Jonathan A. Kollasch (jakllsch@kollasch.net) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/12313
commit e39ccb5f9fe4a7dd931b534d5062ea9fd3835b41 Author: Jonathan A. Kollasch jakllsch@kollasch.net Date: Tue Nov 3 12:31:52 2015 -0600
ultra40m2: remove some probably-useless cargo cult GPIO configuration
Change-Id: Ie7ab1ae49f5c9e42dbfe491da05e0fb09692a513 Signed-off-by: Jonathan A. Kollasch jakllsch@kollasch.net --- src/mainboard/sunw/ultra40m2/romstage.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/src/mainboard/sunw/ultra40m2/romstage.c b/src/mainboard/sunw/ultra40m2/romstage.c index 8fc8304..c20d39f 100644 --- a/src/mainboard/sunw/ultra40m2/romstage.c +++ b/src/mainboard/sunw/ultra40m2/romstage.c @@ -61,8 +61,6 @@ static inline int spd_read_byte(unsigned device, unsigned address) RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+38, 0x00, 0x44,/* GPIO39 PCI_GNT3 */ \ RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+39, 0x00, 0x44,/* GPIO40 PCI_GNT2 */ \ RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+40, 0x00, 0x44,/* GPIO41 PCI_REQ2 */ \ - RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+59, 0x00, 0x60,/* GPIP60 FANCTL0 */ \ - RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+60, 0x00, 0x60,/* GPIO61 FANCTL1 */ \ RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+61, 0xf0, 0x05,/* GPIO62 Firewire OHCI disable (active low)? */
#include <southbridge/nvidia/mcp55/early_setup_ss.h>
