Aaron Durbin (adurbin@chromium.org) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/12788
commit a451cdd2e54cfb2d180190c6874f1a08fed52574 Author: Patrick Georgi pgeorgi@google.com Date: Fri Nov 20 21:48:18 2015 +0100
cbfstool: Adapt "cbfstool copy" to only use fmap regions.
These need to go together, so the commit became a bit larger than typial.
- Add an option -R for the copy source fmap region. Use: cbfstool copy -r target-region -R source-region. - Don't generate a CBFS master header because for fmap regions, we assume that the region starts with a file header. Use cbfstool add-master-header to add it afterwards, if necessary. - Don't copy files of type "cbfs master header" (which are what cbfstool add-master-header creates) - Leave room for the master header pointer - Remove -D command line option as it's no longer used.
BUG=chromium:445938 BRANCH=none TEST=Manual test on image and integration test w/ bundle_firmware changes. CQ-DEPEND=CL:313770,CL:313771
Change-Id: I2a11cda42caee96aa763f162b5f3bc11bb7992f9 Signed-off-by: Patrick Georgi pgeorgi@google.com Signed-off-by: Aaron Durbin adurbin@chromium.org --- util/cbfstool/cbfs_image.c | 29 ++++++++------------------ util/cbfstool/cbfstool.c | 52 ++++++++++++++++++---------------------------- 2 files changed, 29 insertions(+), 52 deletions(-)
diff --git a/util/cbfstool/cbfs_image.c b/util/cbfstool/cbfs_image.c index 25aafe9..3820c40 100644 --- a/util/cbfstool/cbfs_image.c +++ b/util/cbfstool/cbfs_image.c @@ -390,31 +390,16 @@ int cbfs_image_from_buffer(struct cbfs_image *out, struct buffer *in, int cbfs_copy_instance(struct cbfs_image *image, struct buffer *dst) { assert(image); - if (!cbfs_is_legacy_cbfs(image)) - return -1;
struct cbfs_file *src_entry, *dst_entry; - struct cbfs_header *copy_header; - size_t align, entry_offset; + size_t align; ssize_t last_entry_size;
size_t copy_end = buffer_size(dst);
- align = image->header.align; - - /* This will work, let's create a copy. */ - copy_header = (struct cbfs_header *)buffer_get(dst); - cbfs_put_header(copy_header, &image->header); + align = CBFS_ENTRY_ALIGNMENT;
- copy_header->bootblocksize = 0; - /* FIXME: romsize and offset have a full-flash interpretation even - * though they don't need to and should be region-relative (where - * region is sufficiently specified by the master header pointer. - * But that's for a later change. */ - copy_header->romsize = htonl(dst->offset + buffer_size(dst)); - entry_offset = align_up(sizeof(*copy_header), align); - copy_header->offset = htonl(dst->offset + entry_offset); - dst_entry = (struct cbfs_file *)(buffer_get(dst) + entry_offset); + dst_entry = (struct cbfs_file *)buffer_get(dst);
/* Copy non-empty files */ for (src_entry = cbfs_find_first_entry(image); @@ -423,6 +408,7 @@ int cbfs_copy_instance(struct cbfs_image *image, struct buffer *dst) size_t entry_size;
if ((src_entry->type == htonl(CBFS_COMPONENT_NULL)) || + (src_entry->type == htonl(CBFS_COMPONENT_CBFSHEADER)) || (src_entry->type == htonl(CBFS_COMPONENT_DELETED))) continue;
@@ -438,9 +424,12 @@ int cbfs_copy_instance(struct cbfs_image *image, struct buffer *dst) } }
- /* Last entry size is all the room above it. */ + /* Last entry size is all the room above it, except for top 4 bytes + * which may be used by the master header pointer. This messes with + * the ability to stash something "top-aligned" into the region, but + * keeps things simpler. */ last_entry_size = copy_end - ((void *)dst_entry - buffer_get(dst)) - - cbfs_calculate_file_header_size(""); + - cbfs_calculate_file_header_size("") - sizeof(int32_t);
