Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/8138
commit 448670a6a80a9fcacb64e19b052b4273f595b6e3 Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Tue Jan 6 07:08:46 2015 +0100
Revert "Re-factor 'to_flash_offset()' into 'spi_flash.h'"
This reverts commit 9270553fff23462fcb298f154296319bf3639d15.
Change-Id: I195f721ce7a18aac6c1aa6f4e0f9284455d531b0 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/drivers/intel/fsp/fastboot_cache.c | 13 +++++++++++-- src/include/spi_flash.h | 11 ----------- src/northbridge/intel/haswell/mrccache.c | 7 ++++++- src/northbridge/intel/sandybridge/mrccache.c | 7 ++++++- src/soc/intel/common/nvm.c | 10 ++++++++-- src/soc/intel/fsp_baytrail/nvm.c | 13 +++++++++++-- 6 files changed, 42 insertions(+), 19 deletions(-)
diff --git a/src/drivers/intel/fsp/fastboot_cache.c b/src/drivers/intel/fsp/fastboot_cache.c index 907e143..64982d8 100644 --- a/src/drivers/intel/fsp/fastboot_cache.c +++ b/src/drivers/intel/fsp/fastboot_cache.c @@ -31,6 +31,15 @@ #include <lib.h> // hexdump #include "fsp_util.h"
+#ifndef CONFIG_VIRTUAL_ROM_SIZE +#error "CONFIG_VIRTUAL_ROM_SIZE must be set." +#endif + +/* convert a pointer to flash area into the offset inside the flash */ +static inline u32 to_flash_offset(void *p) { + return ((u32)p + CONFIG_VIRTUAL_ROM_SIZE); +} + static struct mrc_data_container *next_mrc_block( struct mrc_data_container *mrc_cache) { @@ -196,7 +205,7 @@ void update_mrc_cache(void *unused) "Need to erase the MRC cache region of %d bytes at %p\n", cache_size, cache_base);
- flash->erase(flash, to_flash_offset(flash, cache_base), cache_size); + flash->erase(flash, to_flash_offset(cache_base), cache_size);
/* we will start at the beginning again */ cache = cache_base; @@ -204,7 +213,7 @@ void update_mrc_cache(void *unused) /* 4. write mrc data with flash->write() */ printk(BIOS_DEBUG, "Write MRC cache update to flash at %p\n", cache); - flash->write(flash, to_flash_offset(flash, cache), + flash->write(flash, to_flash_offset(cache), current->mrc_data_size + sizeof(*current), current); }
diff --git a/src/include/spi_flash.h b/src/include/spi_flash.h index 1a78b5a..70ca784 100644 --- a/src/include/spi_flash.h +++ b/src/include/spi_flash.h @@ -76,15 +76,4 @@ static inline int spi_flash_erase(struct spi_flash *flash, u32 offset, return flash->erase(flash, offset, len); }
-#if !defined(__PRE_RAM__) -/* convert a pointer to flash area into the offset inside the flash */ -static inline u32 to_flash_offset(struct spi_flash *flash, void *p) { -#if defined(CONFIG_VIRTUAL_ROM_SIZE) - return ((u32)p + CONFIG_VIRTUAL_ROM_SIZE); -#else - return ((u32)p + flash->size); -#endif /* defined(CONFIG_VIRTUAL_ROM_SIZE) */ -} -#endif /* !defined(__PRE_RAM__) */ - #endif /* _SPI_FLASH_H_ */ diff --git a/src/northbridge/intel/haswell/mrccache.c b/src/northbridge/intel/haswell/mrccache.c index 88af789..a921e04 100644 --- a/src/northbridge/intel/haswell/mrccache.c +++ b/src/northbridge/intel/haswell/mrccache.c @@ -33,6 +33,11 @@ #include <vendorcode/google/chromeos/fmap.h> #endif
