Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/73231 )
Change subject: soc/amd/*/acpi: add comment about p_lvl[2,3]_lat FADT field usage ......................................................................
The latency values in the _CST package override the values in the p_lvl2_lat and p_lvl3_lat FADT fields. In Picasso, Cezanne, Mendocino, Phoenix and Glinda generate_cpu_entries generates the _CST packages for each CPU device. The coreboot code for Stoneyridge doesn't generate _CST packages for the CPU objects, but those are provided via the PSTATE SSDT binaryPI generates and agesa_write_acpi_tables gets and adds to the ACPI tables. The AGESA reference code also sets those two FADT entries to the equivalents of ACPI_FADT_C2_NOT_SUPPORTED and ACPI_FADT_C3_NOT_SUPPORTED so this also matches the AGESA behavior.
From the ACPI 6.4 spec: "Values provided by the _CST object override P_LVLx values in P_BLK and P_LVLx_LAT values in the FADT."
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: I1116a3013576b18b6f521604d6b0a9d75b971e0b Reviewed-on: https://review.coreboot.org/c/coreboot/+/73231 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Martin Roth martin.roth@amd.corp-partner.google.com --- M src/soc/amd/cezanne/acpi.c M src/soc/amd/glinda/acpi.c M src/soc/amd/mendocino/acpi.c M src/soc/amd/phoenix/acpi.c M src/soc/amd/picasso/acpi.c M src/soc/amd/stoneyridge/acpi.c 6 files changed, 38 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Martin Roth: Looks good to me, approved
diff --git a/src/soc/amd/cezanne/acpi.c b/src/soc/amd/cezanne/acpi.c index edf20c9..631f388 100644 --- a/src/soc/amd/cezanne/acpi.c +++ b/src/soc/amd/cezanne/acpi.c @@ -76,6 +76,8 @@
fill_fadt_extended_pm_regs(fadt);
+ /* p_lvl2_lat and p_lvl3_lat match what the AGESA code does, but those values are + overridden by the _CST packages in the processor devices. */ fadt->p_lvl2_lat = ACPI_FADT_C2_NOT_SUPPORTED; fadt->p_lvl3_lat = ACPI_FADT_C3_NOT_SUPPORTED; fadt->duty_offset = 0; /* Not supported */ diff --git a/src/soc/amd/glinda/acpi.c b/src/soc/amd/glinda/acpi.c index 8d6c008..31723b1 100644 --- a/src/soc/amd/glinda/acpi.c +++ b/src/soc/amd/glinda/acpi.c @@ -79,6 +79,8 @@
+ /* p_lvl2_lat and p_lvl3_lat match what the AGESA code does, but those values are + overridden by the _CST packages in the processor devices. */ fadt->p_lvl2_lat = ACPI_FADT_C2_NOT_SUPPORTED; fadt->p_lvl3_lat = ACPI_FADT_C3_NOT_SUPPORTED; fadt->duty_offset = 0; /* Not supported */ diff --git a/src/soc/amd/mendocino/acpi.c b/src/soc/amd/mendocino/acpi.c index 6b20b02..044b345 100644 --- a/src/soc/amd/mendocino/acpi.c +++ b/src/soc/amd/mendocino/acpi.c @@ -78,6 +78,8 @@
+ /* p_lvl2_lat and p_lvl3_lat match what the AGESA code does, but those values are + overridden by the _CST packages in the processor devices. */ fadt->p_lvl2_lat = ACPI_FADT_C2_NOT_SUPPORTED; fadt->p_lvl3_lat = ACPI_FADT_C3_NOT_SUPPORTED; fadt->duty_offset = 0; /* Not supported */ diff --git a/src/soc/amd/phoenix/acpi.c b/src/soc/amd/phoenix/acpi.c index 32dde83..09c4a15 100644 --- a/src/soc/amd/phoenix/acpi.c +++ b/src/soc/amd/phoenix/acpi.c @@ -79,6 +79,8 @@
+ /* p_lvl2_lat and p_lvl3_lat match what the AGESA code does, but those values are + overridden by the _CST packages in the processor devices. */ fadt->p_lvl2_lat = ACPI_FADT_C2_NOT_SUPPORTED; fadt->p_lvl3_lat = ACPI_FADT_C3_NOT_SUPPORTED; fadt->duty_offset = 0; /* Not supported */ diff --git a/src/soc/amd/picasso/acpi.c b/src/soc/amd/picasso/acpi.c index 1d5a275..f6fb9f2 100644 --- a/src/soc/amd/picasso/acpi.c +++ b/src/soc/amd/picasso/acpi.c @@ -82,6 +82,8 @@
+ /* p_lvl2_lat and p_lvl3_lat match what the AGESA code does, but those values are + overridden by the _CST packages in the processor devices. */ fadt->p_lvl2_lat = ACPI_FADT_C2_NOT_SUPPORTED; fadt->p_lvl3_lat = ACPI_FADT_C3_NOT_SUPPORTED; fadt->duty_offset = 1; /* CLK_VAL bits 3:1 */ diff --git a/src/soc/amd/stoneyridge/acpi.c b/src/soc/amd/stoneyridge/acpi.c index e2fb2e3..3b45a5f 100644 --- a/src/soc/amd/stoneyridge/acpi.c +++ b/src/soc/amd/stoneyridge/acpi.c @@ -74,6 +74,8 @@
+ /* p_lvl2_lat and p_lvl3_lat match what the AGESA code does, but those values are + overridden by the _CST packages in the PSTATE SSDT. */ fadt->p_lvl2_lat = ACPI_FADT_C2_NOT_SUPPORTED; fadt->p_lvl3_lat = ACPI_FADT_C3_NOT_SUPPORTED; fadt->duty_offset = 1; /* CLK_VAL bits 3:1 */
