Damien Zammit has uploaded this change for review. ( https://review.coreboot.org/21873
Change subject: [NOTFORMERGE]: biostar/a68n_5200: Enable IDS tracing ......................................................................
Switch off warnings are errors as well (cannot merge)
Change-Id: I06a9699e5c8844652c1db389adea671ecdca5cc0 Signed-off-by: Damien Zammit damien@zamaudio.com --- M src/Kconfig M src/mainboard/biostar/a68n_5200/OptionsIds.h 2 files changed, 2 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/73/21873/1
diff --git a/src/Kconfig b/src/Kconfig index adeeb7c..4970a88 100644 --- a/src/Kconfig +++ b/src/Kconfig @@ -1059,7 +1059,7 @@
config WARNINGS_ARE_ERRORS bool - default y + default n
# The four POWER_BUTTON_DEFAULT_ENABLE, POWER_BUTTON_DEFAULT_DISABLE, # POWER_BUTTON_FORCE_ENABLE and POWER_BUTTON_FORCE_DISABLE options are diff --git a/src/mainboard/biostar/a68n_5200/OptionsIds.h b/src/mainboard/biostar/a68n_5200/OptionsIds.h index eaf2442..1a1056e 100644 --- a/src/mainboard/biostar/a68n_5200/OptionsIds.h +++ b/src/mainboard/biostar/a68n_5200/OptionsIds.h @@ -44,7 +44,7 @@
#define IDSOPT_IDS_ENABLED TRUE //#define IDSOPT_CONTROL_ENABLED TRUE -//#define IDSOPT_TRACING_ENABLED TRUE +#define IDSOPT_TRACING_ENABLED TRUE #define IDSOPT_TRACING_CONSOLE_SERIALPORT TRUE //#define IDSOPT_PERF_ANALYSIS TRUE #define IDSOPT_ASSERT_ENABLED TRUE
