Marshall Dawson has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/36119 )
Change subject: superio/smsc: Restore sio1036 ......................................................................
Change d3a1a417 "src/superio: Remove unused superio chips" removed all unused devices except for ones used on mainboards still under review. The SMSC 1036 was inadvertenly also removed as well. This device is used in debug cards that may be connected to AMD CRBs.
This patch restores the smsc1036 directory as-is and then corrects the following lint messages. * WARNING: Prefer 'unsigned int' to bare use of 'unsigned' * ERROR: else should follow close brace '}' * WARNING: braces {} are not necessary for single statement blocks
Change-Id: I851826e12032f802b9b2ff86d5a0eb99871bee6d Signed-off-by: Marshall Dawson marshalldawson3rd@gmail.com --- A src/superio/smsc/sio1036/Kconfig A src/superio/smsc/sio1036/Makefile.inc A src/superio/smsc/sio1036/sio1036.h A src/superio/smsc/sio1036/sio1036_early_init.c A src/superio/smsc/sio1036/superio.c 5 files changed, 213 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/19/36119/1
diff --git a/src/superio/smsc/sio1036/Kconfig b/src/superio/smsc/sio1036/Kconfig new file mode 100644 index 0000000..df519de --- /dev/null +++ b/src/superio/smsc/sio1036/Kconfig @@ -0,0 +1,18 @@ +## +## This file is part of the coreboot project. +## +## Copyright (C) 2009 Ronald G. Minnich +## Copyright (C) 2012 Advanced Micro Devices, Inc. +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## + +config SUPERIO_SMSC_SIO1036 + bool diff --git a/src/superio/smsc/sio1036/Makefile.inc b/src/superio/smsc/sio1036/Makefile.inc new file mode 100644 index 0000000..e9fdae2 --- /dev/null +++ b/src/superio/smsc/sio1036/Makefile.inc @@ -0,0 +1,18 @@ +# +# This file is part of the coreboot project. +# +# Copyright (C) 2012 Advanced Micro Devices, Inc. +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; version 2 of the License. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# + +bootblock-$(CONFIG_SUPERIO_SMSC_SIO1036) += sio1036_early_init.c +romstage-$(CONFIG_SUPERIO_SMSC_SIO1036) += sio1036_early_init.c +ramstage-$(CONFIG_SUPERIO_SMSC_SIO1036) += superio.c diff --git a/src/superio/smsc/sio1036/sio1036.h b/src/superio/smsc/sio1036/sio1036.h new file mode 100644 index 0000000..610beba --- /dev/null +++ b/src/superio/smsc/sio1036/sio1036.h @@ -0,0 +1,30 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2012 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef SUPERIO_SMSC_SIO1306_H +#define SUPERIO_SMSC_SIO1306_H + +#define SIO1036_SP1 0 /* Com1 */ + +#define UART_POWER_DOWN (1 << 7) +#define LPT_POWER_DOWN (1 << 2) +#define IR_OUTPUT_MUX (1 << 6) + +#include <device/pnp_type.h> +#include <stdint.h> + +void sio1036_enable_serial(pnp_devfn_t dev, u16 iobase); + +#endif /* SUPERIO_SMSC_SIO1306_H */ diff --git a/src/superio/smsc/sio1036/sio1036_early_init.c b/src/superio/smsc/sio1036/sio1036_early_init.c new file mode 100644 index 0000000..26a2a3e --- /dev/null +++ b/src/superio/smsc/sio1036/sio1036_early_init.c @@ -0,0 +1,95 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2012 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +/* Pre-RAM driver for the SMSC KBC1100 Super I/O chip */ + +#include <arch/io.h> +#include <device/pnp_ops.h> +#include <stdint.h> + +#include "sio1036.h" + +static inline void sio1036_enter_conf_state(pnp_devfn_t dev) +{ + u8 port = dev >> 8; + outb(0x55, port); +} + +static inline void sio1036_exit_conf_state(pnp_devfn_t dev) +{ + u8 port = dev >> 8; + outb(0xaa, port); +} + +/* Detect SMSC SIO1036 LPC Debug Card status */ +static u8 detect_sio1036_chip(unsigned int port) +{ + pnp_devfn_t dev = PNP_DEV(port, SIO1036_SP1); + u8 