Julius Werner has submitted this change. ( https://review.coreboot.org/c/coreboot/+/66561 )
Change subject: cbfs/vboot: Adapt to new vb2_digest API ......................................................................
CL:3825558 changes all vb2_digest and vb2_hash functions to take a new hwcrypto_allowed argument, to potentially let them try to call the vb2ex_hwcrypto API for hash calculation. This change will open hardware crypto acceleration up to all hash calculations in coreboot (most notably CBFS verification). As part of this change, the vb2_digest_buffer() function has been removed, so replace existing instances in coreboot with the newer vb2_hash_calculate() API.
Due to the circular dependency of these changes with vboot, this patch also needs to update the vboot submodule:
Updating from commit id 18cb85b5: 2load_kernel.c: Expose load kernel as vb2_api
to commit id b827ddb9: tests: Ensure auxfw sync runs after EC sync
This brings in 15 new commits.
Signed-off-by: Julius Werner jwerner@chromium.org Change-Id: I287d8dac3c49ad7ea3e18a015874ce8d610ec67e Reviewed-on: https://review.coreboot.org/c/coreboot/+/66561 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Jakub Czapiga jacz@semihalf.com --- M 3rdparty/vboot M payloads/libpayload/include/cbfs_glue.h M payloads/libpayload/libcbfs/cbfs.c M payloads/libpayload/tests/libcbfs/cbfs-verification-test.c M src/commonlib/bsd/cbfs_private.c M src/commonlib/bsd/include/commonlib/bsd/cbfs_private.h M src/include/cbfs_glue.h M src/lib/cbfs.c M src/lib/metadata_hash.c M src/security/tpm/tspi/tspi.c M src/security/vboot/misc.h M src/security/vboot/mrc_cache_hash_tpm.c M src/security/vboot/tpm_common.c M src/soc/intel/alderlake/hsphy.c M src/soc/intel/common/block/cse/cse_lite.c M src/vendorcode/eltan/security/mboot/mboot.c M src/vendorcode/eltan/security/verified_boot/vboot_check.c M tests/lib/cbfs-verification-test.c M util/cbfstool/cbfs_glue.h M util/cbfstool/cbfs_image.c M util/cbfstool/cbfstool.c M util/cbfstool/platform_fixups.c 22 files changed, 130 insertions(+), 85 deletions(-)
Approvals: build bot (Jenkins): Verified Jakub Czapiga: Looks good to me, approved
diff --git a/3rdparty/vboot b/3rdparty/vboot index 18cb85b..b827ddb 160000 --- a/3rdparty/vboot +++ b/3rdparty/vboot @@ -1 +1 @@ -Subproject commit 18cb85b52d689b4cfbd49c6384ae2088b78af1e0 +Subproject commit b827ddb9b02228fc8064d7e03bdc6f05535d5e03 diff --git a/payloads/libpayload/include/cbfs_glue.h b/payloads/libpayload/include/cbfs_glue.h index 00d0ea9..bff63ee 100644 --- a/payloads/libpayload/include/cbfs_glue.h +++ b/payloads/libpayload/include/cbfs_glue.h @@ -5,9 +5,11 @@
#include <libpayload-config.h> #include <boot_device.h> +#include <stdbool.h> #include <stdio.h>
#define CBFS_ENABLE_HASHING CONFIG(LP_CBFS_VERIFICATION) +#define CBFS_HASH_HWCRYPTO cbfs_hwcrypto_allowed()
#define ERROR(...) printf("CBFS ERROR: " __VA_ARGS__) #define LOG(...) printf("CBFS: " __VA_ARGS__) @@ -43,4 +45,6 @@ return dev->size; }
