Aaron Durbin (adurbin@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/2890
commit c05722fb57c5b80d0377530e90cf07ee088e2c3d Author: Aaron Durbin adurbin@chromium.org Date: Fri Mar 22 22:09:46 2013 -0500
resources: remove IORESOURCE_[UMA_FB|IGNORE_MTRR]
The IORESOURCE_UMA_FB and IORESOURCE_IGNORE_MTRR attributes on a resource provided hints to the MTRR algorithm. The IORESOURCE_UMA_FB directed the MTRR algorithm to setup a uncacheable space for the resource. The IORESOURCE_IGNORE_MTRR directed the MTRR algorithm to ignore this resource as it was used reserving RAM space.
Now that the optimizing MTRR algorithm is in place there isn't a need for these flags. All IORESOURCE_IGNORE_MTRR users are handled by the MTRR code merging resources of the same cacheable type. The users of the IORESOURCE_UMA_FB will find that the default MTRR type calculation means there isn't a need for this flag any more.
Change-Id: I4f62192edd9a700cb80fa7569caf49538f9b83b7 Signed-off-by: Aaron Durbin adurbin@chromium.org --- src/include/device/device.h | 6 +++--- src/include/device/resource.h | 2 -- 2 files changed, 3 insertions(+), 5 deletions(-)
diff --git a/src/include/device/device.h b/src/include/device/device.h index b8dfbf5..44a9742 100644 --- a/src/include/device/device.h +++ b/src/include/device/device.h @@ -207,16 +207,16 @@ void fixed_mem_resource(device_t dev, unsigned long index, fixed_mem_resource(dev, idx, basek, sizek, IORESOURCE_CACHEABLE)
#define reserved_ram_resource(dev, idx, basek, sizek) \ - fixed_mem_resource(dev, idx, basek, sizek, IORESOURCE_CACHEABLE | IORESOURCE_RESERVE | IORESOURCE_IGNORE_MTRR) + fixed_mem_resource(dev, idx, basek, sizek, IORESOURCE_CACHEABLE | IORESOURCE_RESERVE)
#define bad_ram_resource(dev, idx, basek, sizek) \ reserved_ram_resource((dev), (idx), (basek), (sizek))
#define uma_resource(dev, idx, basek, sizek) \ - fixed_mem_resource(dev, idx, basek, sizek, IORESOURCE_RESERVE | IORESOURCE_UMA_FB) + fixed_mem_resource(dev, idx, basek, sizek, IORESOURCE_RESERVE)
#define mmio_resource(dev, idx, basek, sizek) \ - fixed_mem_resource(dev, idx, basek, sizek, IORESOURCE_RESERVE | IORESOURCE_IGNORE_MTRR) + fixed_mem_resource(dev, idx, basek, sizek, IORESOURCE_RESERVE)
void tolm_test(void *gp, struct device *dev, struct resource *new); u32 find_pci_tolm(struct bus *bus); diff --git a/src/include/device/resource.h b/src/include/device/resource.h index ea1bab5..6b66605 100644 --- a/src/include/device/resource.h +++ b/src/include/device/resource.h @@ -21,8 +21,6 @@ * to the bus below. */ #define IORESOURCE_BRIDGE 0x00080000 /* The IO resource has a bus below it. */ -#define IORESOURCE_UMA_FB 0x00100000 /* UMA framebuffer */ -#define IORESOURCE_IGNORE_MTRR 0x00200000 /* The resource does not affect MTRR setup. */
#define IORESOURCE_RESERVE 0x10000000 /* The resource needs to be reserved in the coreboot table */ #define IORESOURCE_STORED 0x20000000 /* The IO resource assignment has been stored in the device */
