Attention is currently required from: Jason Glenesk, Furquan Shaikh, Marshall Dawson, Karthik Ramasubramanian, Felix Held. Hello build bot (Jenkins), Jason Glenesk, Furquan Shaikh, Marshall Dawson, Karthik Ramasubramanian, Felix Held,
https://review.coreboot.org/c/coreboot/+/56578
Change subject: soc/amd/common/block/cpu: Add support for cbfs_cache region ......................................................................
This change adds the cbfs_cache region into the x86 memlayout. The SoC or mainboard can decide how big the region should be by specifying CBFS_CACHE_SIZE.
BUG=b:179699789 TEST=Build guybrush and verify cbfs_cache region wasn't added.
Signed-off-by: Raul E Rangel rrangel@chromium.org Change-Id: I268b6bc10906932ee94f795684a28cfac247a68c --- M src/soc/amd/common/block/cpu/Kconfig M src/soc/amd/common/block/cpu/noncar/memlayout_x86.ld 2 files changed, 14 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/78/56578/10