+bool cbfs_hwcrypto_allowed(void); + #endif /* _CBFS_CBFS_GLUE_H */ diff --git a/payloads/libpayload/libcbfs/cbfs.c b/payloads/libpayload/libcbfs/cbfs.c index 0694c4f..a158ba8 100644 --- a/payloads/libpayload/libcbfs/cbfs.c +++ b/payloads/libpayload/libcbfs/cbfs.c @@ -89,7 +89,7 @@ ERROR("'%s' does not have a file hash!\n", mdata->h.filename); return true; } - if (vb2_hash_verify(buffer, size, hash) != VB2_SUCCESS) { + if (vb2_hash_verify(cbfs_hwcrypto_allowed(), buffer, size, hash) != VB2_SUCCESS) { ERROR("'%s' file hash mismatch!\n", mdata->h.filename); return true; } @@ -223,3 +223,10 @@
return do_load(&mdata, dev.offset + data_offset, buf, size_inout, true); } + +/* This should be overridden by payloads that want to enforce more explicit + policy on using HW crypto. */ +__weak bool cbfs_hwcrypto_allowed(void) +{ + return true; +} diff --git a/payloads/libpayload/tests/libcbfs/cbfs-verification-test.c b/payloads/libpayload/tests/libcbfs/cbfs-verification-test.c index 8e50f39..25e402c 100644 --- a/payloads/libpayload/tests/libcbfs/cbfs-verification-test.c +++ b/payloads/libpayload/tests/libcbfs/cbfs-verification-test.c @@ -23,8 +23,10 @@ return VB2_SHA256_DIGEST_SIZE; }
-vb2_error_t vb2_hash_verify(const void *buf, uint32_t size, const struct vb2_hash *hash) +vb2_error_t vb2_hash_verify(bool allow_hwcrypto, const void *buf, uint32_t size, + const struct vb2_hash *hash) { + assert_true(allow_hwcrypto); check_expected_ptr(buf); check_expected(size);
diff --git a/src/commonlib/bsd/cbfs_private.c b/src/commonlib/bsd/cbfs_private.c index e77c299..b9221fc 100644 --- a/src/commonlib/bsd/cbfs_private.c +++ b/src/commonlib/bsd/cbfs_private.c @@ -30,13 +30,10 @@ const bool do_hash = CBFS_ENABLE_HASHING && metadata_hash; const size_t devsize = cbfs_dev_size(dev); struct vb2_digest_context dc; - vb2_error_t vbrv;
assert(CBFS_ENABLE_HASHING || (!metadata_hash && !(flags & CBFS_WALK_WRITEBACK_HASH))); - if (do_hash && (vbrv = vb2_digest_init(&dc, metadata_hash->algo))) { - ERROR("Metadata hash digest (%d) init error: %#x\n", metadata_hash->algo, vbrv); + if (do_hash && vb2_digest_init(&dc, CBFS_HASH_HWCRYPTO, metadata_hash->algo, 0)) return CB_ERR_ARG; - }
size_t offset = 0; enum cb_err ret_header; diff --git a/src/commonlib/bsd/include/commonlib/bsd/cbfs_private.h b/src/commonlib/bsd/include/commonlib/bsd/cbfs_private.h index 410bfd6..88f5b63 100644 --- a/src/commonlib/bsd/include/commonlib/bsd/cbfs_private.h +++ b/src/commonlib/bsd/include/commonlib/bsd/cbfs_private.h @@ -27,6 +27,9 @@ * cbfs_dev_t An opaque type representing a CBFS storage backend. * CBFS_ENABLE_HASHING Should be 0 to avoid linking hashing features, 1 otherwise. (Only for * metadata hashing. Host application needs to check file hashes itself.) + * CBFS_HASH_HWCRYPTO Should evaluate to true to allow using vboot hardware crypto routines + * for hashing, false to forbid. This macro may expand to a function call + * to decide this at runtime. * ERROR(...) printf-style macro to print errors. * LOG(...) printf-style macro to print normal-operation log messages. * DEBUG(...) printf-style macro to print detailed debug output. diff --git a/src/include/cbfs_glue.h b/src/include/cbfs_glue.h index 3170c37..652cf1b 100644 --- a/src/include/cbfs_glue.h +++ b/src/include/cbfs_glue.h @@ -5,6 +5,7 @@
