Marc Jones (marc@marcjonesconsulting.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/17220
commit 8ac5ca71591ea79db791a57f5879c804b6b3ae2f Author: Marshall Dawson marshalldawson3rd@gmail.com Date: Sat Oct 8 10:04:21 2016 -0600
amd/gardenia: Remove rev-specific storage setup
Gardenia doesn't have the ability to modify settings depending on the board ID.
Original-Signed-off-by: Marshall Dawson marshalldawson3rd@gmail.com Original-Reviewed-by: Marc Jones marcj303@gmail.com (cherry picked from commit 536b4c424e5259ddbd82469f5f426d3189ff3f89)
Change-Id: I2c928431306c669735cf735042855e95721bb107 Signed-off-by: Marc Jones marcj303@gmail.com --- src/mainboard/amd/gardenia/BiosCallOuts.c | 8 -------- 1 file changed, 8 deletions(-)
diff --git a/src/mainboard/amd/gardenia/BiosCallOuts.c b/src/mainboard/amd/gardenia/BiosCallOuts.c index 44644ce..f7c16b9 100644 --- a/src/mainboard/amd/gardenia/BiosCallOuts.c +++ b/src/mainboard/amd/gardenia/BiosCallOuts.c @@ -32,7 +32,6 @@ #include "northbridge/amd/pi/dimmSpd.h" #include "northbridge/amd/pi/agesawrapper.h" #include <PlatformMemoryConfiguration.h> -#include <boardid.h>
static AGESA_STATUS Fch_Oem_config(UINT32 Func, UINT32 FchData, VOID *ConfigPtr);
@@ -90,13 +89,6 @@ AGESA_STATUS Fch_Oem_config(UINT32 Func, UINT32 FchData, VOID *ConfigPtr) #endif FchParams_env->Usb.Xhci1Enable = FALSE; FchParams_env->Usb.USB30PortInit = 8; /* 8: If USB3 port is unremoveable. */ - - /* sata configuration */ - /* SD configuration */ - /* Rev F has an on-board eMMC, which only supports SD 2.0 */ - if (board_id() == 'F') { - FchParams_env->Sd.SdConfig = SdVer2; - } } printk(BIOS_DEBUG, "Done\n");
