"flashrom" command succeeded on reading chip containing one-time programmable memory on 3 trials, but "cmp" command says there are different bytes among the 3 output files.
Hello Flashrom team, As captioned. I read the flashrom man page and understand that one-time programmable memory may be out of scope of flashrom and hence the failure on my chip readings. My goal is to make a backup of the chip before I put my motherboard into production and connect it to the internet. If my motherboard is hacked and content within the chip changed, I can easily roll back the chip to a known trustable state by flashing the backed up image back into the chip. Can you please advise how I can achieve my goal? Should I go purchase a hardware flash programmer and mess with it (I don't have any electronic knowledge)? I searched the net and found "Bus Pirate", am I correct to say that it is a programmer/debugger that can talk "directly" to the chip? Would this possibly help in my case? Motherboard : ASRock X300M-STX CPU : AMD Ryzen 5600G BIOS chip : Winbond W25Q128.w "AMD fTPM switch" within BIOS: Disabled Programmer used : CH341a /w USB interface Thank you for your time considering my questions. I hope you will have a good day. Alan
Alan K.L. Mok:
Have you tried using AMD's internal flasher to read the chip? What is the full command you used to run flashrom, and what was the error? I'm a bit confused because you are looking at Bus Pirates, but list a CH341a w/ USB as the programmer used, which is also a fine external programmer. Does that mobo have one onboard? -- - don't top post Mailing list etiquette: - trim quoted reply to only relevant portions - when possible, copy and paste text instead of screenshots
participants (2)
Alan K.L. Mok -
awokd