#include <commonlib/region.h> #include <console/console.h> +#include <security/vboot/misc.h> #include <rules.h>
/* @@ -18,6 +19,7 @@ */ #define CBFS_ENABLE_HASHING (CONFIG(CBFS_VERIFICATION) && \ (CONFIG(TOCTOU_SAFETY) || ENV_INITIAL_STAGE)) +#define CBFS_HASH_HWCRYPTO vboot_hwcrypto_allowed()
#define ERROR(...) printk(BIOS_ERR, "CBFS ERROR: " __VA_ARGS__) #define LOG(...) printk(BIOS_INFO, "CBFS: " __VA_ARGS__) diff --git a/src/lib/cbfs.c b/src/lib/cbfs.c index e1334f4..4f2d9ca 100644 --- a/src/lib/cbfs.c +++ b/src/lib/cbfs.c @@ -12,7 +12,7 @@ #include <list.h> #include <metadata_hash.h> #include <security/tpm/tspi/crtm.h> -#include <security/vboot/vboot_common.h> +#include <security/vboot/misc.h> #include <stdlib.h> #include <string.h> #include <symbols.h> @@ -160,7 +160,7 @@ ERROR("'%s' does not have a file hash!\n", mdata->h.filename); return true; } - if (vb2_hash_verify(buffer, size, hash) != VB2_SUCCESS) { + if (vb2_hash_verify(vboot_hwcrypto_allowed(), buffer, size, hash)) { ERROR("'%s' file hash mismatch!\n", mdata->h.filename); return true; } @@ -171,11 +171,15 @@
/* No need to re-hash file if we already have it from verification. */ if (!hash || hash->algo != TPM_MEASURE_ALGO) { - vb2_hash_calculate(buffer, size, TPM_MEASURE_ALGO, &calculated_hash); - hash = &calculated_hash; + if (vb2_hash_calculate(vboot_hwcrypto_allowed(), buffer, size, + TPM_MEASURE_ALGO, &calculated_hash)) + hash = NULL; + else + hash = &calculated_hash; }
- if (tspi_cbfs_measurement(mdata->h.filename, be32toh(mdata->h.type), hash)) + if (!hash || + tspi_cbfs_measurement(mdata->h.filename, be32toh(mdata->h.type), hash)) ERROR("failed to measure '%s' into TCPA log\n", mdata->h.filename); /* We intentionally continue to boot on measurement errors. */ } diff --git a/src/lib/metadata_hash.c b/src/lib/metadata_hash.c index e10f6ff..8779b7c 100644 --- a/src/lib/metadata_hash.c +++ b/src/lib/metadata_hash.c @@ -2,6 +2,7 @@
#include <assert.h> #include <metadata_hash.h> +#include <security/vboot/misc.h> #include <symbols.h>
#if !CONFIG(COMPRESS_BOOTBLOCK) || ENV_DECOMPRESSOR @@ -46,5 +47,5 @@ struct vb2_hash hash = { .algo = get_anchor()->cbfs_hash.algo }; memcpy(hash.raw, metadata_hash_anchor_fmap_hash(get_anchor()), vb2_digest_size(hash.algo)); - return vb2_hash_verify(fmap_buffer, fmap_size, &hash); + return vb2_hash_verify(vboot_hwcrypto_allowed(), fmap_buffer, fmap_size, &hash); } diff --git a/src/security/tpm/tspi/tspi.c b/src/security/tpm/tspi/tspi.c index 891f915..7bf8d6c 100644 --- a/src/security/tpm/tspi/tspi.c +++ b/src/security/tpm/tspi/tspi.c @@ -266,7 +266,8 @@
digest_len = vb2_digest_size(TPM_MEASURE_ALGO); assert(digest_len <= sizeof(digest)); - if (vb2_digest_init(&ctx, TPM_MEASURE_ALGO)) { + if (vb2_digest_init(&ctx, vboot_hwcrypto_allowed(), TPM_MEASURE_ALGO, + region_device_sz(rdev))) { printk(BIOS_ERR, "TPM: Error initializing hash.\n"); return TPM_E_HASH_ERROR; } diff --git a/src/security/vboot/misc.h b/src/security/vboot/misc.h index c39af08..8310647 100644 --- a/src/security/vboot/misc.h +++ b/src/security/vboot/misc.h @@ -87,4 +87,18 @@ } }
