Elyes HAOUAS has uploaded this change for review. ( https://review.coreboot.org/26005
Change subject: device/smbus_ops.c: Get rid of device_t ......................................................................
Use of `device_t` has been abandoned in ramstage.
Change-Id: I5eb858df7b69a7177564c883b81177ffadc63691 Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- M src/device/smbus_ops.c 1 file changed, 4 insertions(+), 4 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/05/26005/1
diff --git a/src/device/smbus_ops.c b/src/device/smbus_ops.c index 2a86702..c91f415 100644 --- a/src/device/smbus_ops.c +++ b/src/device/smbus_ops.c @@ -20,7 +20,7 @@ #include <device/device.h> #include <device/smbus.h>
-struct bus *get_pbus_smbus(device_t dev) +struct bus *get_pbus_smbus(struct device *dev) { struct bus *const pbus = i2c_link(dev); if (!pbus->dev->ops->ops_smbus_bus) { @@ -40,7 +40,7 @@ * * @param dev TODO. */ -int smbus_set_link(device_t dev) +int smbus_set_link(struct device *dev) { struct bus *pbus_a[4]; // 4 level mux only. Enough? struct bus *pbus = dev->bus; @@ -75,7 +75,7 @@ return -1; \ }
-int smbus_block_read(device_t dev, u8 cmd, u8 bytes, u8 *buffer) +int smbus_block_read(struct device *dev, u8 cmd, u8 bytes, u8 *buffer) { CHECK_PRESENCE(block_read);
@@ -83,7 +83,7 @@ bytes, buffer); }
-int smbus_block_write(device_t dev, u8 cmd, u8 bytes, const u8 *buffer) +int smbus_block_write(struct device *dev, u8 cmd, u8 bytes, const u8 *buffer) { CHECK_PRESENCE(block_write);