+/* convert a pointer to flash area into the offset inside the flash */ +static inline u32 to_flash_offset(struct spi_flash *flash, void *p) { + return ((u32)p + flash->size); +} + static struct mrc_data_container *next_mrc_block( struct mrc_data_container *mrc_cache) { @@ -223,7 +228,7 @@ BOOT_STATE_INIT_ENTRIES(mrc_cache_update) = { BOOT_STATE_INIT_ENTRY(BS_WRITE_TABLES, BS_ON_ENTRY, update_mrc_cache, NULL), }; -#endif /* !defined(__PRE_RAM__) */ +#endif
struct mrc_data_container *find_current_mrc_cache(void) { diff --git a/src/northbridge/intel/sandybridge/mrccache.c b/src/northbridge/intel/sandybridge/mrccache.c index 664fb7f..c84ff82 100644 --- a/src/northbridge/intel/sandybridge/mrccache.c +++ b/src/northbridge/intel/sandybridge/mrccache.c @@ -33,6 +33,11 @@ #include <vendorcode/google/chromeos/fmap.h> #endif
+/* convert a pointer to flash area into the offset inside the flash */ +static inline u32 to_flash_offset(struct spi_flash *flash, void *p) { + return ((u32)p + flash->size); +} + static struct mrc_data_container *next_mrc_block( struct mrc_data_container *mrc_cache) { @@ -222,7 +227,7 @@ BOOT_STATE_INIT_ENTRIES(mrc_cache_update) = { BOOT_STATE_INIT_ENTRY(BS_WRITE_TABLES, BS_ON_ENTRY, update_mrc_cache, NULL), }; -#endif /* !defined(__PRE_RAM__) */ +#endif
struct mrc_data_container *find_current_mrc_cache(void) { diff --git a/src/soc/intel/common/nvm.c b/src/soc/intel/common/nvm.c index 54b3baf..791422f 100644 --- a/src/soc/intel/common/nvm.c +++ b/src/soc/intel/common/nvm.c @@ -46,6 +46,12 @@ static int nvm_init(void) return 0; }
+/* Convert memory mapped pointer to flash offset. */ +static inline uint32_t to_flash_offset(void *p) +{ + return CONFIG_ROM_SIZE + (uintptr_t)p; +} + int nvm_is_erased(const void *start, size_t size) { const uint8_t *cur = start; @@ -64,7 +70,7 @@ int nvm_erase(void *start, size_t size) { if (nvm_init() < 0) return -1; - return flash->erase(flash, to_flash_offset(flash, start), size); + return flash->erase(flash, to_flash_offset(start), size); }
/* Write data to NVM. Returns 0 on success < 0 on error. */ @@ -72,5 +78,5 @@ int nvm_write(void *start, const void *data, size_t size) { if (nvm_init() < 0) return -1; - return flash->write(flash, to_flash_offset(flash, start), size, data); + return flash->write(flash, to_flash_offset(start), size, data); } diff --git a/src/soc/intel/fsp_baytrail/nvm.c b/src/soc/intel/fsp_baytrail/nvm.c index d1e5223..0224463 100644 --- a/src/soc/intel/fsp_baytrail/nvm.c +++ b/src/soc/intel/fsp_baytrail/nvm.c @@ -47,6 +47,15 @@ static int nvm_init(void) return 0; }
+/* Convert memory mapped pointer to flash offset. */ +static inline uint32_t to_flash_offset(void *p) +{ +#ifndef CONFIG_ROM_SIZE +#error CONFIG_ROM_SIZE must be set. +#endif + return CONFIG_ROM_SIZE + (uintptr_t)p; +} + int nvm_is_erased(const void *start, size_t size) { const uint8_t *cur = start; @@ -65,7 +74,7 @@ int nvm_erase(void *start, size_t size) { if (nvm_init() < 0) return -1; - flash->erase(flash, to_flash_offset(flash, start), size); + flash->erase(flash, to_flash_offset(start), size); return 0; }
@@ -74,6 +83,6 @@ int nvm_write(void *start, const void *data, size_t size) { if (nvm_init() < 0) return -1; - flash->write(flash, to_flash_offset(flash, start), size, data); + flash->write(flash, to_flash_offset(start), size, data); return 0; }