+static inline bool vboot_hwcrypto_allowed(void) +{ + /* When not using vboot firmware verification, HW crypto is always allowed. */ + if (!CONFIG(VBOOT)) + return 1; + + /* Before vboot runs we can't check for HW crypto, so err on the side of caution. */ + if (!vboot_logic_executed()) + return 0; + + /* Otherwise, vboot can decide. */ + return vb2api_hwcrypto_allowed(vboot_get_context()); +} + #endif /* __VBOOT_MISC_H__ */ diff --git a/src/security/vboot/mrc_cache_hash_tpm.c b/src/security/vboot/mrc_cache_hash_tpm.c index 77c23f6..f67eae4 100644 --- a/src/security/vboot/mrc_cache_hash_tpm.c +++ b/src/security/vboot/mrc_cache_hash_tpm.c @@ -2,27 +2,16 @@
#include <security/vboot/antirollback.h> #include <program_loading.h> -#include <security/vboot/vboot_common.h> #include <vb2_api.h> #include <security/tpm/tss.h> +#include <security/vboot/misc.h> #include <security/vboot/mrc_cache_hash_tpm.h> #include <console/console.h> #include <string.h>
void mrc_cache_update_hash(uint32_t index, const uint8_t *data, size_t size) { - uint8_t data_hash[VB2_SHA256_DIGEST_SIZE]; - static const uint8_t dead_hash[VB2_SHA256_DIGEST_SIZE] = { - 0xba, 0xad, 0xda, 0x1a, /* BAADDA1A */ - 0xde, 0xad, 0xde, 0xad, /* DEADDEAD */ - 0xde, 0xad, 0xda, 0x1a, /* DEADDA1A */ - 0xba, 0xad, 0xba, 0xad, /* BAADBAAD */ - 0xba, 0xad, 0xda, 0x1a, /* BAADDA1A */ - 0xde, 0xad, 0xde, 0xad, /* DEADDEAD */ - 0xde, 0xad, 0xda, 0x1a, /* DEADDA1A */ - 0xba, 0xad, 0xba, 0xad, /* BAADBAAD */ - }; - const uint8_t *hash_ptr = data_hash; + struct vb2_hash hash;
/* Initialize TPM driver. */ if (tlcl_lib_init() != VB2_SUCCESS) { @@ -31,8 +20,8 @@ }
/* Calculate hash of data generated by MRC. */ - if (vb2_digest_buffer(data, size, VB2_HASH_SHA256, data_hash, - sizeof(data_hash))) { + if (vb2_hash_calculate(vboot_hwcrypto_allowed(), data, size, + VB2_HASH_SHA256, &hash)) { printk(BIOS_ERR, "MRC: SHA-256 calculation failed for data. " "Not updating TPM hash space.\n"); /* @@ -40,13 +29,13 @@ * currently stored in TPM hash space is no longer * valid. If we are not able to calculate hash of the * data being updated, reset all the bits in TPM hash - * space to pre-defined hash pattern. + * space to zero to invalidate it. */ - hash_ptr = dead_hash; + memset(hash.raw, 0, VB2_SHA256_DIGEST_SIZE); }
/* Write hash of data to TPM space. */ - if (antirollback_write_space_mrc_hash(index, hash_ptr, VB2_SHA256_DIGEST_SIZE) + if (antirollback_write_space_mrc_hash(index, hash.sha256, sizeof(hash.sha256)) != TPM_SUCCESS) { printk(BIOS_ERR, "MRC: Could not save hash to TPM.\n"); return; @@ -57,15 +46,7 @@
int mrc_cache_verify_hash(uint32_t index, const uint8_t *data, size_t size) { - uint8_t data_hash[VB2_SHA256_DIGEST_SIZE]; - uint8_t tpm_hash[VB2_SHA256_DIGEST_SIZE]; - - /* Calculate hash of data read from MRC_CACHE. */ - if (vb2_digest_buffer(data, size, VB2_HASH_SHA256, data_hash, - sizeof(data_hash))) { - printk(BIOS_ERR, "MRC: SHA-256 calculation failed for data.\n"); - return 0; - } + struct vb2_hash tpm_hash = { .algo = VB2_HASH_SHA256 };
/* Initialize TPM driver. */ if (tlcl_lib_init() != VB2_SUCCESS) { @@ -74,13 +55,14 @@ }
