[PATCH 1/2] virtio: Use threads when scanning for virtio devices
Signed-off-by: Kevin O'Connor <kevin@koconnor.net> --- src/hw/virtio-blk.c | 6 ++++-- src/hw/virtio-scsi.c | 6 ++++-- 2 files changed, 8 insertions(+), 4 deletions(-) diff --git a/src/hw/virtio-blk.c b/src/hw/virtio-blk.c index 2dfd0c3..dca7855 100644 --- a/src/hw/virtio-blk.c +++ b/src/hw/virtio-blk.c @@ -15,6 +15,7 @@ #include "pcidevice.h" // foreachpci #include "pci_ids.h" // PCI_DEVICE_ID_VIRTIO_BLK #include "pci_regs.h" // PCI_VENDOR_ID +#include "stacks.h" // run_thread #include "std/disk.h" // DISK_RET_SUCCESS #include "string.h" // memset #include "util.h" // usleep @@ -93,8 +94,9 @@ virtio_blk_process_op(struct disk_op_s *op) } static void -init_virtio_blk(struct pci_device *pci) +init_virtio_blk(void *data) { + struct pci_device *pci = data; u8 status = VIRTIO_CONFIG_S_ACKNOWLEDGE | VIRTIO_CONFIG_S_DRIVER; dprintf(1, "found virtio-blk at %pP\n", pci); struct virtiodrive_s *vdrive = malloc_fseg(sizeof(*vdrive)); @@ -203,6 +205,6 @@ virtio_blk_setup(void) (pci->device != PCI_DEVICE_ID_VIRTIO_BLK_09 && pci->device != PCI_DEVICE_ID_VIRTIO_BLK_10)) continue; - init_virtio_blk(pci); + run_thread(init_virtio_blk, pci); } } diff --git a/src/hw/virtio-scsi.c b/src/hw/virtio-scsi.c index 322d469..5fb9409 100644 --- a/src/hw/virtio-scsi.c +++ b/src/hw/virtio-scsi.c @@ -16,6 +16,7 @@ #include "pcidevice.h" // foreachpci #include "pci_ids.h" // PCI_DEVICE_ID_VIRTIO_BLK #include "pci_regs.h" // PCI_VENDOR_ID +#include "stacks.h" // run_thread #include "std/disk.h" // DISK_RET_SUCCESS #include "string.h" // memset #include "util.h" // usleep @@ -132,8 +133,9 @@ virtio_scsi_scan_target(struct pci_device *pci, struct vp_device *vp, } static void -init_virtio_scsi(struct pci_device *pci) +init_virtio_scsi(void *data) { + struct pci_device *pci = data; dprintf(1, "found virtio-scsi at %pP\n", pci); struct vring_virtqueue *vq = NULL; struct vp_device *vp = malloc_high(sizeof(*vp)); @@ -199,6 +201,6 @@ virtio_scsi_setup(void) (pci->device != PCI_DEVICE_ID_VIRTIO_SCSI_09 && pci->device != PCI_DEVICE_ID_VIRTIO_SCSI_10)) continue; - init_virtio_scsi(pci); + run_thread(init_virtio_scsi, pci); } } -- 2.5.5
Signed-off-by: Kevin O'Connor <kevin@koconnor.net> --- src/hw/esp-scsi.c | 8 ++++---- src/hw/lsi-scsi.c | 8 ++++---- src/hw/megasas.c | 7 +++---- src/hw/mpt-scsi.c | 23 ++++++++++------------- src/hw/pvscsi.c | 8 ++++---- 5 files changed, 25 insertions(+), 29 deletions(-) diff --git a/src/hw/esp-scsi.c b/src/hw/esp-scsi.c index c98989c..d2ba023 100644 --- a/src/hw/esp-scsi.c +++ b/src/hw/esp-scsi.c @@ -20,6 +20,7 @@ #include "pcidevice.h" // foreachpci #include "pci_ids.h" // PCI_DEVICE_ID #include "pci_regs.h" // PCI_VENDOR_ID +#include "stacks.h" // run_thread #include "std/disk.h" // DISK_RET_SUCCESS #include "string.h" // memset #include "util.h" // usleep @@ -188,8 +189,9 @@ esp_scsi_scan_target(struct pci_device *pci, u32 iobase, u8 target) } static void -init_esp_scsi(struct pci_device *pci) +init_esp_scsi(void *data) { + struct pci_device *pci = data; u32 iobase = pci_enable_iobar(pci, PCI_BASE_ADDRESS_0); if (!iobase) return; @@ -203,8 +205,6 @@ init_esp_scsi(struct pci_device *pci) int i; for (i = 0; i <= 7; i++) esp_scsi_scan_target(pci, iobase, i); - - return; } void @@ -221,6 +221,6 @@ esp_scsi_setup(void) if (pci->vendor != PCI_VENDOR_ID_AMD || pci->device != PCI_DEVICE_ID_AMD_SCSI) continue; - init_esp_scsi(pci); + run_thread(init_esp_scsi, pci); } } diff --git a/src/hw/lsi-scsi.c b/src/hw/lsi-scsi.c index fd695fa..b63430d 100644 --- a/src/hw/lsi-scsi.c +++ b/src/hw/lsi-scsi.c @@ -20,6 +20,7 @@ #include "pcidevice.h" // foreachpci #include "pci_ids.h" // PCI_DEVICE_ID_VIRTIO_BLK #include "pci_regs.h" // PCI_VENDOR_ID +#include "stacks.h" // run_thread #include "std/disk.h" // DISK_RET_SUCCESS #include "string.h" // memset #include "util.h" // usleep @@ -168,8 +169,9 @@ lsi_scsi_scan_target(struct pci_device *pci, u32 iobase, u8 target) } static void -init_lsi_scsi(struct pci_device *pci) +init_lsi_scsi(void *data) { + struct pci_device *pci = data; u32 iobase = pci_enable_iobar(pci, PCI_BASE_ADDRESS_0); if (!iobase) return; @@ -183,8 +185,6 @@ init_lsi_scsi(struct pci_device *pci) int i; for (i = 0; i < 7; i++) lsi_scsi_scan_target(pci, iobase, i); - - return; } void @@ -201,6 +201,6 @@ lsi_scsi_setup(void) if (pci->vendor != PCI_VENDOR_ID_LSI_LOGIC || pci->device != PCI_DEVICE_ID_LSI_53C895A) continue; - init_lsi_scsi(pci); + run_thread(init_lsi_scsi, pci); } } diff --git a/src/hw/megasas.c b/src/hw/megasas.c index 7514164..efd0f6e 100644 --- a/src/hw/megasas.c +++ b/src/hw/megasas.c @@ -357,8 +357,9 @@ static int megasas_transition_to_ready(struct pci_device *pci, u32 ioaddr) } static void -init_megasas(struct pci_device *pci) +init_megasas(void *data) { + struct pci_device *pci = data; u32 bar = PCI_BASE_ADDRESS_2; if (!(pci_config_readl(pci->bdf, bar) & PCI_BASE_ADDRESS_IO_MASK)) bar = PCI_BASE_ADDRESS_0; @@ -372,8 +373,6 @@ init_megasas(struct pci_device *pci) // reset if (megasas_transition_to_ready(pci, iobase) == 0) megasas_scan_target(pci, iobase); - - return; } void @@ -401,6 +400,6 @@ megasas_setup(void) pci->device == PCI_DEVICE_ID_DELL_PERC5 || pci->device == PCI_DEVICE_ID_LSI_SAS2208 || pci->device == PCI_DEVICE_ID_LSI_SAS3108) - init_megasas(pci); + run_thread(init_megasas, pci); } } diff --git a/src/hw/mpt-scsi.c b/src/hw/mpt-scsi.c