Change in flashrom[master]: buspirate_spi.c: Separate shutdown from failed init cleanup
Anastasia Klimchuk has uploaded this change for review. ( https://review.coreboot.org/c/flashrom/+/52877 ) Change subject: buspirate_spi.c: Separate shutdown from failed init cleanup ...................................................................... buspirate_spi.c: Separate shutdown from failed init cleanup Shutdown function was covering two different jobs here: 1) the actual shutdown which is run at the end of the driver's lifecycle and 2) cleanup in cases when initialisation failed. Now, shutdown is only doing its main job (#1), and the driver itself is doing cleanup when init fails (#2). The good thing is that now resources are released/closed immediately in cases when init fails (vs shutdown function which was run at some point later), and the driver leaves clean space after itself if init fails. And very importantly this unlocks API change which plans to move register_shutdown inside register master API, see https://review.coreboot.org/c/flashrom/+/51761 BUG=b:185191942 TEST=builds Change-Id: I04d57e2552d23a1a4a906c68539f0ccefc13e8a0 Signed-off-by: Anastasia Klimchuk <aklm@chromium.org> --- M buspirate_spi.c 1 file changed, 71 insertions(+), 49 deletions(-) git pull ssh://review.coreboot.org:29418/flashrom refs/changes/77/52877/1 diff --git a/buspirate_spi.c b/buspirate_spi.c index eee8daa..31d36cd 100644 --- a/buspirate_spi.c +++ b/buspirate_spi.c @@ -385,13 +385,6 @@ return ret; } - if (register_shutdown(buspirate_spi_shutdown, NULL) != 0) { - bp_commbufsize = 0; - free(bp_commbuf); - bp_commbuf = NULL; - return 1; - } - /* This is the brute force version, but it should work. * It is likely to fail if a previous flashrom run was aborted during a write with the new SPI commands * in firmware v5.5 because that firmware may wait for up to 4096 bytes of input before responding to @@ -403,7 +396,7 @@ /* Send the command, don't read the response. */ ret = buspirate_sendrecv(bp_commbuf, 1, 0); if (ret) - return ret; + goto init_err_cleanup_exit; /* The old way to handle responses from a Bus Pirate already in BBIO mode was to flush any * response which came in over serial. Unfortunately that does not work reliably on Linux * with FTDI USB-serial. @@ -416,19 +409,19 @@ } /* We know that 20 commands of \0 should elicit at least one BBIO1 response. */ if ((ret = buspirate_wait_for_string(bp_commbuf, "BBIO"))) - return ret; + goto init_err_cleanup_exit; /* Reset the Bus Pirate. */ bp_commbuf[0] = 0x0f; /* Send the command, don't read the response. */ if ((ret = buspirate_sendrecv(bp_commbuf, 1, 0))) - return ret; + goto init_err_cleanup_exit; if ((ret = buspirate_wait_for_string(bp_commbuf, "irate "))) - return ret; + goto init_err_cleanup_exit; /* Read the hardware version string. Last byte of the buffer is reserved for \0. */ for (i = 0; i < DEFAULT_BUFSIZE - 1; i++) { if ((ret = buspirate_sendrecv(bp_commbuf + i, 0, 1))) - return ret; + goto init_err_cleanup_exit; if (strchr("\r\n\t ", bp_commbuf[i])) break; } @@ -449,11 +442,11 @@ msg_pdbg("\n"); if ((ret = buspirate_wait_for_string(bp_commbuf, "irmware "))) - return ret; + goto init_err_cleanup_exit; /* Read the firmware version string. Last byte of the buffer is reserved