/* Read hash of MRC data saved in TPM. */ - if (antirollback_read_space_mrc_hash(index, tpm_hash, sizeof(tpm_hash)) + if (antirollback_read_space_mrc_hash(index, tpm_hash.sha256, sizeof(tpm_hash.sha256)) != TPM_SUCCESS) { printk(BIOS_ERR, "MRC: Could not read hash from TPM.\n"); return 0; }
- if (memcmp(tpm_hash, data_hash, sizeof(tpm_hash))) { + /* Calculate hash of data read from MRC_CACHE and compare. */ + if (vb2_hash_verify(vboot_hwcrypto_allowed(), data, size, &tpm_hash)) { printk(BIOS_ERR, "MRC: Hash comparison failed.\n"); return 0; } diff --git a/src/security/vboot/tpm_common.c b/src/security/vboot/tpm_common.c index 7fb2a9d..e67cc01 100644 --- a/src/security/vboot/tpm_common.c +++ b/src/security/vboot/tpm_common.c @@ -1,8 +1,9 @@ /* SPDX-License-Identifier: GPL-2.0-only */
#include <security/tpm/tspi.h> -#include <vb2_api.h> #include <security/vboot/tpm_common.h> +#include <vb2_api.h> +#include <vb2_sha.h>
#define TPM_PCR_BOOT_MODE "VBOOT: boot mode" #define TPM_PCR_GBB_HWID_NAME "VBOOT: GBB HWID" diff --git a/src/soc/intel/alderlake/hsphy.c b/src/soc/intel/alderlake/hsphy.c index e958d72..9d41600 100644 --- a/src/soc/intel/alderlake/hsphy.c +++ b/src/soc/intel/alderlake/hsphy.c @@ -10,6 +10,7 @@ #include <device/pci_ops.h> #include <intelblocks/cse.h> #include <intelblocks/systemagent.h> +#include <security/vboot/misc.h> #include <soc/hsphy.h> #include <soc/iomap.h> #include <soc/pci_devs.h> @@ -105,42 +106,28 @@
static int verify_hsphy_hash(void *buf, uint32_t buf_size, uint8_t *hash_buf, uint8_t hash_alg) { - enum vb2_hash_algorithm alg; - uint32_t hash_size; - uint8_t hash_calc[MAX_HASH_SIZE]; + struct vb2_hash hash;
switch (hash_alg) { case HASHALG_SHA256: - alg = VB2_HASH_SHA256; - hash_size = VB2_SHA256_DIGEST_SIZE; + hash.algo = VB2_HASH_SHA256; break; case HASHALG_SHA384: - alg = VB2_HASH_SHA384; - hash_size = VB2_SHA384_DIGEST_SIZE; + hash.algo = VB2_HASH_SHA384; break; case HASHALG_SHA512: - alg = VB2_HASH_SHA512; - hash_size = VB2_SHA512_DIGEST_SIZE; + hash.algo = VB2_HASH_SHA512; break; case HASHALG_SHA1: default: printk(BIOS_ERR, "Hash alg %d not supported, trying SHA384\n", hash_alg); - alg = VB2_HASH_SHA384; - hash_size = VB2_SHA384_DIGEST_SIZE; + hash.algo = VB2_HASH_SHA384; break; } + memcpy(hash.raw, hash_buf, vb2_digest_size(hash.algo));
- if (vb2_digest_buffer(buf, buf_size, alg, hash_calc, hash_size)) { - printk(BIOS_ERR, "HSPHY SHA calculation failed\n"); - return -1; - } - - if (memcmp(hash_buf, hash_calc, hash_size)) { + if (vb2_hash_verify(vboot_hwcrypto_allowed(), buf, buf_size, &hash) != VB2_SUCCESS) { printk(BIOS_ERR, "HSPHY SHA hashes do not match\n"); - printk(BIOS_DEBUG, "Hash from CSME:\n"); - hexdump(hash_buf, hash_size); - printk(BIOS_DEBUG, "Calculated hash:\n"); - hexdump(hash_calc, hash_size); return -1; }
diff --git a/src/soc/intel/common/block/cse/cse_lite.c b/src/soc/intel/common/block/cse/cse_lite.c index 40ae995..1d30a8d 100644 --- a/src/soc/intel/common/block/cse/cse_lite.c +++ b/src/soc/intel/common/block/cse/cse_lite.c @@ -544,15 +544,15 @@ const void *rw_blob, const size_t rw_blob_sz)
{ - uint8_t rw_comp_sha[VB2_SHA256_DIGEST_SIZE]; + struct vb2_hash calculated;
