Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/57149 )
Change subject: soc/intel: Don't send CSE EOP if CSME is disabled ......................................................................
CSE EOP will fail if the CSE is disabled (CB:52800)
Signed-off-by: Sean Rhodes sean@starlabs.systems Change-Id: Ic00fdb0d97fefac977c0878d1d5893d07d4481ea Reviewed-on: https://review.coreboot.org/c/coreboot/+/57149 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/soc/intel/common/block/cse/cse_eop.c 1 file changed, 12 insertions(+), 0 deletions(-)
diff --git a/src/soc/intel/common/block/cse/cse_eop.c b/src/soc/intel/common/block/cse/cse_eop.c index e47eb51..4e1c563 100644 --- a/src/soc/intel/common/block/cse/cse_eop.c +++ b/src/soc/intel/common/block/cse/cse_eop.c @@ -18,6 +18,7 @@ CSE_EOP_RESULT_GLOBAL_RESET_REQUESTED, CSE_EOP_RESULT_SUCCESS, CSE_EOP_RESULT_ERROR, + CSE_EOP_RESULT_DISABLED, };
static bool cse_disable_mei_bus(void) @@ -100,6 +101,14 @@ * 2) HFSTS1 COM is Normal * 3) Only sent after DID (accomplished by compiling this into ramstage) */ + + if (cse_is_hfs1_com_soft_temp_disable()) { + printk(BIOS_ERR, "HECI: Prerequisites not met for sending EOP\n"); + if (CONFIG(SOC_INTEL_CSE_LITE_SKU)) + return CSE_EOP_RESULT_ERROR; + return CSE_EOP_RESULT_DISABLED; + } + if (!cse_is_hfs1_cws_normal() || !cse_is_hfs1_com_normal()) { printk(BIOS_ERR, "HECI: Prerequisites not met for sending EOP\n"); return CSE_EOP_RESULT_ERROR; @@ -158,6 +167,9 @@ case CSE_EOP_RESULT_SUCCESS: printk(BIOS_INFO, "CSE EOP successful, continuing boot\n"); break; + case CSE_EOP_RESULT_DISABLED: + printk(BIOS_INFO, "CSE is disabled, continuing boot\n"); + break; case CSE_EOP_RESULT_ERROR: /* fallthrough */ default: printk(BIOS_ERR, "ERROR: Failed to send EOP to CSE, %d\n", result);
19 is the latest approved patch-set. No files were changed between the latest approved patch-set and the submitted one.
