Attention is currently required from: Sean Rhodes, Arthur Heymans.
Hello build bot (Jenkins), Nico Huber, Sean Rhodes, Lean Sheng Tan,
https://review.coreboot.org/c/coreboot/+/72705
Change subject: soc/intel/apl: Hook up cpu ops in devicetree ......................................................................
This simplifies the code flow of the cpu init. APL can do CPU init after calling FSP-S, while GLK needs to do that before. This is now reflected directly in the cpu ops rather than using CONFIG_SOC_INTEL_COMMON_BLOCK_CPU_MPINIT as a proxy.
Change-Id: I7fd1db72ca98f0a1b8fd03a979308a7c701a8a54 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/soc/intel/apollolake/chip.c M src/soc/intel/apollolake/chipset_apl.cb M src/soc/intel/apollolake/chipset_glk.cb M src/soc/intel/apollolake/cpu.c 4 files changed, 24 insertions(+), 7 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/05/72705/2