index 7d1aa3d..a37e44c 100644 --- a/src/hw/mpt-scsi.c +++ b/src/hw/mpt-scsi.c @@ -15,6 +15,7 @@ #include "pcidevice.h" // foreachpci #include "pci_ids.h" // PCI_DEVICE_ID #include "pci_regs.h" // PCI_VENDOR_ID +#include "stacks.h" // run_thread #include "std/disk.h" // DISK_RET_SUCCESS #include "string.h" // memset #include "util.h" // usleep @@ -241,8 +242,9 @@ mpt_out_doorbell(u8 func, u8 arg, u16 iobase) } static void -init_mpt_scsi(struct pci_device *pci, const char *dev_name) +init_mpt_scsi(void *data) { + struct pci_device *pci = data; u16 *msg_in_p; u32 iobase = pci_enable_iobar(pci, PCI_BASE_ADDRESS_0); if (!iobase) @@ -250,7 +252,8 @@ init_mpt_scsi(struct pci_device *pci, const char *dev_name) struct MptIOCInitReply MptIOCInitReply; pci_enable_busmaster(pci); - dprintf(1, "found %s at %pP, io @ %x\n", dev_name, pci, iobase); + dprintf(1, "found mpt-scsi(%04x) at %pP, io @ %x\n" + , pci->device, pci, iobase); // reset mpt_out_doorbell(MPT_DOORBELL_MSG_RESET, 0, iobase); @@ -295,16 +298,10 @@ mpt_scsi_setup(void) struct pci_device *pci; foreachpci(pci) { - if (pci->vendor == PCI_VENDOR_ID_LSI_LOGIC) { - if (pci->device == PCI_DEVICE_ID_LSI_53C1030) { - init_mpt_scsi(pci, "lsi53c1030"); - } - if (pci->device == PCI_DEVICE_ID_LSI_SAS1068) { - init_mpt_scsi(pci, "sas1068"); - } - if (pci->device == PCI_DEVICE_ID_LSI_SAS1068E) { - init_mpt_scsi(pci, "sas1068e"); - } - } + if (pci->vendor == PCI_VENDOR_ID_LSI_LOGIC + && (pci->device == PCI_DEVICE_ID_LSI_53C1030 + || pci->device == PCI_DEVICE_ID_LSI_SAS1068 + || pci->device == PCI_DEVICE_ID_LSI_SAS1068E)) + run_thread(init_mpt_scsi, pci); } } diff --git a/src/hw/pvscsi.c b/src/hw/pvscsi.c index a9d118b..05cbd91 100644 --- a/src/hw/pvscsi.c +++ b/src/hw/pvscsi.c @@ -17,6 +17,7 @@ #include "pci_ids.h" // PCI_DEVICE_ID_VMWARE_PVSCSI #include "pci_regs.h" // PCI_VENDOR_ID #include "pvscsi.h" // pvscsi_setup +#include "stacks.h" // run_thread #include "std/disk.h" // DISK_RET_SUCCESS #include "string.h" // memset #include "util.h" // usleep @@ -294,8 +295,9 @@ pvscsi_scan_target(struct pci_device *pci, void *iobase, } static void -init_pvscsi(struct pci_device *pci) +init_pvscsi(void *data) { + struct pci_device *pci = data; void *iobase = pci_enable_membar(pci, PCI_BASE_ADDRESS_0); if (!iobase) return; @@ -310,8 +312,6 @@ init_pvscsi(struct pci_device *pci) int i; for (i = 0; i < 7; i++) pvscsi_scan_target(pci, iobase, ring_dsc, i); - - return; } void @@ -328,6 +328,6 @@ pvscsi_setup(void) if (pci->vendor != PCI_VENDOR_ID_VMWARE || pci->device != PCI_DEVICE_ID_VMWARE_PVSCSI) continue; - init_pvscsi(pci); + run_thread(init_pvscsi, pci); } } -- 2.5.5
FYI, I committed this change. -Kevin
participants (1)
Kevin O'Connor