if (last_entry_size < 0) WARN("No room to create the last entry!\n") diff --git a/util/cbfstool/cbfstool.c b/util/cbfstool/cbfstool.c index c9a9564..f00aa30 100644 --- a/util/cbfstool/cbfstool.c +++ b/util/cbfstool/cbfstool.c @@ -49,6 +49,7 @@ static struct param { const char *filename; const char *fmap; const char *region_name; + const char *source_region; const char *bootblock; const char *ignore_section; uint64_t u64val; @@ -56,8 +57,6 @@ static struct param { uint32_t baseaddress; uint32_t baseaddress_assigned; uint32_t loadaddress; - uint32_t copyoffset; - uint32_t copyoffset_assigned; uint32_t headeroffset; uint32_t headeroffset_assigned; uint32_t entrypoint; @@ -917,34 +916,25 @@ static int cbfs_update_fit(void)
static int cbfs_copy(void) { - /* always a valid source region */ struct cbfs_image src_image; + struct buffer src_buf;
- if (cbfs_image_from_buffer(&src_image, param.image_region, - param.headeroffset)) + if (!param.source_region) { + ERROR("You need to specify -R/--source-region.\n"); return 1; + }
- struct buffer dst_buffer; - - if (cbfs_is_legacy_cbfs(&src_image)) { - if (!param.copyoffset_assigned) { - ERROR("You need to specify -D/--copy-offset.\n"); - return 1; - } - - if (!param.size) { - ERROR("You need to specify -s/--size.\n"); - return 1; - } - - buffer_splice(&dst_buffer, param.image_region, - param.copyoffset, param.size); - } else { - ERROR("This operation is only valid on legacy images having CBFS master headers\n"); + /* Obtain the source region and convert it to a cbfs_image. */ + if (!partitioned_file_read_region(&src_buf, param.image_file, + param.source_region)) { + ERROR("Region not found in image: %s\n", param.source_region); return 1; }
- return cbfs_copy_instance(&src_image, &dst_buffer); + if (cbfs_image_from_buffer(&src_image, &src_buf, param.headeroffset)) + return 1; + + return cbfs_copy_instance(&src_image, param.image_region); }
static const struct command commands[] = { @@ -955,7 +945,7 @@ static const struct command commands[] = { {"add-stage", "a:H:r:f:n:t:c:b:P:S:yvA:h?", cbfs_add_stage, true, true}, {"add-int", "H:r:i:n:b:vh?", cbfs_add_integer, true, true}, {"add-master-header", "H:r:vh?", cbfs_add_master_header, true, true}, - {"copy", "H:D:s:h?", cbfs_copy, true, true}, + {"copy", "r:R:h?", cbfs_copy, true, true}, {"create", "M:r:s:B:b:H:o:m:vh?", cbfs_create, true, true}, {"extract", "H:r:m:n:f:vh?", cbfs_extract, true, false}, {"layout", "wvh?", cbfs_layout, false, false}, @@ -972,7 +962,6 @@ static struct option long_options[] = { {"bootblock", required_argument, 0, 'B' }, {"cmdline", required_argument, 0, 'C' }, {"compression", required_argument, 0, 'c' }, - {"copy-offset", required_argument, 0, 'D' }, {"empty-fits", required_argument, 0, 'x' }, {"entry-point", required_argument, 0, 'e' }, {"file", required_argument, 0, 'f' }, @@ -980,6 +969,7 @@ static struct option long_options[] = { {"fill-upward", no_argument, 0, 'u' }, {"flashmap", required_argument, 0, 'M' }, {"fmap-regions", required_argument, 0, 'r' }, + {"source-region", required_argument, 0, 'R' }, {"hash-algorithm",required_argument, 0, 'A' }, {"header-offset", required_argument, 0, 'H' }, {"help", no_argument, 0, 'h' }, @@ -1085,9 +1075,8 @@ static void usage(char *name) "Add a legacy CBFS master header\n" " remove [-r image,regions] -n NAME " "Remove a component\n" - " copy -D new_header_offset -s region size \\n" - " [-H source header offset] " - "Create a copy (duplicate) cbfs instance*\n" + " copy -r image,regions -R source-region " + "Create a copy (duplicate) cbfs instance in fmap\n" " create -m ARCH -s size [-b bootblock offset] \\n" " [-o CBFS offset] [-H header offset] [-B bootblock] " "Create a legacy ROM file with CBFS master header*\n" @@ -1216,6 +1205,9 @@ int main(int argc, char **argv) case 'r': param.region_name = optarg; break; + case 'R': + param.source_region = optarg; + break; case 'b': param.baseaddress = strtoul(optarg, NULL, 0); // baseaddress may be zero on non-x86, so we @@ -1246,10 +1238,6 @@ int main(int argc, char **argv) optarg, NULL, 0); param.headeroffset_assigned = 1; break; - case 'D': - param.copyoffset = strtoul(optarg, NULL, 0); - param.copyoffset_assigned = 1; - break; case 'a': param.alignment = strtoul(optarg, NULL, 0); break;
