Alexander Couzens (lynxis@fe80.eu) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9710
commit f31ec6948e3ab5c7e89a60cf48fc9d1c1986dae3 Author: Alexander Couzens lynxis@fe80.eu Date: Thu Apr 16 02:23:00 2015 +0200
southbridge/ibexpeak: use new ssdt sata port generator
Change-Id: Id3eca5551a070dfdd6fa674e1d5b6627e28ab5a7 Signed-off-by: Alexander Couzens lynxis@fe80.eu --- src/southbridge/intel/ibexpeak/Kconfig | 1 + src/southbridge/intel/ibexpeak/sata.c | 7 +++++++ 2 files changed, 8 insertions(+)
diff --git a/src/southbridge/intel/ibexpeak/Kconfig b/src/southbridge/intel/ibexpeak/Kconfig index ccd16bf..f31f83c 100644 --- a/src/southbridge/intel/ibexpeak/Kconfig +++ b/src/southbridge/intel/ibexpeak/Kconfig @@ -35,6 +35,7 @@ config SOUTH_BRIDGE_OPTIONS # dummy select SOUTHBRIDGE_INTEL_COMMON select HAVE_USBDEBUG_OPTIONS select COMMON_FADT + select ACPI_SATA_GENERATOR
config EHCI_BAR hex diff --git a/src/southbridge/intel/ibexpeak/sata.c b/src/southbridge/intel/ibexpeak/sata.c index 29d9240..be2b961 100644 --- a/src/southbridge/intel/ibexpeak/sata.c +++ b/src/southbridge/intel/ibexpeak/sata.c @@ -26,6 +26,7 @@ #include <device/pci_ids.h> #include "pch.h" #include <pc80/mc146818rtc.h> +#include <acpi/sata.h>
typedef struct southbridge_intel_ibexpeak_config config_t;
@@ -249,6 +250,11 @@ static void sata_set_subsystem(device_t dev, unsigned vendor, unsigned device) } }
+static void sata_fill_ssdt(device_t dev) { + config_t *config = dev->chip_info; + generate_sata_ssdt_ports("\_SB_.PCI0.SATA", config->sata_port_map); +} + static struct pci_operations sata_pci_ops = { .set_subsystem = sata_set_subsystem, }; @@ -259,6 +265,7 @@ static struct device_operations sata_ops = { .enable_resources = pci_dev_enable_resources, .init = sata_init, .enable = sata_enable, + .acpi_fill_ssdt_generator = sata_fill_ssdt, .scan_bus = 0, .ops_pci = &sata_pci_ops, };
