Robbie Zhang (robbie.zhang@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/18445
commit c71c9393504da43675e1694bdb2ee7425564acb7 Author: Robbie Zhang robbie.zhang@intel.com Date: Tue Feb 21 14:00:31 2017 -0800
soc/intel/skylake: add SGX initialization
Note PrmrrSize is also required to set in board's devicetree to enable SGX.
One issue is still puzzling and needs to addressed: by calling configure_sgx() in cpu_core_init() which is the per-thread function, the SGX is always failing for thread0 but successful for other 3 threads. I had to call configure_sgx() again from soc_init_cpus() which is BSP-only function to make it enable on BSP.
Another pending work is the implementation for the Owner Epoch update which shall be added later.
BUG=chrome-os-partner:62438 BRANCH=NONE TEST=Tested on Eve, verified SGX activation is successful on all threads, and boot.
Change-Id: I8b64284875eae061fa8e7a01204d48d320a285a9 Signed-off-by: Robbie Zhang robbie.zhang@intel.com --- src/soc/intel/skylake/Makefile.inc | 1 + src/soc/intel/skylake/chip.h | 3 + src/soc/intel/skylake/cpu.c | 51 +++++++--- src/soc/intel/skylake/include/soc/cpu.h | 1 + src/soc/intel/skylake/include/soc/msr.h | 11 ++- src/soc/intel/skylake/sgx.c | 165 ++++++++++++++++++++++++++++++++ 6 files changed, 217 insertions(+), 15 deletions(-)
diff --git a/src/soc/intel/skylake/Makefile.inc b/src/soc/intel/skylake/Makefile.inc index 4b6fcfc..25f65d0 100644 --- a/src/soc/intel/skylake/Makefile.inc +++ b/src/soc/intel/skylake/Makefile.inc @@ -80,6 +80,7 @@ ramstage-y += pmutil.c ramstage-$(CONFIG_PLATFORM_USES_FSP2_0) += reset.c ramstage-y += sata.c ramstage-y += sd.c +ramstage-y += sgx.c ramstage-y += smbus.c ramstage-y += smbus_common.c ramstage-y += smi.c diff --git a/src/soc/intel/skylake/chip.h b/src/soc/intel/skylake/chip.h index 2e4adb2..4255069 100644 --- a/src/soc/intel/skylake/chip.h +++ b/src/soc/intel/skylake/chip.h @@ -410,6 +410,9 @@ struct soc_intel_skylake_config {
/* Wake Enable Bitmap for USB3 ports */ u8 usb3_wake_enable_bitmap; + + /* Enable SGX feature */ + u8 sgx_enable; };
typedef struct soc_intel_skylake_config config_t; diff --git a/src/soc/intel/skylake/cpu.c b/src/soc/intel/skylake/cpu.c index d1a684c..44bd2d9 100644 --- a/src/soc/intel/skylake/cpu.c +++ b/src/soc/intel/skylake/cpu.c @@ -42,6 +42,10 @@ #include <soc/smm.h> #include <soc/systemagent.h>
+/* MP initialization support. */ +static const void *microcode_patch; +static int ht_disabled; + /* Convert time in seconds to POWER_LIMIT_1_TIME MSR value */ static const u8 power_limit_time_sec_to_msr[] = { [0] = 0x00, @@ -336,11 +340,10 @@ static void set_energy_perf_bias(u8 policy) static void configure_mca(void) { msr_t msr; - const unsigned int mcg_cap_msr = 0x179; int i; int num_banks;
- msr = rdmsr(mcg_cap_msr); + msr = rdmsr(IA32_MCG_CAP); num_banks = msr.lo & 0xff; msr.lo = msr.hi = 0; /* @@ -348,8 +351,13 @@ static void configure_mca(void) * of these banks are core vs package scope. For now every CPU clears * every bank. */ - for (i = 0; i < num_banks; i++) + for (i = 0; i < num_banks; i++) { + /* Clear the machine check status */ wrmsr(IA32_MC0_STATUS + (i * 4), msr); + /* Initialize machine checks */ + wrmsr(IA32_MC0_CTL + i * 4, + (msr_t) {.lo = 0xffffffff, .hi = 0xffffffff}); + } }
/* All CPUs including BSP will run the following function. */ @@ -376,6 +384,9 @@ static void cpu_core_init(device_t cpu)
/* Enable Turbo */ enable_turbo(); + + /* Configure SGX */ + configure_sgx(microcode_patch); }
static struct device_operations cpu_dev_ops = { @@ -399,10 +410,6 @@ static const struct cpu_driver driver __cpu_driver = { .id_table = cpu_table, };