for \0. */ for (i = 0; i < DEFAULT_BUFSIZE - 1; i++) { if ((ret = buspirate_sendrecv(bp_commbuf + i, 0, 1))) - return ret; + goto init_err_cleanup_exit; if (strchr("\r\n\t ", bp_commbuf[i])) break; } @@ -474,21 +467,24 @@ msg_pdbg("\n"); if ((ret = buspirate_wait_for_string(bp_commbuf, "HiZ>"))) - return ret; + goto init_err_cleanup_exit; /* Tell the user about missing SPI binary mode in firmware 2.3 and older. */ if (BP_FWVERSION(fw_version_major, fw_version_minor) < BP_FWVERSION(2, 4)) { msg_pinfo("Bus Pirate firmware 2.3 and older does not support binary SPI access.\n"); msg_pinfo("Please upgrade to the latest firmware (at least 2.4).\n"); - return SPI_PROGRAMMER_ERROR; + ret = SPI_PROGRAMMER_ERROR; + goto init_err_cleanup_exit; } /* Use fast SPI mode in firmware 5.5 and newer. */ if (BP_FWVERSION(fw_version_major, fw_version_minor) >= BP_FWVERSION(5, 5)) { msg_pdbg("Using SPI command set v2.\n"); /* Sensible default buffer size. */ - if (buspirate_commbuf_grow(260 + 5)) - return ERROR_OOM; + if (buspirate_commbuf_grow(260 + 5)) { + ret = ERROR_OOM; + goto init_err_cleanup_exit; + } spi_master_buspirate.max_data_read = 2048; spi_master_buspirate.max_data_write = 256; spi_master_buspirate.command = buspirate_spi_send_command_v2; @@ -497,8 +493,10 @@ msg_pinfo("Reading/writing a flash chip may take hours.\n"); msg_pinfo("It is recommended to upgrade to firmware 5.5 or newer.\n"); /* Sensible default buffer size. */ - if (buspirate_commbuf_grow(16 + 3)) - return ERROR_OOM; + if (buspirate_commbuf_grow(16 + 3)) { + ret = ERROR_OOM; + goto init_err_cleanup_exit; + } spi_master_buspirate.max_data_read = 12; spi_master_buspirate.max_data_write = 12; spi_master_buspirate.command = buspirate_spi_send_command_v1; @@ -538,37 +536,37 @@ /* Enter baud rate configuration mode */ cnt = snprintf((char *)bp_commbuf, DEFAULT_BUFSIZE, "b\n"); if ((ret = buspirate_sendrecv(bp_commbuf, cnt, 0))) - return ret; + goto init_err_cleanup_exit; if ((ret = buspirate_wait_for_string(bp_commbuf, ">"))) - return ret; + goto init_err_cleanup_exit; /* Enter manual clock divisor entry mode */ cnt = snprintf((char *)bp_commbuf, DEFAULT_BUFSIZE, "10\n"); if ((ret = buspirate_sendrecv(bp_commbuf, cnt, 0))) - return ret; + goto init_err_cleanup_exit; if ((ret = buspirate_wait_for_string(bp_commbuf, ">"))) - return ret; + goto init_err_cleanup_exit; /* Set the clock divisor to the value calculated from the user's input */ cnt = snprintf((char *)bp_commbuf, DEFAULT_BUFSIZE, "%d\n", BP_DIVISOR(serialspeeds[serialspeed_index].speed)); if ((ret = buspirate_sendrecv(bp_commbuf, cnt, 0))) - return ret; + goto init_err_cleanup_exit; sleep(1); /* Reconfigure the host's serial baud rate to the new value */ if ((ret = serialport_config(sp_fd, serialspeeds[serialspeed_index].speed))) { msg_perr("Unable to configure system baud rate to specified value."); - return ret; + goto init_err_cleanup_exit; } /* Return to the main prompt */ bp_commbuf[0] = ' '; if ((ret = buspirate_sendrecv(bp_commbuf, 1, 0))) - return ret; + goto init_err_cleanup_exit; if ((ret = buspirate_wait_for_string(bp_commbuf, "HiZ>"))) - return ret; + goto init_err_cleanup_exit; msg_pdbg("Serial speed is %d baud\n", serialspeeds[serialspeed_index].speed); } @@ -581,30 +579,34 @@ for (i = 0; i < 20; i++) { bp_commbuf[0] = 0x00; if ((ret = buspirate_sendrecv(bp_commbuf, 1, 0))) - return ret; + goto init_err_cleanup_exit; } if ((ret = buspirate_wait_for_string(bp_commbuf, "BBIO"))) - return ret; + goto init_err_cleanup_exit; if ((ret = buspirate_sendrecv(bp_commbuf, 0, 1))) - return ret; + goto init_err_cleanup_exit; msg_pdbg("Raw bitbang mode version %c\n", bp_commbuf[0]); if (bp_commbuf[0] != '1') { msg_perr("Can't handle raw bitbang mode version %c!