data; + + sio1036_enter_conf_state(dev); + data = pnp_read_config(dev, 0x0D); + sio1036_exit_conf_state(dev); + + /* Detect SMSC SIO1036 chip */ + if (data == 0x82) { + /* Found SMSC SIO1036 chip */ + return 0; + } else { + return 1; + }; +} + +void sio1036_enable_serial(pnp_devfn_t dev, u16 iobase) +{ + unsigned int port = dev >> 8; + + if (detect_sio1036_chip(port) != 0) + return; + + sio1036_enter_conf_state(dev); + + /* Enable SMSC UART 0 */ + /* Valid configuration cycle */ + pnp_write_config(dev, 0x00, 0x28); + + /* PP power/mode/cr lock */ + pnp_write_config(dev, 0x01, 0x98 | LPT_POWER_DOWN); + pnp_write_config(dev, 0x02, 0x08 | UART_POWER_DOWN); + + /*Auto power management*/ + pnp_write_config(dev, 0x07, 0x00); + + /*ECP FIFO threhod */ + pnp_write_config(dev, 0x0A, 0x00 | IR_OUTPUT_MUX); + + /*GPIO direction register 2 */ + pnp_write_config(dev, 0x033, 0x00); + + /*UART Mode */ + pnp_write_config(dev, 0x0C, 0x02); + + /* GPIO polarity regisgter 2 */ + pnp_write_config(dev, 0x034, 0x00); + + /* Enable SMSC UART 0 */ + /*Set base io address */ + pnp_write_config(dev, 0x25, (u8)(iobase >> 2)); + + /* Set UART IRQ onto 0x04 */ + pnp_write_config(dev, 0x28, 0x04); + + sio1036_exit_conf_state(dev); +} diff --git a/src/superio/smsc/sio1036/superio.c b/src/superio/smsc/sio1036/superio.c new file mode 100644 index 0000000..dc8a551 --- /dev/null +++ b/src/superio/smsc/sio1036/superio.c @@ -0,0 +1,52 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2012 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +/* RAM driver for the SMSC SIO1036 Super I/O chip */ + +#include <device/device.h> +#include <device/pnp.h> +#include <superio/conf_mode.h> +#include <stdlib.h> + +#include "sio1036.h" + +static void sio1036_init(struct device *dev) +{ + if (!dev->enabled) + return; +} + +static struct device_operations ops = { + .read_resources = pnp_read_resources, + .set_resources = pnp_set_resources, + .enable_resources = pnp_enable_resources, + .enable = pnp_alt_enable, + .init = sio1036_init, + .ops_pnp_mode = &pnp_conf_mode_55_aa, +}; + +static struct pnp_info pnp_dev_info[] = { + { NULL, SIO1036_SP1, PNP_IO0 | PNP_IRQ0, 0x07f8, }, +}; + +static void enable_dev(struct device *dev) +{ + pnp_enable_devices(dev, &ops, ARRAY_SIZE(pnp_dev_info), pnp_dev_info); +} + +struct chip_operations superio_smsc_sio1036_ops = { + CHIP_NAME("SMSC SIO1036 Super I/O") + .enable_dev = enable_dev +};
Hello Felix Held, Patrick Georgi, Martin Roth,
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/19/36119/2
Martin Roth has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/36119 )
Patch Set 2: Code-Review+2
Felix Held has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/36119 )
Patch Set 2: Code-Review+1
Please add a patch on top of this using the SIO1036 device support, so that this code gets build-tested. I'm ok with restoring this, but I want it to not silently rot away while being in the tree
ah, just saw that the next patch does exactly this
Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/36119 )
Change-Id: I851826e12032f802b9b2ff86d5a0eb99871bee6d Signed-off-by: Marshall Dawson marshalldawson3rd@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/36119 Reviewed-by: Martin Roth martinroth@google.com Reviewed-by: Felix Held felix-coreboot@felixheld.de Tested-by: build bot (Jenkins) no-reply@coreboot.org --- A src/superio/smsc/sio1036/Kconfig A src/superio/smsc/sio1036/Makefile.inc A src/superio/smsc/sio1036/sio1036.h A src/superio/smsc/sio1036/sio1036_early_init.c A src/superio/smsc/sio1036/superio.c 5 files changed, 213 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Martin Roth: Looks good to me, approved Felix Held: Looks good to me, approved