-/* MP initialization support. */ -static const void *microcode_patch; -static int ht_disabled; - static int get_cpu_count(void) { msr_t msr; @@ -501,6 +508,14 @@ static void soc_init_cpus(void *unused)
/* Thermal throttle activation offset */ configure_thermal_target(); + + /* + * TODO: somehow calling configure_sgx() in cpu_core_init() was not + * successful on the BSP (other threads were fine). Have to run it again + * here to get SGX enabled on BSP. This behavior needs to root-caused + * and we shall not have this redundant call. + */ + configure_sgx(microcode_patch); }
/* Ensure to re-program all MTRRs based on DRAM resource settings */ @@ -512,15 +527,25 @@ static void soc_post_cpus_init(void *unused)
int soc_skip_ucode_update(u32 current_patch_id, u32 new_patch_id) { - msr_t msr; - /* If PRMRR/SGX is supported the FIT microcode load will set the msr + msr_t msr1; + msr_t msr2; + + /* + * If PRMRR/SGX is supported the FIT microcode load will set the msr * 0x08b with the Patch revision id one less than the id in the * microcode binary. The PRMRR support is indicated in the MSR - * MTRRCAP[12]. Check for this feature and avoid reloading the - * same microcode during CPU initialization. + * MTRRCAP[12]. If SGX is not enabled, check and avoid reloading the + * same microcode during CPU initialization. If SGX is enabled, as + * part of SGX BIOS initialization steps, the same microcode needs to + * be reloaded after the core PRMRR MSRs are programmed. */ - msr = rdmsr(MTRR_CAP_MSR); - return (msr.lo & PRMRR_SUPPORTED) && (current_patch_id == new_patch_id - 1); + msr1 = rdmsr(MTRR_CAP_MSR); + msr2 = rdmsr(PRMRR_PHYS_BASE_MSR); + if (msr2.lo && (current_patch_id == new_patch_id - 1)) + return 0; + else + return (msr1.lo & PRMRR_SUPPORTED) && + (current_patch_id == new_patch_id - 1); }
/* diff --git a/src/soc/intel/skylake/include/soc/cpu.h b/src/soc/intel/skylake/include/soc/cpu.h index 33fb2f1..a259a2b 100644 --- a/src/soc/intel/skylake/include/soc/cpu.h +++ b/src/soc/intel/skylake/include/soc/cpu.h @@ -68,5 +68,6 @@ u32 cpu_family_model(void); u32 cpu_stepping(void); int cpu_is_ult(void); int is_secondary_thread(void); +void configure_sgx(const void *microcode_patch);
#endif diff --git a/src/soc/intel/skylake/include/soc/msr.h b/src/soc/intel/skylake/include/soc/msr.h index 4d295e1..4f05ba6 100644 --- a/src/soc/intel/skylake/include/soc/msr.h +++ b/src/soc/intel/skylake/include/soc/msr.h @@ -22,11 +22,13 @@ #define IA32_FEATURE_CONTROL 0x3a #define CPUID_VMX (1 << 5) #define CPUID_SMX (1 << 6) +#define MSR_BIOS_UPGD_TRIG 0x7a #define MSR_PLATFORM_INFO 0xce #define PLATFORM_INFO_SET_TDP (1 << 29) #define MSR_PMG_CST_CONFIG_CONTROL 0xe2 #define MSR_PMG_IO_CAPTURE_BASE 0xe4 #define MSR_FEATURE_CONFIG 0x13c +#define IA32_MCG_CAP 0x179 #define SMM_MCA_CAP_MSR 0x17d #define SMM_CPU_SVRSTR_BIT 57 #define SMM_CPU_SVRSTR_MASK (1 << (SMM_CPU_SVRSTR_BIT - 32)) @@ -48,13 +50,18 @@ #define ENERGY_POLICY_NORMAL 6 #define ENERGY_POLICY_POWERSAVE 15 #define IA32_PACKAGE_THERM_INTERRUPT 0x1b2 -#define EMRR_PHYS_BASE_MSR 0x1f4 -#define EMRR_PHYS_MASK_MSR 0x1f5 +#define PRMRR_PHYS_BASE_MSR 0x1f4 +#define PRMRR_PHYS_MASK_MSR 0x1f5 +#define PRMRR_PHYS_MASK_LOCK (1 << 10) +#define PRMRR_PHYS_MASK_VALID (1 << 11) #define IA32_PLATFORM_DCA_CAP 0x1f8 #define MSR_POWER_CTL 0x1fc #define MSR_LT_LOCK_MEMORY 0x2e7 #define UNCORE_PRMRR_PHYS_BASE_MSR 0x2f4 #define UNCORE_PRMRR_PHYS_MASK_MSR 0x2f5 +#define MSR_SGX_OWNEREPOCH0 0x300 +#define MSR_SGX_OWNEREPOCH1 0x301 +#define IA32_MC0_CTL 0x400 #define IA32_MC0_STATUS 0x401 #define SMM_FEATURE_CONTROL_MSR 0x4e0 #define SMM_CPU_SAVE_EN (1 << 1) diff --git a/src/soc/intel/skylake/sgx.c b/src/soc/intel/skylake/sgx.c new file mode 100644 index 0000000..1080047 --- /dev/null +++ b/src/soc/intel/skylake/sgx.c @@ -0,0 +1,165 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2017 Intel Corporation. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <console/console.h> +#include <chip.h> +#include <cpu/x86/msr.h> +#include <cpu/x86/mtrr.h> +#include <cpu/intel/microcode.h> +#include <soc/cpu.h> +#include <soc/msr.h> +#include <soc/pci_devs.h> + +static int is_sgx_supported(void) +{ + struct cpuid_result cpuid_regs; + msr_t msr; + + /* + * Check CPUID(EAX=7,ECX=0) for feature capability + * and MTRR_CAP_MSR(FEh) for PRMRR enablement. + */ + cpuid_regs = cpuid_ext(0x7, 0x0); + msr = rdmsr(MTRR_CAP_MSR); + return ((cpuid_regs.ebx & 0x4) && (msr.lo & PRMRR_SUPPORTED)); +} + +static int configure_core_prmrr(void) +{ + msr_t prmrr_base; + msr_t prmrr_mask; + msr_t msr; + + /* + * PRMRR base and mask are read from the UNCORE PRMRR MSRs + * that were already set in FSP-M. + */ + prmrr_base = rdmsr(UNCORE_PRMRR_PHYS_BASE_MSR); + prmrr_mask = rdmsr(UNCORE_PRMRR_PHYS_MASK_MSR); + if (!prmrr_base.lo){ + printk(BIOS_ERR, "SGX Error: Uncore PRMRR is not initialized!\n"); + return -1; + } + + msr = rdmsr(PRMRR_PHYS_MASK_MSR); + /* If it is locked don't attempt to write PRMRR MSRs. */ + if (msr.lo & PRMRR_PHYS_MASK_LOCK) + return 0; + + /* Program core PRMRR MSRs */ + prmrr_base.lo |= 0x6; /* Set memory attribute to cache writeback */ + wrmsr(PRMRR_PHYS_BASE_MSR, prmrr_base); + prmrr_mask.lo &= ~PRMRR_PHYS_MASK_VALID; /* Must not set the valid bit */ + prmrr_mask.lo |= PRMRR_PHYS_MASK_LOCK; /* Lock it */ + wrmsr(PRMRR_PHYS_MASK_MSR, prmrr_mask); + return 0; +} + +static void enable_sgx(void) +{ + msr_t msr; + + msr = rdmsr(IA32_FEATURE_CONTROL); + /* Only enable it when it is not locked */ + if ((msr.lo & 1) == 0) { + msr.lo |= (1 << 18); /* Enable it */ + wrmsr(IA32_FEATURE_CONTROL, msr); + } +} + +static void lock_sgx(void) +{ + msr_t msr; + + msr = rdmsr(IA32_FEATURE_CONTROL); + /* If it is locked don't attempt to lock it again. */ + if ((msr.lo & 1) == 0) { + msr.lo |= 1; /* Lock it */ + wrmsr(IA32_FEATURE_CONTROL, msr); + } +} + +static int owner_epoch_update(void) +{ + msr_t msr; + + /* + * ToDO - the Owner Epoch udpate mechanism is not determined yet + * For PoC just write '0's to the MSRs. + */ + msr.lo = msr.hi = 0; + wrmsr(MSR_SGX_OWNEREPOCH0, msr); + wrmsr(MSR_SGX_OWNEREPOCH1, msr); + return 0; +} + +static void activate_sgx(void) +{ + msr_t msr; + + /* + * Activate SGX feature by writing 1b to MSR 0x7A on all threads. + * BIOS must ensure bit 0 is set prior to writing to it, then read it + * back and verify the bit is cleared to confirm SGX activation. + */ + msr = rdmsr(MSR_BIOS_UPGD_TRIG); + if (msr.lo & 0x1) { + wrmsr(MSR_BIOS_UPGD_TRIG, (msr_t) {.lo = 0x1, .hi = 0}); + /* Read back to verify the it is activated */ + msr = rdmsr(MSR_BIOS_UPGD_TRIG); + if (msr.lo & 0x1) + printk(BIOS_DEBUG, "SGX activation failed.\n"); + else + printk(BIOS_DEBUG, "SGX activation was successful.\n"); + } else + printk(BIOS_DEBUG, "SGX feature is deactivated.\n"); +} + +void configure_sgx(const void *microcode_patch) +{ + device_t dev = SA_DEV_ROOT; + config_t *conf = dev->chip_info; + msr_t msr; + + if (!conf->sgx_enable || !is_sgx_supported()) + return; + + /* Initialize PRMRR core MSRs */ + if (configure_core_prmrr() < 0) + return; + + /* Enable the SGX feature */ + enable_sgx(); + + /* Update the owner epoch value */ + if (owner_epoch_update() < 0) + return; + + /* Ensure to lock memory before reload microcode patch */ + msr = rdmsr(MSR_LT_LOCK_MEMORY); + if ((msr.lo & 1) == 0) { + msr.lo |= 1; /* Lock it */ + wrmsr(MSR_LT_LOCK_MEMORY, msr); + } + + /* Reload the microcode patch */ + intel_microcode_load_unlocked(microcode_patch); + + /* Lock the SGX feature */ + lock_sgx(); + + /* Activate the SGX feature */ + activate_sgx(); +}