- if (vb2_digest_buffer(rw_blob, rw_blob_sz, VB2_HASH_SHA256, rw_comp_sha, - VB2_SHA256_DIGEST_SIZE)) { + if (vb2_hash_calculate(vboot_hwcrypto_allowed(), rw_blob, rw_blob_sz, + VB2_HASH_SHA256, &calculated)) { printk(BIOS_ERR, "cse_lite: CSE CBFS RW's SHA-256 calculation has failed\n"); return false; }
- if (memcmp(expected_rw_blob_sha, rw_comp_sha, VB2_SHA256_DIGEST_SIZE)) { + if (memcmp(expected_rw_blob_sha, calculated.sha256, sizeof(calculated.sha256))) { printk(BIOS_ERR, "cse_lite: Computed CBFS RW's SHA-256 does not match with" "the provided SHA in the metadata\n"); return false; diff --git a/src/vendorcode/eltan/security/mboot/mboot.c b/src/vendorcode/eltan/security/mboot/mboot.c index 575c5fc..c26ac8f 100644 --- a/src/vendorcode/eltan/security/mboot/mboot.c +++ b/src/vendorcode/eltan/security/mboot/mboot.c @@ -128,9 +128,10 @@ /* The hash is provided as data */ memcpy(digest->digest.sha256, (void *)hashData, hashDataLen); } else { - if (vb2_digest_buffer(hashData, hashDataLen, VB2_HASH_SHA256, digest->digest.sha256, - VB2_SHA256_DIGEST_SIZE)) + struct vb2_hash tmp; + if (vb2_hash_calculate(false, hashData, hashDataLen, VB2_HASH_SHA256, &tmp)) return TPM_E_IOERROR; + memcpy(digest->digest.sha256, tmp.sha256, sizeof(tmp.sha256)); }
printk(BIOS_DEBUG, "%s: SHA256 Hash Digest:\n", __func__); diff --git a/src/vendorcode/eltan/security/verified_boot/vboot_check.c b/src/vendorcode/eltan/security/verified_boot/vboot_check.c index 09da5c5..649adc2 100644 --- a/src/vendorcode/eltan/security/verified_boot/vboot_check.c +++ b/src/vendorcode/eltan/security/verified_boot/vboot_check.c @@ -145,9 +145,12 @@ start, (int)size);
if (start && size) { + struct vb2_hash tmp_hash;
- status = vb2_digest_buffer((const uint8_t *)start, size, HASH_ALG, digest, - DIGEST_SIZE); + status = vb2_hash_calculate(false, start, size, HASH_ALG, &tmp_hash); + if (!status) + memcpy(digest, tmp_hash.raw, DIGEST_SIZE); + if ((CONFIG(VENDORCODE_ELTAN_VBOOT) && memcmp((void *)( (uint8_t *)CONFIG_VENDORCODE_ELTAN_OEM_MANIFEST_LOC + sizeof(digest) * hash_index), digest, sizeof(digest))) || status) { diff --git a/tests/lib/cbfs-verification-test.c b/tests/lib/cbfs-verification-test.c index 263fbec..b1a39bc 100644 --- a/tests/lib/cbfs-verification-test.c +++ b/tests/lib/cbfs-verification-test.c @@ -28,8 +28,10 @@ return VB2_SHA256_DIGEST_SIZE; }
-vb2_error_t vb2_hash_verify(const void *buf, uint32_t size, const struct vb2_hash *hash) +vb2_error_t vb2_hash_verify(bool allow_hwcrypto, const void *buf, uint32_t size, + const struct vb2_hash *hash) { + assert_true(allow_hwcrypto); check_expected_ptr(buf); check_expected(size); assert_int_equal(hash->algo, VB2_HASH_SHA256); @@ -56,7 +58,8 @@ return 0; }
-vb2_error_t vb2_digest_init(struct vb2_digest_context *dc, enum vb2_hash_algorithm hash_alg) +vb2_error_t vb2_digest_init(struct vb2_digest_context *dc, bool allow_hwcrypto, + enum vb2_hash_algorithm hash_alg, uint32_t data_size) { if (hash_alg != VB2_HASH_SHA256) { fail_msg("Unsupported hash algorithm: %d\n", hash_alg); diff --git a/util/cbfstool/cbfs_glue.h b/util/cbfstool/cbfs_glue.h index 11786be..77f22e5 100644 --- a/util/cbfstool/cbfs_glue.h +++ b/util/cbfstool/cbfs_glue.h @@ -6,6 +6,7 @@ #include "cbfs_image.h"
