HAOUAS Elyes (ehaouas@noos.fr) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/14456
commit be4c6497df9e0e5626f431f73dbab1e7720dc55a Author: Elyes HAOUAS ehaouas@noos.fr Date: Thu Apr 21 22:14:51 2016 +0200
Northbridge/i945 fix fsbclk function.
According "64-ia-32-architectures-software-developer-manual-325462.pdf" and mobile-945-express-chipset-datasheet.pdf, (MCHBAR32(CLKCFG) & 7) value should be equal to MSR_FSB_FREQ.
Change-Id: I7dcdc641d647b45a086098a316043883d0b3fefb Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- src/northbridge/intel/i945/raminit.c | 32 ++++++++++++++++---------------- 1 file changed, 16 insertions(+), 16 deletions(-)
diff --git a/src/northbridge/intel/i945/raminit.c b/src/northbridge/intel/i945/raminit.c index 59a31de..a8cf2e3 100644 --- a/src/northbridge/intel/i945/raminit.c +++ b/src/northbridge/intel/i945/raminit.c @@ -119,29 +119,29 @@ static int memclk(void) return -1; }
-#if CONFIG_NORTHBRIDGE_INTEL_SUBTYPE_I945GM -static u16 fsbclk(void) -{ - switch (MCHBAR32(CLKCFG) & 7) { - case 0: return 400; - case 1: return 533; - case 3: return 667; - default: printk(BIOS_DEBUG, "fsbclk: unknown register value %x\n", MCHBAR32(CLKCFG) & 7); - } - return 0xffff; -} -#elif CONFIG_NORTHBRIDGE_INTEL_SUBTYPE_I945GC static u16 fsbclk(void) { switch (MCHBAR32(CLKCFG) & 7) { - case 0: return 1066; - case 1: return 533; - case 2: return 800; + /* should be equal to MSR_FSB_FREQ */ + case 0: + #if CONFIG_NORTHBRIDGE_INTEL_SUBTYPE_I945GM + return 400; // seems to be wrong + #elif CONFIG_NORTHBRIDGE_INTEL_SUBTYPE_I945GC + return 1066; // 266.67 MHz should be utilized if + // performing calculation with System Bus Speed + #endif + case 1: return 533; // 133.33 MHz + case 2: return 800; // 200 MHz + case 3: return 667; // 166.67 MHz + case 4: return 1333; // 333.33 MHz + case 5: return 400; // 100 MHz + case 6: return 1600; // 400 MHz + case 7: return 333; // 83 MHz + default: printk(BIOS_DEBUG, "fsbclk: unknown register value %x\n", MCHBAR32(CLKCFG) & 7); } return 0xffff; } -#endif
static int sdram_capabilities_max_supported_memory_frequency(void) {
