Subrata Banik has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/60789 )
Change subject: soc/intel/alderlake: Fix GPIO reset mapping as per GPIO BWG ......................................................................
This patch fixes the documentation discrepancy of GPIO reset type between PCH EDS and GPIO BWG. As per GPIO BWG, there are 4-GPIO reset types in Alder Lake as below: - Power Good - (Value 00) - Deep - (Value 01) - Host Reset/PLTRST - (Value 10) - RSMRST for GPD/Reserved for GPP - (Value 11)
Hence, created two different reset types for `GPP` and `GPD`. Also, replaced PAD_CFG0_LOGICAL_RESET_x macros with PAD_RESET().
BUG=b:213293047
Signed-off-by: Subrata Banik subratabanik@google.com Change-Id: I4b8742c7a0cc1dc420e3e22e34a16355294ed61b --- M src/soc/intel/alderlake/gpio.c 1 file changed, 23 insertions(+), 23 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/89/60789/1
diff --git a/src/soc/intel/alderlake/gpio.c b/src/soc/intel/alderlake/gpio.c index aa05136e..3d5af83 100644 --- a/src/soc/intel/alderlake/gpio.c +++ b/src/soc/intel/alderlake/gpio.c @@ -9,20 +9,20 @@
/* * This file is created based on Intel Alder Lake Processor PCH Datasheet - * Document number: 630094 - * Chapter number: 27 + * Document number: 630094, Chapter number: 27 + * Document number: 630603, Chapter number: 16 */
-static const struct reset_mapping rst_map[] = { - { .logical = PAD_CFG0_LOGICAL_RESET_RSMRST, .chipset = 0U << 30 }, - { .logical = PAD_CFG0_LOGICAL_RESET_DEEP, .chipset = 1U << 30 }, - { .logical = PAD_CFG0_LOGICAL_RESET_PLTRST, .chipset = 2U << 30 }, +static const struct reset_mapping rst_map_gpp[] = { + { .logical = PAD_RESET(PWROK), .chipset = 0U << 30 }, + { .logical = PAD_RESET(DEEP), .chipset = 1U << 30 }, + { .logical = PAD_RESET(PLTRST), .chipset = 2U << 30 }, }; -static const struct reset_mapping rst_map_com2[] = { - { .logical = PAD_CFG0_LOGICAL_RESET_PWROK, .chipset = 0U << 30 }, - { .logical = PAD_CFG0_LOGICAL_RESET_DEEP, .chipset = 1U << 30 }, - { .logical = PAD_CFG0_LOGICAL_RESET_PLTRST, .chipset = 2U << 30 }, - { .logical = PAD_CFG0_LOGICAL_RESET_RSMRST, .chipset = 3U << 30 }, +static const struct reset_mapping rst_map_gpd[] = { + { .logical = PAD_RESET(PWROK), .chipset = 0U << 30 }, + { .logical = PAD_RESET(DEEP), .chipset = 1U << 30 }, + { .logical = PAD_RESET(PLTRST), .chipset = 2U << 30 }, + { .logical = PAD_RESET(RSMRST), .chipset = 3U << 30 }, };
/* @@ -104,8 +104,8 @@ .max_pads_per_group = GPIO_MAX_NUM_PER_GROUP, .name = "GPP_BTA", .acpi_path = "\_SB.PCI0.GPIO", - .reset_map = rst_map, - .num_reset_vals = ARRAY_SIZE(rst_map), + .reset_map = rst_map_gpp, + .num_reset_vals = ARRAY_SIZE(rst_map_gpp), .groups = adl_community0_groups, .num_groups = ARRAY_SIZE(adl_community0_groups), .vw_base = DEFAULT_VW_BASE, @@ -128,8 +128,8 @@ .max_pads_per_group = GPIO_MAX_NUM_PER_GROUP, .name = "GPP_SDH", .acpi_path = "\_SB.PCI0.GPIO", - .reset_map = rst_map, - .num_reset_vals = ARRAY_SIZE(rst_map), + .reset_map = rst_map_gpp, + .num_reset_vals = ARRAY_SIZE(rst_map_gpp), .groups = adl_community1_groups, .num_groups = ARRAY_SIZE(adl_community1_groups), .vw_base = DEFAULT_VW_BASE, @@ -151,8 +151,8 @@ .max_pads_per_group = GPIO_MAX_NUM_PER_GROUP, .name = "GPD", .acpi_path = "\_SB.PCI0.GPIO", - .reset_map = rst_map_com2, - .num_reset_vals = ARRAY_SIZE(rst_map_com2), + .reset_map = rst_map_gpd, + .num_reset_vals = ARRAY_SIZE(rst_map_gpd), .groups = adl_community2_groups, .num_groups = ARRAY_SIZE(adl_community2_groups), }, @@ -171,8 +171,8 @@ .max_pads_per_group = GPIO_MAX_NUM_PER_GROUP, .name = "GPP_VGPIO", .acpi_path = "\_SB.PCI0.GPIO", - .reset_map = rst_map, - .num_reset_vals = ARRAY_SIZE(rst_map), + .reset_map = rst_map_gpp, + .num_reset_vals = ARRAY_SIZE(rst_map_gpp), .groups = adl_community3_groups, .num_groups = ARRAY_SIZE(adl_community3_groups), }, @@ -192,8 +192,8 @@ .max_pads_per_group = GPIO_MAX_NUM_PER_GROUP, .name = "GPP_FCE", .acpi_path = "\_SB.PCI0.GPIO", - .reset_map = rst_map, - .num_reset_vals = ARRAY_SIZE(rst_map), + .reset_map = rst_map_gpp, + .num_reset_vals = ARRAY_SIZE(rst_map_gpp), .groups = adl_community4_groups, .num_groups = ARRAY_SIZE(adl_community4_groups), .vw_base = DEFAULT_VW_BASE, @@ -216,8 +216,8 @@ .max_pads_per_group = GPIO_MAX_NUM_PER_GROUP, .name = "GPP_RSPI0", .acpi_path = "\_SB.PCI0.GPIO", - .reset_map = rst_map, - .num_reset_vals = ARRAY_SIZE(rst_map), + .reset_map = rst_map_gpp, + .num_reset_vals = ARRAY_SIZE(rst_map_gpp), .groups = adl_community5_groups, .num_groups = ARRAY_SIZE(adl_community5_groups), }
