Attention is currently required from: Jason Glenesk, Martin Roth, Marshall Dawson, Zheng Bao, Felix Held. Hello Zheng Bao,
https://review.coreboot.org/c/coreboot/+/49737
Change subject: src/amd/cezzanne: Add APCB integration code ......................................................................
Change-Id: I93f798c8834f4496f05d2bf8a15cd4f204513715 Signed-off-by: Zheng Bao fishbaozi@gmail.com --- M src/soc/amd/cezanne/Makefile.inc 1 file changed, 10 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/37/49737/1
diff --git a/src/soc/amd/cezanne/Makefile.inc b/src/soc/amd/cezanne/Makefile.inc index f3c6ca2..5132146 100644 --- a/src/soc/amd/cezanne/Makefile.inc +++ b/src/soc/amd/cezanne/Makefile.inc @@ -81,6 +81,9 @@ # BIOS Directory Table items - proper ordering is managed by amdfwtool #
+# type = 0x60 +PSP_APCB_FILES=$(APCB_SOURCES) $(APCB_SOURCES_68) $(APCB_SOURCES_RECOVERY) + # type = 0x61 PSP_APOB_BASE=$(CONFIG_PSP_APOB_DRAM_ADDRESS)
@@ -130,6 +133,10 @@ OPT_VERSTAGE_FILE=$(call add_opt_prefix, $(PSP_VERSTAGE_FILE), --verstage) OPT_VERSTAGE_SIG_FILE=$(call add_opt_prefix, $(PSP_VERSTAGE_SIG_FILE), --verstage_sig)
+OPT_PSP_APCB_FILES= --instance 0 --apcb $(APCB_SOURCES) \ + --instance 10 --apcb $(APCB_SOURCES_RECOVERY) \ + --instance 18 --apcb $(APCB_SOURCES_68) + OPT_APOB_ADDR=$(call add_opt_prefix, $(PSP_APOB_BASE), --apob-base) OPT_PSP_BIOSBIN_FILE=$(call add_opt_prefix, $(PSP_BIOSBIN_FILE), --bios-bin) OPT_PSP_BIOSBIN_DEST=$(call add_opt_prefix, $(PSP_BIOSBIN_DEST), --bios-bin-dest) @@ -156,7 +163,7 @@ POUND_SIGN=$(call strip_quotes, "#") DEP_FILES= $(patsubst %,$(FIRMWARE_LOCATION)/%, $(shell sed -e /^$(POUND_SIGN)/d -e /*/d -e /^FIRMWARE_LOCATION/d $(CONFIG_AMDFW_CONFIG_FILE) | awk '{print $$2}' ))
-AMDFW_COMMON_ARGS= \ +AMDFW_COMMON_ARGS=$(OPT_PSP_APCB_FILES) \ $(OPT_APOB_ADDR) \ $(OPT_PSP_BIOSBIN_FILE) \ $(OPT_PSP_BIOSBIN_DEST) \ @@ -181,9 +188,11 @@ $(obj)/amdfw.rom: $(call strip_quotes, $(PSP_BIOSBIN_FILE)) \ $(PSP_VERSTAGE_FILE) \ $(PSP_VERSTAGE_SIG_FILE) \ + $$(PSP_APCB_FILES) \ $(DEP_FILES) \ $(AMDFWTOOL) \ $(obj)/fmap_config.h + $(if $(PSP_APCB_FILES), ,$(error APCB_SOURCES is not set)) rm -f $@ @printf " AMDFWTOOL $(subst $(obj)/,,$(@))\n" $(AMDFWTOOL) \
