Pratikkumar V Prajapati has uploaded this change for review. ( https://review.coreboot.org/21339
Change subject: [WIP]src/soc/intel/cannonlake: Define USB AFE params ......................................................................
Change-Id: I42243950366d672e886158eb1934350f47b4ff1f Signed-off-by: Pratik Prajapati pratikkumar.v.prajapati@intel.com --- M src/soc/intel/cannonlake/include/soc/usb.h 1 file changed, 49 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/39/21339/1
diff --git a/src/soc/intel/cannonlake/include/soc/usb.h b/src/soc/intel/cannonlake/include/soc/usb.h index eac017e..c02949f 100644 --- a/src/soc/intel/cannonlake/include/soc/usb.h +++ b/src/soc/intel/cannonlake/include/soc/usb.h @@ -19,6 +19,25 @@
#include <stdint.h>
+/* Per Port HS Transmitter Emphasis */ +#define USB2_EMP_OFF 0 +#define USB2_DE_EMP_ON 1 +#define USB2_PRE_EMP_ON 2 +#define USB2_DE_EMP_ON_PRE_EMP_ON 3 + +/* Per Port Half Bit Pre-emphasis */ +#define USB2_FULL_BIT_PRE_EMP 0 +#define USB2_HALF_BIT_PRE_EMP 1 + +/* Per Port HS Preemphasis Bias */ +#define USB2_BIAS_0MV 0 +#define USB2_BIAS_11P25MV 1 +#define USB2_BIAS_16P9MV 2 +#define USB2_BIAS_28P15MV 3 +#define USB2_BIAS_39P35MV 5 +#define USB2_BIAS_45MV 6 +#define USB2_BIAS_56P3MV 7 + struct usb2_port_config { uint8_t enable; uint8_t ocpin; @@ -28,6 +47,29 @@ uint8_t pre_emp_bit; };
+/* USB Overcurrent pins definition */ +enum { + OC0 = 0, + OC1, + OC2, + OC3, + OC4, + OC5, + OC6, + OC7, + OCMAX, + OC_SKIP = 0xff, /* Skip OC programming */ +}; + +#define USB2_PORT_EMPTY { \ + .enable = 0, \ + .ocpin = OC_SKIP, \ + .tx_bias = USB2_BIAS_0MV, \ + .tx_emp_enable = USB2_EMP_OFF, \ + .pre_emp_bias = USB2_BIAS_0MV, \ + .pre_emp_bit = USB2_HALF_BIT_PRE_EMP, \ +} + struct usb3_port_config { uint8_t enable; uint8_t ocpin; @@ -35,4 +77,11 @@ uint8_t tx_downscale_amp; };
+#define USB3_PORT_EMPTY { \ + .enable = 0, \ + .ocpin = OC_SKIP, \ + .tx_de_emp = 0x00, \ + .tx_downscale_amp = 0x00, \ +} + #endif
