Tim Wawrzynczak has submitted this change. ( https://review.coreboot.org/c/coreboot/+/56765 )
Change subject: mb/google/brya: Create felwinter variant ......................................................................
Create the felwinter variant of the brya0 reference board by copying the template files to a new directory named for the variant.
(Auto-Generated by create_coreboot_variant.sh version 4.5.0).
BUG=b:194431541 BRANCH=None TEST=util/abuild/abuild -p none -t google/brya -x -a make sure the build includes GOOGLE_FELWINTER
Signed-off-by: Ian Feng ian_feng@compal.corp-partner.google.com Change-Id: Iff2b9daec40995a013f9fe0dd76ad667d1807d1b Reviewed-on: https://review.coreboot.org/c/coreboot/+/56765 Reviewed-by: EricR Lai ericr_lai@compal.corp-partner.google.com Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/mainboard/google/brya/Kconfig M src/mainboard/google/brya/Kconfig.name A src/mainboard/google/brya/variants/felwinter/include/variant/ec.h A src/mainboard/google/brya/variants/felwinter/include/variant/gpio.h A src/mainboard/google/brya/variants/felwinter/memory/Makefile.inc A src/mainboard/google/brya/variants/felwinter/memory/dram_id.generated.txt A src/mainboard/google/brya/variants/felwinter/memory/mem_parts_used.txt A src/mainboard/google/brya/variants/felwinter/overridetree.cb 8 files changed, 45 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified EricR Lai: Looks good to me, approved Tim Wawrzynczak: Looks good to me, approved
diff --git a/src/mainboard/google/brya/Kconfig b/src/mainboard/google/brya/Kconfig index d1b6f24..3637959 100644 --- a/src/mainboard/google/brya/Kconfig +++ b/src/mainboard/google/brya/Kconfig @@ -77,6 +77,7 @@ default "Redrix" if BOARD_GOOGLE_REDRIX default "Kano" if BOARD_GOOGLE_KANO default "Taeko" if BOARD_GOOGLE_TAEKO + default "Felwinter" if BOARD_GOOGLE_FELWINTER
config VARIANT_DIR default "brya0" if BOARD_GOOGLE_BRYA0 @@ -85,6 +86,7 @@ default "redrix" if BOARD_GOOGLE_REDRIX default "kano" if BOARD_GOOGLE_KANO default "taeko" if BOARD_GOOGLE_TAEKO + default "felwinter" if BOARD_GOOGLE_FELWINTER
config DIMM_SPD_SIZE int diff --git a/src/mainboard/google/brya/Kconfig.name b/src/mainboard/google/brya/Kconfig.name index 657c411..f11a998 100644 --- a/src/mainboard/google/brya/Kconfig.name +++ b/src/mainboard/google/brya/Kconfig.name @@ -30,3 +30,7 @@ config BOARD_GOOGLE_TAEKO bool "-> Taeko" select BOARD_GOOGLE_BASEBOARD_BRYA + +config BOARD_GOOGLE_FELWINTER + bool "-> Felwinter" + select BOARD_GOOGLE_BASEBOARD_BRYA diff --git a/src/mainboard/google/brya/variants/felwinter/include/variant/ec.h b/src/mainboard/google/brya/variants/felwinter/include/variant/ec.h new file mode 100644 index 0000000..7a2a6ff --- /dev/null +++ b/src/mainboard/google/brya/variants/felwinter/include/variant/ec.h @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#ifndef __VARIANT_EC_H__ +#define __VARIANT_EC_H__ + +#include <baseboard/ec.h> + +#endif diff --git a/src/mainboard/google/brya/variants/felwinter/include/variant/gpio.h b/src/mainboard/google/brya/variants/felwinter/include/variant/gpio.h new file mode 100644 index 0000000..c4fe342 --- /dev/null +++ b/src/mainboard/google/brya/variants/felwinter/include/variant/gpio.h @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#ifndef VARIANT_GPIO_H +#define VARIANT_GPIO_H + +#include <baseboard/gpio.h> + +#endif diff --git a/src/mainboard/google/brya/variants/felwinter/memory/Makefile.inc b/src/mainboard/google/brya/variants/felwinter/memory/Makefile.inc new file mode 100644 index 0000000..b0ca222 --- /dev/null +++ b/src/mainboard/google/brya/variants/felwinter/memory/Makefile.inc @@ -0,0 +1,5 @@ +## SPDX-License-Identifier: GPL-2.0-or-later +## This is an auto-generated file. Do not edit!! +## Add memory parts in mem_parts_used.txt and run spd_tools to regenerate. + +SPD_SOURCES = placeholder.spd.hex diff --git a/src/mainboard/google/brya/variants/felwinter/memory/dram_id.generated.txt b/src/mainboard/google/brya/variants/felwinter/memory/dram_id.generated.txt new file mode 100644 index 0000000..fa24790 --- /dev/null +++ b/src/mainboard/google/brya/variants/felwinter/memory/dram_id.generated.txt @@ -0,0 +1 @@ +DRAM Part Name ID to assign diff --git a/src/mainboard/google/brya/variants/felwinter/memory/mem_parts_used.txt b/src/mainboard/google/brya/variants/felwinter/memory/mem_parts_used.txt new file mode 100644 index 0000000..9cff262 --- /dev/null +++ b/src/mainboard/google/brya/variants/felwinter/memory/mem_parts_used.txt @@ -0,0 +1,11 @@ +# This is a CSV file containing a list of memory parts used by this variant. +# One part per line with an optional fixed ID in column 2. +# Only include a fixed ID if it is required for legacy reasons! +# Generated IDs are dependent on the order of parts in this file, +# so new parts must always be added at the end of the file! +# +# Generate an updated Makefile.inc and dram_id.generated.txt by running the +# gen_part_id tool from util/spd_tools/lp4x. +# See util/spd_tools/lp4x/README.md for more details and instructions. + +# Part Name diff --git a/src/mainboard/google/brya/variants/felwinter/overridetree.cb b/src/mainboard/google/brya/variants/felwinter/overridetree.cb new file mode 100644 index 0000000..4f2c04a --- /dev/null +++ b/src/mainboard/google/brya/variants/felwinter/overridetree.cb @@ -0,0 +1,6 @@ +chip soc/intel/alderlake + + device domain 0 on + end + +end