\n", bp_commbuf[0]); - return 1; + ret = 1; + goto init_err_cleanup_exit; } /* Enter raw SPI mode */ bp_commbuf[0] = 0x01; ret = buspirate_sendrecv(bp_commbuf, 1, 0); - if (ret) - return 1; + if (ret) { + ret = 1; + goto init_err_cleanup_exit; + } if ((ret = buspirate_wait_for_string(bp_commbuf, "SPI"))) - return ret; + goto init_err_cleanup_exit; if ((ret = buspirate_sendrecv(bp_commbuf, 0, 1))) - return ret; + goto init_err_cleanup_exit; msg_pdbg("Raw SPI mode version %c\n", bp_commbuf[0]); if (bp_commbuf[0] != '1') { msg_perr("Can't handle raw SPI mode version %c!\n", bp_commbuf[0]); - return 1; + ret = 1; + goto init_err_cleanup_exit; } /* Initial setup (SPI peripherals config): Enable power, CS high, AUX */ @@ -614,21 +616,27 @@ msg_pdbg("Enabling pull-up resistors.\n"); } ret = buspirate_sendrecv(bp_commbuf, 1, 1); - if (ret) - return 1; + if (ret) { + ret = 1; + goto init_err_cleanup_exit; + } if (bp_commbuf[0] != 0x01) { msg_perr("Protocol error while setting power/CS/AUX(/Pull-up resistors)!\n"); - return 1; + ret = 1; + goto init_err_cleanup_exit; } /* Set SPI speed */ bp_commbuf[0] = 0x60 | spispeed; ret = buspirate_sendrecv(bp_commbuf, 1, 1); - if (ret) - return 1; + if (ret) { + ret = 1; + goto init_err_cleanup_exit; + } if (bp_commbuf[0] != 0x01) { msg_perr("Protocol error while setting SPI speed!\n"); - return 1; + ret = 1; + goto init_err_cleanup_exit; } /* Set SPI config: output type, idle, clock edge, sample */ @@ -638,24 +646,38 @@ msg_pdbg("Pull-ups enabled, so using HiZ pin output! (Open-Drain mode)\n"); } ret = buspirate_sendrecv(bp_commbuf, 1, 1); - if (ret) - return 1; + if (ret) { + ret = 1; + goto init_err_cleanup_exit; + } if (bp_commbuf[0] != 0x01) { msg_perr("Protocol error while setting SPI config!\n"); - return 1; + ret = 1; + goto init_err_cleanup_exit; } /* De-assert CS# */ bp_commbuf[0] = 0x03; ret = buspirate_sendrecv(bp_commbuf, 1, 1); - if (ret) - return 1; + if (ret) { + ret = 1; + goto init_err_cleanup_exit; + } if (bp_commbuf[0] != 0x01) { msg_perr("Protocol error while raising CS#!\n"); - return 1; + ret = 1; + goto init_err_cleanup_exit; } + if (register_shutdown(buspirate_spi_shutdown, NULL) != 0) { + ret = 1; + goto init_err_cleanup_exit; + } register_spi_master(&spi_master_buspirate); return 0; + +init_err_cleanup_exit: + buspirate_spi_shutdown(NULL); + return ret; } -- To view, visit https://review.coreboot.org/c/flashrom/+/52877 To unsubscribe, or for help writing mail filters, visit https://review.coreboot.org/settings Gerrit-Project: flashrom Gerrit-Branch: master Gerrit-Change-Id: I04d57e2552d23a1a4a906c68539f0ccefc13e8a0 Gerrit-Change-Number: 52877 Gerrit-PatchSet: 1 Gerrit-Owner: Anastasia Klimchuk <aklm@chromium.org> Gerrit-MessageType: newchange
participants (1)
Anastasia Klimchuk (Code Review)