#define CBFS_ENABLE_HASHING 1 +#define CBFS_HASH_HWCRYPTO 0
typedef const struct cbfs_image *cbfs_dev_t;
diff --git a/util/cbfstool/cbfs_image.c b/util/cbfstool/cbfs_image.c index 97ad995..182b185 100644 --- a/util/cbfstool/cbfs_image.c +++ b/util/cbfstool/cbfs_image.c @@ -1456,7 +1456,7 @@ break; } char *hash_str = bintohex(attr->hash.raw, hash_len); - int valid = vb2_hash_verify(CBFS_SUBHEADER(entry), + int valid = vb2_hash_verify(false, CBFS_SUBHEADER(entry), be32toh(entry->len), &attr->hash) == VB2_SUCCESS; const char *valid_str = valid ? "valid" : "invalid";
@@ -1544,7 +1544,7 @@ if (!hash_len) continue; char *hash_str = bintohex(attr->hash.raw, hash_len); - int valid = vb2_hash_verify(CBFS_SUBHEADER(entry), + int valid = vb2_hash_verify(false, CBFS_SUBHEADER(entry), be32toh(entry->len), &attr->hash) == VB2_SUCCESS; fprintf(fp, "%shash:%s:%s:%s", sep, vb2_get_hash_algorithm_name(attr->hash.algo), @@ -1873,7 +1873,7 @@ if (attr == NULL) return -1;
- if (vb2_hash_calculate(buffer_get(buffer), buffer_size(buffer), + if (vb2_hash_calculate(false, buffer_get(buffer), buffer_size(buffer), alg, &attr->hash) != VB2_SUCCESS) return -1;
diff --git a/util/cbfstool/cbfstool.c b/util/cbfstool/cbfstool.c index c2191d2..5cb787d 100644 --- a/util/cbfstool/cbfstool.c +++ b/util/cbfstool/cbfstool.c @@ -271,12 +271,12 @@ if (mhc->cbfs_hash.algo == VB2_HASH_INVALID) return 0;
- uint8_t fmap_hash[VB2_MAX_DIGEST_SIZE]; + struct vb2_hash fmap_hash; const struct fmap *fmap = partitioned_file_get_fmap(param.image_file); - if (!fmap || vb2_digest_buffer((const void *)fmap, fmap_size(fmap), - mhc->cbfs_hash.algo, fmap_hash, sizeof(fmap_hash))) + if (!fmap || vb2_hash_calculate(false, fmap, fmap_size(fmap), + mhc->cbfs_hash.algo, &fmap_hash)) return -1; - return update_anchor(mhc, fmap_hash); + return update_anchor(mhc, fmap_hash.raw); }
static bool verification_exclude(enum cbfs_type type) @@ -1511,7 +1511,7 @@ if (!hash) return CB_ERR; void *file_data = arg + offset + data_offset; - if (vb2_hash_verify(file_data, be32toh(mdata->h.len), hash) != VB2_SUCCESS) + if (vb2_hash_verify(false, file_data, be32toh(mdata->h.len), hash) != VB2_SUCCESS) return CB_CBFS_HASH_MISMATCH; return CB_CBFS_NOT_FOUND; } diff --git a/util/cbfstool/platform_fixups.c b/util/cbfstool/platform_fixups.c index b2e12cf..12a5ad7 100644 --- a/util/cbfstool/platform_fixups.c +++ b/util/cbfstool/platform_fixups.c @@ -67,7 +67,7 @@ }
/* Pass out the actual hash of the current bootblock segment in |real_hash|. */ - if (vb2_hash_calculate(buffer_get(&elf) + pelf.phdr[bb_segment].p_offset, + if (vb2_hash_calculate(false, buffer_get(&elf) + pelf.phdr[bb_segment].p_offset, pelf.phdr[bb_segment].p_filesz, VB2_HASH_SHA384, real_hash)) { ERROR("fixups: vboot digest error\n"); goto destroy_elf; @@ -159,7 +159,7 @@ return NULL; }
- if (vb2_hash_calculate(buffer_get(&buffer), + if (vb2_hash_calculate(false, buffer_get(&buffer), MEDIATEK_BOOTBLOCK_GFH_SIZE + data_size, VB2_HASH_SHA256, real_hash)) { ERROR("fixups: MediaTek: vboot digest error\n");
