // SS - if (s->dimms[(chan>>1) + 1].sides == 0) { - // SS/NC - if (s->dimms[chan>>1].width == 0) { - // 8SS/NC - s->dimm_config[chan] = 1; - } else { - // 16SS/NC - s->dimm_config[chan] = 3; - } - } else if (s->dimms[(chan>>1) + 1].sides == 1) { - // SS/SS - if (s->dimms[chan>>1].width == 0) { - if (s->dimms[(chan>>1) + 1].width == 0) { - // 8SS/8SS - s->dimm_config[chan] = 5; - } else { - // 8SS/16SS - s->dimm_config[chan] = 13; - } - } else { - if (s->dimms[(chan>>1) + 1].width == 0) { - // 16SS/8SS - s->dimm_config[chan] = 7; - } else { - // 16SS/16SS - s->dimm_config[chan] = 15; - } - } - } else { - // SS/DS - if (s->dimms[chan>>1].width == 0) { - if (s->dimms[(chan>>1) + 1].width == 0) { - // 8SS/8DS - s->dimm_config[chan] = 9; - } else { - die("16DS not supported\n"); - } - } else { - if (s->dimms[(chan>>1) + 1].width == 0) { - // 16SS/8DS - s->dimm_config[chan] = 11; - } else { - die("16DS not supported\n"); - } - } - } - } else { - // DS - if (s->dimms[(chan>>1) + 1].sides == 0) { - // DS/NC - if (s->dimms[chan>>1].width == 0) { - // 8DS/NC - s->dimm_config[chan] = 2; - } else { - die("16DS not supported\n"); - } - } else if (s->dimms[(chan>>1) + 1].sides == 1) { - // DS/SS - if (s->dimms[chan>>1].width == 0) { - if (s->dimms[(chan>>1) + 1].width == 0) { - // 8DS/8SS - s->dimm_config[chan] = 6; - } else { - // 8DS/16SS - s->dimm_config[chan] = 14; - } - } else { - die("16DS not supported\n"); - } - } else { - // DS/DS - if (s->dimms[chan>>1].width == 0 && s->dimms[(chan>>1)+1].width == 0) { - // 8DS/8DS - s->dimm_config[chan] = 10; - } + if (s->dimms[i].width == 0) /* x8 */ + dimm_config = 2; + else + die("Dual-rank x16 not supported\n"); } + s->dimm_config[chan] |= dimm_config << (i - chan) * 2; } printk(BIOS_DEBUG, " Config[CH%d] : %d\n", chan, s->dimm_config[chan]); } diff --git a/src/northbridge/intel/x4x/x4x.h b/src/northbridge/intel/x4x/x4x.h index aa5db7d..2d1dee1 100644 --- a/src/northbridge/intel/x4x/x4x.h +++ b/src/northbridge/intel/x4x/x4x.h @@ -161,6 +161,10 @@ for (idx = 0; idx < TOTAL_DIMMS; ++idx) #define FOR_EACH_POPULATED_DIMM(dimms, idx) \ FOR_EACH_DIMM(idx) IF_DIMM_POPULATED(dimms, idx) +#define FOR_EACH_DIMM_IN_CHANNEL(ch, idx) \ + for (idx = (ch); idx < (ch) + 2; ++idx) +#define FOR_EACH_POPULATED_DIMM_IN_CHANNEL(dimms, ch, idx) \ + FOR_EACH_DIMM_IN_CHANNEL(ch, idx) IF_DIMM_POPULATED(dimms, idx) #define CHANNEL_IS_POPULATED(dimms, idx) ((dimms[idx<<1].card_type != RAW_CARD_UNPOPULATED) || (dimms[(idx<<1) + 1].card_type != RAW_CARD_UNPOPULATED)) #define CHANNEL_IS_CARDF(dimms, idx) ((dimms[idx<<1].card_type == 0xf) || (dimms[(idx<<1) + 1].card_type == 0xf)) #define IF_CHANNEL_POPULATED(dimms, idx) if ((dimms[idx<<1].card_type != RAW_CARD_UNPOPULATED) || (dimms[(idx<<1) + 1].card_type != RAW_CARD_UNPOPULATED))
